parasitic cell blocking
SAMIRAZ
Newbie
Hi ,
At the moment I am trying to perform parasitic extraction using PVS-Quantus to get the RLC parasitics of the metal stack (routing).
the Pcell of my the transistor already includes RLC parasitics , I want this part of the layout to be blocked from parasitic extraction to avoid parasitics double counting
To do that :
• I preserved the Pcell during PVS LVS using preserve_cell_list in PVL.
• Then I introduced the cell to be blocked which is the Pcell to PVS Quantus tool in a txt file as pcellname_CDNS* .
checking fT and fmax of the transitor I can see that there is parasitics double counting (10-15% degradation).
any idea how solve this issue ?
Br.
Have you changed the corner after extraction for simulation? Typically schematic simulations and extracted simulations are done with different corners.
I am using nominal (typical) corner for both schematic and extraction.
There is something called a "pre" sim and "post" sim.. Check your PDK documents.
Which technology is this?
Hi ,
To do that :
Br.
I think it should be expected that performance deteriorates when you instantiate your cell at higher hierarchy, due to interconnects parasitics.
Why do you think your parasitics in the pcell are double counted?
