Page 7 of 7 FirstFirst ... 5 6 7
Results 121 to 130 of 130
  1. #121
    Points: 38,501, Level: 47
    Jun 2010
    6,962
    38,501
    47
    Re: AXI arvalid signal issue
    Quote Originally Posted by dpaul View Post
    This is your investigation as you have the environment set with the slave instantiated.
    changing ARADDR to 1 also does not work, I suspect the data is not actually written, but we have BVALID asserted and BRESP is ok
    Can you not add-to-wave and investiage the slave internal signals? See if your data is getting latched after the address and write-data handshakes.
    All I can say is that Xilinx AXI based cores might have bugs (they don't perform formal verification of their AXI based cores).
    On another note, if there is an AXI Interconnect b/w the master and slave, then you might want to investigate the interface signals there.
    Before blaming Xilinx IP - be very sure that your cores are functioning correctly.
    This sounds very much like a slave issue. @promach. Telling us that it doesnt work helps no one, and we cannot help you. Unless you post your code, AND your test envirmnent, or a small example exhibiting the problems, there is nothing more we can do.
  2. #122
    Advanced Member level 3
    Points: 4,010, Level: 14
    Feb 2016
    786
    4,010
    14
    See https://gist.github.com/promach/251c...instructions-v
    I have two AXi interfaces. I am only testing the one of the AXi interfaces.
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    311
    312
    313
    314
    315
    316
    317
    318
    319
    320
    321
    322
    323
    324
    325
    326
    327
    328
    329
    330
    331
    332
    333
    334
    335
    336
    337
    338
    339
    340
    341
    342
    343
    344
    345
    346
    347
    348
    349
    350
    351
    `define LOOPBACK 1
    module read_instructions(clk, reset,
                i_axi_awready, o_axi_awid, o_axi_awaddr, o_axi_awlen, o_axi_awsize, o_axi_awburst,
                o_axi_awlock, o_axi_awcache, o_axi_awprot, o_axi_awqos, o_axi_awvalid,
                i_axi_wready, o_axi_wdata, o_axi_wstrb, o_axi_wlast, o_axi_wvalid,
                i_axi_bid, i_axi_bresp, i_axi_bvalid, o_axi_bready,
                i_axi_arready, o_axi_arid, o_axi_araddr, o_axi_arlen, o_axi_arsize, o_axi_arburst,
                o_axi_arlock, o_axi_arcache, o_axi_arprot, o_axi_arqos, o_axi_arvalid,
                i_axi_rid, i_axi_rresp, i_axi_rvalid, i_axi_rdata, i_axi_rlast, o_axi_rready);
    `ifdef FORMAL
        // AXI Address width (log wordsize) for DDR
        parameter C_AXI_ADDR_WIDTH = 9; // just for random test, need to change for actual neural network
        parameter C_AXI_DATA_WIDTH = 8; // related to AxSIZE
        parameter C_SIZE_OF_CACHE = 4; // for storing weights and biases parameters of neural network
    `else
        parameter C_AXI_ADDR_WIDTH = 12; // just for random test, need to change for actual neural network
        parameter C_AXI_DATA_WIDTH = 128; // related to AxSIZE
        parameter C_SIZE_OF_CACHE = 64; // for storing weights and biases parameters of neural network
    `endif
    parameter C_AXI_ID_WIDTH    =   1;
    localparam NUM_OF_BITS_PER_BYTES = 8;
    localparam INCR_BURST_TYPE = 2'b01; // AxBURST[2:0] , see 'burst type' section in AXI spec
    // AXI4 extends burst length support for the INCR burst type to 1 to 256 transfers.
    // Support for all other burst types in AXI4 remains at 1 to 16 transfers.
    // for wrapping bursts, the burst length must be 2, 4, 8, or 16
    // a burst must not cross a 4KB address boundary
    // early termination of bursts is not supported
    localparam MAX_BURST_LENGTH = 255;
    localparam BURST_SIZE_ENCODING_WIDTH = 3; // AxSIZE[2:0] , see 'burst size' section in AXI spec
    localparam SUBWORD_SMALLEST_UNIT = 8; // smallest granularity in AXI protocol : 8 bit
    localparam PROT_BITWIDTH = 3;
    localparam QOS_BITWIDTH = 4;
    localparam CACHE_BITWIDTH = 4;
    input clk, reset;
    // AXI write address channel signals
        input   wire            i_axi_awready; // Slave is ready to accept
        output  wire    [C_AXI_ID_WIDTH-1:0]    o_axi_awid; // Write ID
        output  reg [C_AXI_ADDR_WIDTH-1:0]  o_axi_awaddr;   // Write address
        output  wire    [$clog2(MAX_BURST_LENGTH)-1:0]      o_axi_awlen;    // Write Burst Length
        output  wire    [BURST_SIZE_ENCODING_WIDTH-1:0]     o_axi_awsize;   // Write Burst size
        output  wire    [1:0]       o_axi_awburst;  // Write Burst type
        output  wire    [0:0]       o_axi_awlock;   // Write lock type
        output  wire    [CACHE_BITWIDTH-1:0]        o_axi_awcache;  // Write Cache type
        output  wire    [PROT_BITWIDTH-1:0]     o_axi_awprot;   // Write Protection type
        output  wire    [QOS_BITWIDTH-1:0]      o_axi_awqos;    // Write Quality of Svc
        output  reg         o_axi_awvalid;  // Write address valid
    // AXI write data channel signals
        input   wire            i_axi_wready;  // Write data ready
        output  reg [C_AXI_DATA_WIDTH-1:0]  o_axi_wdata;    // Write data
        output  reg [C_AXI_DATA_WIDTH/SUBWORD_SMALLEST_UNIT-1:0] o_axi_wstrb;   // Write strobes
        output  reg         o_axi_wlast;    // Last write transaction
        output  reg         o_axi_wvalid;   // Write valid
    // AXI write response channel signals
    /* verilator lint_off UNUSED */
        input wire [C_AXI_ID_WIDTH-1:0] i_axi_bid;  // Response ID
    /* verilator lint_on UNUSED */
        input   wire [1:0]      i_axi_bresp;    // Write response
        input   wire            i_axi_bvalid;  // Write reponse valid
        output  wire            o_axi_bready;  // Response ready
    // AXI read address channel signals
        input   wire            i_axi_arready;  // Read address ready
        output  wire    [C_AXI_ID_WIDTH-1:0]    o_axi_arid; // Read ID
        output  reg [C_AXI_ADDR_WIDTH-1:0]  o_axi_araddr;   // Read address
        output  wire    [$clog2(MAX_BURST_LENGTH)-1:0]      o_axi_arlen;    // Read Burst Length
        output  wire    [BURST_SIZE_ENCODING_WIDTH-1:0]     o_axi_arsize;   // Read Burst size
        output  wire    [1:0]       o_axi_arburst;  // Read Burst type
        output  wire    [0:0]       o_axi_arlock;   // Read lock type
        output  wire    [CACHE_BITWIDTH-1:0]        o_axi_arcache;  // Read Cache type
        output  wire    [PROT_BITWIDTH-1:0]     o_axi_arprot;   // Read Protection type
        output  wire    [QOS_BITWIDTH-1:0]      o_axi_arqos;    // Read Quality of Svc
        output  reg         o_axi_arvalid;  // Read address valid
    // AXI read data channel signals
        input wire [C_AXI_ID_WIDTH-1:0] i_axi_rid;     // Response ID
        input   wire    [1:0]       i_axi_rresp;   // Read response
        input   wire            i_axi_rvalid;  // Read reponse valid
        input wire [C_AXI_DATA_WIDTH-1:0] i_axi_rdata;    // Read data
        input   wire            i_axi_rlast;    // Read last
        output  wire            o_axi_rready;  // Read Response ready
    always @(posedge clk)
    begin
        if(reset) o_axi_wstrb <= 0;
        // burst alignment mechanism, see [url]https://i.imgur.com/jKbzfFo.png[/url]
        // o_axi_wstrb <= (~0) << (o_axi_awaddr % o_axi_awlen);
        // all the bracket variables are for removing verilator width warnings
        else o_axi_wstrb <= ((~0) << (o_axi_awaddr %
                                      {{(C_AXI_ADDR_WIDTH-$clog2(MAX_BURST_LENGTH)){1'b0}}, o_axi_awlen}));
    end
    wire write_response_is_ok = i_axi_bvalid && ((i_axi_bresp == 'b00) || (i_axi_bresp == 'b01));
    // need to implement data re-transmission
    wire write_response_is_not_ok = i_axi_bvalid && !((i_axi_bresp == 'b00) || (i_axi_bresp == 'b01));
    begin
        if(reset)
        begin
            o_axi_wvalid <= 0;
        end
        else if(!(o_axi_wvalid && !i_axi_wready))
        begin
            // Note that both o_axi_awsize , o_axi_awlen are of hardware constants, so no multiply hardware
            // since this is for testing, WDATA just uses some values up to the total size of the write address space
            // Note: a master must not wait for AWREADY to be asserted before driving WVALID
            o_axi_wvalid <= (o_axi_wlast) ? 0 :
                            (o_axi_wdata < (o_axi_awsize*o_axi_awlen));
        end
    end
    wire ddr_write_address_range_is_valid = (o_axi_awaddr < (1 << C_AXI_ADDR_WIDTH));
    begin
        if(reset) o_axi_awvalid <= 0;
        // AXI specification: A3.3.1 Dependencies between channel handshake signal
        // the VALID signal of the AXI interface sending information must not be dependent on
        // the READY signal of the AXI interface receiving that information
        // this is to prevent deadlock
        // since AXI slave could wait for i_axi_awvalid to be true before setting o_axi_awready true.
        // Note: For same interface, VALID cannot depend upon READY, but READY can depends upon VALID
        // Note: Once VALID is asserted, it MUST be kept asserted until READY is asserted.
        //       VALID signal needs to be set (initially) independent of READY signal,
        //       and then only ever adjusted if !(VALID && !READY)
        // Note: the master must not wait for the slave to assert AWREADY before asserting AWVALID
        // Note: (!(o_axi_awvalid && !i_axi_awready)) == (!awvalid || awready)
        //       == (!awvalid || (awvalid && awready)).
        //       it means "no transaction in progress or transaction accepted"
        else if(!(o_axi_awvalid && !i_axi_awready))
                o_axi_awvalid <= /*i_axi_awready &&*/ (ddr_write_address_range_is_valid);
    end
    wire write_transaction_is_accepted = (o_axi_wvalid) && (i_axi_wready);
    wire address_write_transaction_is_accepted = (o_axi_awvalid) && (i_axi_awready);
    begin
        if(reset)
        begin
            o_axi_awaddr <= 0;
            //o_axi_wdata <= 0;
        end
        else if(address_write_transaction_is_accepted)
        begin
            o_axi_awaddr <= o_axi_awaddr + 1;
            //o_axi_wdata <= o_axi_wdata + 1;
        end
    end
    begin
        if(reset)
        begin
            //o_axi_awaddr <= 0;
            o_axi_wdata <= 0;
        end
        else if(write_transaction_is_accepted)
        begin
            //o_axi_awaddr <= o_axi_awaddr + 1;
        end
    end
    `ifdef LOOPBACK
    wire read_address_contains_loopback_data =
    (o_axi_awaddr > (o_axi_araddr + {{(C_AXI_ADDR_WIDTH-$clog2(MAX_BURST_LENGTH)){1'b0}}, o_axi_awlen}));
    `endif
    wire ddr_read_address_range_is_valid = (o_axi_araddr < (1 << C_AXI_ADDR_WIDTH));
    begin
        if(reset) o_axi_arvalid <= 0;
        // since AXI slave could wait for i_axi_arvalid to be true before setting o_axi_arready true.
        // Note: the master must not wait for the slave to assert ARREADY before asserting ARVALID
        // Note: (!(o_axi_arvalid && !i_axi_arready)) == (!arvalid || arready)
        //       == (!arvalid || (arvalid && arready)).
        // Note: o_axi_rready is used for backpressure mechanism
        else if(!(o_axi_arvalid && !i_axi_arready))
            `ifdef LOOPBACK
                o_axi_arvalid <= /*i_axi_arready &&*/ (ddr_read_address_range_is_valid) &&
                                (read_address_contains_loopback_data) &&
                                (o_axi_bready && i_axi_bvalid && write_response_is_ok);
            `else
                o_axi_arvalid <= /*i_axi_arready &&*/ (ddr_read_address_range_is_valid);
            `endif
    end
    reg [$clog2(MAX_BURST_LENGTH)-1:0] num_of_write_transactions;
    begin
        if(reset) num_of_write_transactions <= 0;
        else if(o_axi_wvalid && i_axi_wready)
                num_of_write_transactions <= (o_axi_wlast) ? 0 : num_of_write_transactions + 1;
    end
    begin
        if(reset) o_axi_wlast <= 0;
        else o_axi_wlast <= (num_of_write_transactions == (o_axi_awlen - 1));
    end
    //assign o_axi_wlast = 0;
    assign o_axi_awid = 0;
    assign o_axi_awlen = 15; // each burst has (Burst_Length = AxLEN[7:0] + 1) data transfers
    /* verilator lint_off WIDTH */
    assign o_axi_awsize = $clog2(C_AXI_DATA_WIDTH/NUM_OF_BITS_PER_BYTES); // 128 bits (16 bytes) of data when AxSIZE[2:0] = 3'b100
    // Burst_Length = AxLEN[7:0] + 1, to accommodate the extended burst length of the INCR burst type in AXI4.
    /* verilator lint_on WIDTH */
    assign o_axi_awburst = INCR_BURST_TYPE;
    assign o_axi_awlock = 0;
    assign o_axi_awcache = 0;
    assign o_axi_awprot = 0;
    assign o_axi_awqos = 0; // no priority or QoS concept
    assign o_axi_arqos = 0; // no priority or QoS concept
    assign o_axi_arburst = INCR_BURST_TYPE;
    assign o_axi_arsize = $clog2(C_AXI_DATA_WIDTH/NUM_OF_BITS_PER_BYTES); // 128 bits (16 bytes) of data when AxSIZE[2:0] = 3'b100
    assign o_axi_arlen = 15; // each burst has (Burst_Length = AxLEN[7:0] + 1) data transfers
    assign o_axi_arprot = 3'b010; // {data access, non-secure access, unprivileged access}
    assign o_axi_arlock = 0; // AXI4 does not support locked transactions.
    assign o_axi_arcache = 0; // mostly used for HPS (hard processor system) such as ARM hard CPU IP
    assign o_axi_arid = 0; // there is one AXI slave which is the DDR memory (A, B, or C) ?
    // what situations will render data requester (AXI master) busy to receive read response ??
    // such as AXI interconnect where arbitration will fail to acquire the data transfer priority
    // such as the internal cache storage to store the data from external DDR memory is now full
    // So, let's use a random value that is $anyseq in formal verification
    assign o_axi_rready = (reset) ? 1 : `ifdef FORMAL $anyseq `else (!cache_is_full) `endif;
    // The master can assert BREADY before BVALID is asserted.
    assign o_axi_bready = (reset) ? 1 : `ifdef FORMAL $anyseq `else (i_axi_bvalid) `endif;
    wire address_read_transaction_is_accepted = (o_axi_arvalid) && (i_axi_arready);
    begin
        if(reset) o_axi_araddr <= 0;
        // When ARVALID & ARREADY are both high the next ARADDR can be generated
        // because the current address for the current transfer is now complete (ARVALID & ARREADY).
        else if(address_read_transaction_is_accepted)
            o_axi_araddr <= o_axi_araddr + 1; // increments DDR address to read instructions from
    end
    wire arm_write_param_enable;
    wire [C_AXI_DATA_WIDTH-1:0] arm_write_param_data;
    wire cache_is_empty;
    wire [$clog2(C_SIZE_OF_CACHE)-1:0] cache_address_for_reading;
    assign cache_address_for_reading = 0; // for testing only
    wire valid_read_response_does_not_contain_error_messages = i_axi_rvalid && (i_axi_rresp == 0);
    wire cache_is_full; // needed since C_SIZE_OF_CACHE is always smaller than SIZE_OF_DDR_MEMORY
    // for storing neural network parameters (weights and biases) at destination side,
    // so this bram acts as intermediate cache (much smaller size than DDR memory) for the neural network
    // no need AXI protocol in order to save logic usage, thus lesser area and power consumption
    cache_controller #(.C_DATA_WIDTH(C_AXI_DATA_WIDTH), .C_SIZE_OF_CACHE(C_SIZE_OF_CACHE)) nn_feature_cache
        .clk(clk), .reset(reset),
        .i_data(i_axi_rdata), // NN params coming from DDR memory
        .i_data_is_valid
         ((o_axi_rready && valid_read_response_does_not_contain_error_messages)), // DDR data is valid
        .i_addr(cache_address_for_reading),
        .full(cache_is_full), // NN params cache is full
        .o_data(arm_write_param_data), // NN params going to neural network layers
        .o_data_is_valid(arm_write_param_enable), // neural network layers to start another intermediate computations
        .empty(cache_is_empty) // no NN params to feed into the neural network layers
    `ifdef FORMAL
    localparam SIXTH_ADDRESS_IN_REQUEST = 6;
    initial assume(reset);
    reg first_clock_had_passed = 0;
    always @(posedge clk) first_clock_had_passed <= 1;
        if(first_clock_had_passed)
            cover((o_axi_araddr > SIXTH_ADDRESS_IN_REQUEST) && address_read_transaction_is_accepted &&
                    $past(i_axi_arready) && $past(o_axi_rready) && !o_axi_rready);
    `endif
    endmodule
  3. #123
    Jun 2010
    6,962
    38,501
    47
    You will struggle to find anyone to do your work for you. That is a lot of code to test. Why not specify what the problem is with a clear SMALL usecase example. Or ask more specific questions?
    You dont provide any specific problems, or help us. 120 posts in now.
    Why cant you just debug the slave?
  4. #124
    Feb 2016
    786
    4,010
    14
    That is why I never provide code to ask about the wrong AXI waveform until someone asks for the code. And data loopback test is already a SMALL testcase.
    From my personal AXi experience with locating which signals to debug, there is actually not really much a need to check the code if waveform could tells it all, in my case, RDATA returns XXX unknown bits for data loopback case.
    I had already asked very specific question about the simulation waveform. See posts #115 and #116
    As for the slave, I do not have the source code of Xilinx BRAM IP. And I am only provided with its slave AXI interface signals.
  5. #125
    Feb 2016
    786
    4,010
    14
    Is it true that XILINX AXI slave IP does not support simultaneous two-way data transfer ?
    In other words, for different AWADDR and ARADDR, AW* channel cannot be active when AR* channel is active ?
  6. #126
    Points: 8,900, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,332
    8,900
    22
    Blog Entries
    Should not be. Better you ask this in the Xilinx forums.
    As for your AXI enlightenment and wisdom, I would recommend reading all the AXI related articles in this blog.
    https://zipcpu.com/formal/2019/09/06/axi-story.html
    FPGA enthusiast!
  7. #127
    Feb 2016
    786
    4,010
    14
    I know what is wrong. Internal BRAM_en signal is not asserted but what actually caused this ?
    Something is very wrong. clk and reset signals have been connected correctly in the module instantiation.
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    bram_axi_controller #(.C_AXI_DATA_WIDTH(C_AXI_DATA_WIDTH)) ddr_nn_params
        .o_axi_awready(axi_awready[0]), .i_axi_awid(axi_awid[0]),       .i_axi_awaddr(axi_awaddr[0]),
        .i_axi_awlen(axi_awlen[0]),     .i_axi_awsize(axi_awsize[0]),   .i_axi_awburst(axi_awburst[0]),
        .i_axi_awlock(axi_awlock[0]),   .i_axi_awcache(axi_awcache[0]), .i_axi_awprot(axi_awprot[0]),
        .i_axi_awqos(axi_awqos[0]),     .i_axi_awvalid(axi_awvalid[0]), .o_axi_wready(axi_wready[0]),
        .i_axi_wdata(axi_wdata[0]),     .i_axi_wstrb(axi_wstrb[0]),     .i_axi_wlast(axi_wlast[0]),
        .i_axi_wvalid(axi_wvalid[0]),   .o_axi_bid(axi_bid[0]),         .o_axi_bresp(axi_bresp[0]),
        .o_axi_bvalid(axi_bvalid[0]),   .i_axi_bready(axi_bready[0]),   .o_axi_arready(axi_arready[0]),
        .i_axi_arid(axi_arid[0]),       .i_axi_araddr(axi_araddr[0]),   .i_axi_arlen(axi_arlen[0]),
        .i_axi_arsize(axi_arsize[0]),   .i_axi_arburst(axi_arburst[0]), .i_axi_arlock(axi_arlock[0]),
        .i_axi_arcache(axi_arcache[0]), .i_axi_arprot(axi_arprot[0]),   .i_axi_arqos(axi_arqos[0]),
        .i_axi_arvalid(axi_arvalid[0]), .o_axi_rid(axi_rid[0]),         .o_axi_rresp(axi_rresp[0]),
        .o_axi_rvalid(axi_rvalid[0]),   .o_axi_rdata(axi_rdata[0]),     .o_axi_rlast(axi_rlast[0]),
        .i_axi_rready(axi_rready[0])
  8. #128
    Points: 6,502, Level: 19
    Feb 2015
    1,053
    6,502
    19
    The posted code doesn't show any of the bram interface ports or the bram itself.
  9. #129
    Feb 2016
    786
    4,010
    14
    See this internal VHDL source code generated by Vivado AXI BRAM controller IP
    addra_bram_addra_i is not driven at all
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    311
    312
    313
    314
    315
    316
    317
    318
    319
    320
    321
    322
    323
    324
    325
    326
    327
    328
    329
    330
    331
    332
    333
    334
    335
    336
    337
    338
    339
    340
    341
    342
    343
    344
    345
    346
    347
    348
    349
    350
    351
    352
    353
    354
    355
    356
    357
    358
    359
    360
    361
    362
    363
    364
    365
    366
    367
    368
    369
    370
    371
    372
    373
    374
    375
    376
    377
    378
    379
    380
    381
    382
    383
    384
    385
    386
    387
    388
    389
    390
    391
    392
    393
    394
    395
    396
    397
    398
    399
    400
    401
    402
    403
    404
    405
    406
    407
    408
    409
    410
    411
    412
    413
    414
    415
    416
    417
    418
    419
    420
    421
    422
    423
    424
    425
    426
    427
    428
    429
    430
    431
    432
    433
    434
    435
    436
    437
    438
    439
    440
    441
    442
    443
    444
    445
    446
    447
    448
    449
    450
    451
    452
    453
    454
    455
    456
    457
    458
    459
    460
    461
    462
    463
    464
    465
    466
    467
    468
    469
    470
    471
    472
    473
    474
    475
    476
    477
    478
    479
    480
    481
    482
    483
    484
    485
    486
    487
    488
    489
    490
    491
    492
    493
    494
    495
    496
    497
    498
    499
    500
    501
    502
    503
    504
    505
    506
    507
    508
    509
    510
    511
    512
    513
    514
    515
    516
    517
    518
    519
    520
    521
    522
    523
    524
    525
    526
    527
    528
    529
    530
    531
    532
    533
    534
    535
    536
    537
    538
    539
    540
    541
    542
    543
    544
    545
    546
    547
    548
    549
    550
    551
    552
    553
    554
    555
    556
    557
    558
    559
    560
    561
    562
    563
    564
    565
    566
    567
    568
    569
    570
    571
    572
    573
    574
    575
    576
    577
    578
    579
    580
    581
    582
    583
    584
    585
    586
    587
    588
    589
    590
    591
    592
    593
    594
    595
    596
    597
    598
    599
    600
    601
    602
    603
    604
    605
    606
    607
    608
    609
    610
    611
    612
    613
    614
    615
    616
    617
    618
    619
    620
    621
    622
    623
    624
    625
    626
    627
    628
    629
    630
    631
    632
    633
    634
    635
    636
    637
    638
    639
    640
    641
    642
    643
    644
    645
    646
    647
    648
    649
    650
    651
    652
    653
    654
    655
    656
    657
    658
    659
    660
    661
    662
    663
    664
    665
    666
    667
    668
    669
    670
    671
    672
    673
    674
    675
    676
    677
    678
    679
    680
    681
    682
    683
    684
    685
    686
    687
    688
    689
    690
    691
    692
    693
    694
    695
    696
    697
    698
    699
    700
    701
    702
    703
    704
    705
    706
    707
    708
    709
    710
    711
    712
    713
    714
    715
    716
    717
    718
    719
    720
    721
    722
    723
    724
    725
    726
    727
    728
    729
    730
    731
    732
    733
    734
    735
    736
    737
    738
    739
    740
    741
    742
    743
    744
    745
    746
    747
    748
    749
    750
    751
    752
    753
    754
    755
    756
    757
    758
    759
    760
    761
    762
    763
    764
    765
    766
    767
    768
    769
    770
    771
    772
    773
    774
    775
    776
    777
    778
    779
    780
    781
    782
    783
    784
    785
    786
    787
    788
    789
    790
    791
    792
    793
    794
    795
    796
    797
    798
    799
    800
    801
    802
    803
    804
    805
    806
    807
    808
    809
    810
    811
    812
    813
    814
    815
    816
    817
    818
    819
    820
    821
    822
    823
    824
    825
    826
    827
    828
    829
    830
    831
    832
    833
    834
    835
    836
    837
    838
    839
    840
    841
    842
    843
    844
    845
    846
    847
    848
    849
    850
    851
    852
    853
    854
    855
    856
    857
    858
    859
    860
    861
    862
    863
    864
    865
    866
    867
    868
    869
    870
    871
    872
    873
    874
    875
    876
    877
    878
    879
    880
    881
    882
    883
    884
    885
    886
    887
    888
    889
    890
    891
    892
    893
    894
    895
    896
    897
    898
    899
    900
    901
    902
    903
    904
    905
    906
    907
    908
    909
    910
    911
    912
    913
    914
    915
    916
    917
    918
    919
    920
    921
    922
    923
    924
    925
    926
    927
    928
    929
    930
    931
    932
    933
    934
    935
    936
    937
    938
    939
    940
    941
    942
    943
    944
    945
    946
    947
    948
    949
    950
    951
    952
    953
    954
    955
    956
    957
    958
    959
    960
    961
    962
    963
    964
    965
    966
    967
    968
    969
    970
    971
    972
    973
    974
    975
    976
    977
    978
    979
    980
    981
    982
    983
    984
    985
    986
    987
    988
    989
    990
    991
    992
    993
    994
    995
    996
    997
    998
    999
    1000
    1001
    1002
    1003
    1004
    1005
    1006
    1007
    1008
    1009
    1010
    1011
    1012
    1013
    1014
    1015
    1016
    1017
    1018
    1019
    1020
    1021
    1022
    1023
    1024
    1025
    1026
    1027
    1028
    1029
    1030
    1031
    1032
    1033
    1034
    1035
    1036
    1037
    1038
    1039
    1040
    1041
    1042
    1043
    1044
    1045
    1046
    1047
    1048
    1049
    1050
    1051
    1052
    1053
    1054
    1055
    1056
    1057
    1058
    1059
    1060
    1061
    1062
    1063
    1064
    1065
    1066
    1067
    1068
    1069
    1070
    1071
    1072
    1073
    1074
    1075
    1076
    1077
    1078
    1079
    1080
    1081
    1082
    1083
    1084
    1085
    1086
    1087
    1088
    1089
    1090
    1091
    1092
    1093
    1094
    1095
    1096
    1097
    1098
    1099
    1100
    1101
    1102
    1103
    1104
    1105
    1106
    1107
    1108
    1109
    1110
    1111
    1112
    1113
    1114
    1115
    1116
    1117
    1118
    1119
    1120
    1121
    1122
    1123
    1124
    1125
    1126
    1127
    1128
    1129
    1130
    1131
    1132
    1133
    1134
    1135
    1136
    1137
    1138
    1139
    1140
    1141
    1142
    1143
    1144
    1145
    1146
    1147
    1148
    1149
    1150
    1151
    1152
    1153
    1154
    1155
    1156
    1157
    1158
    1159
    1160
    1161
    1162
    1163
    1164
    1165
    1166
    1167
    1168
    1169
    1170
    1171
    1172
    1173
    1174
    1175
    1176
    1177
    1178
    1179
    1180
    1181
    1182
    1183
    1184
    1185
    1186
    1187
    1188
    1189
    1190
    1191
    1192
    1193
    1194
    1195
    1196
    1197
    1198
    1199
    1200
    1201
    1202
    1203
    1204
    1205
    1206
    1207
    1208
    1209
    1210
    1211
    1212
    1213
    1214
    1215
    1216
    1217
    1218
    1219
    1220
    1221
    1222
    1223
    1224
    1225
    1226
    1227
    1228
    1229
    1230
    1231
    1232
    1233
    1234
    1235
    1236
    1237
    1238
    1239
    1240
    1241
    1242
    1243
    1244
    1245
    1246
    1247
    1248
    1249
    1250
    1251
    1252
    1253
    1254
    1255
    1256
    1257
    1258
    1259
    1260
    1261
    1262
    1263
    1264
    1265
    1266
    1267
    1268
    1269
    1270
    1271
    1272
    1273
    1274
    1275
    1276
    1277
    1278
    1279
    1280
    1281
    1282
    1283
    1284
    1285
    1286
    1287
    1288
    1289
    1290
    1291
    1292
    1293
    1294
    1295
    1296
    1297
    1298
    1299
    1300
    1301
    1302
    1303
    1304
    1305
    1306
    1307
    1308
    1309
    1310
    1311
    1312
    1313
    1314
    1315
    1316
    1317
    1318
    1319
    1320
    1321
    1322
    1323
    1324
    1325
    1326
    1327
    1328
    1329
    1330
    1331
    1332
    1333
    1334
    1335
    1336
    1337
    1338
    1339
    1340
    1341
    1342
    1343
    1344
    1345
    1346
    1347
    1348
    1349
    1350
    1351
    1352
    1353
    1354
    1355
    1356
    1357
    1358
    1359
    1360
    1361
    1362
    1363
    1364
    1365
    1366
    1367
    1368
    1369
    1370
    1371
    1372
    1373
    1374
    1375
    1376
    1377
    1378
    1379
    1380
    1381
    1382
    1383
    1384
    1385
    1386
    1387
    1388
    1389
    1390
    1391
    1392
    1393
    1394
    1395
    1396
    1397
    1398
    1399
    1400
    1401
    1402
    1403
    1404
    1405
    1406
    1407
    1408
    1409
    1410
    1411
    1412
    1413
    1414
    1415
    1416
    1417
    1418
    1419
    1420
    1421
    1422
    1423
    1424
    1425
    1426
    1427
    1428
    1429
    1430
    1431
    1432
    1433
    1434
    1435
    1436
    1437
    1438
    1439
    1440
    1441
    1442
    1443
    1444
    1445
    1446
    1447
    1448
    1449
    1450
    1451
    1452
    1453
    1454
    1455
    1456
    1457
    1458
    1459
    1460
    1461
    1462
    1463
    1464
    1465
    1466
    1467
    1468
    1469
    1470
    1471
    1472
    1473
    1474
    1475
    1476
    1477
    1478
    1479
    1480
    1481
    1482
    1483
    1484
    1485
    1486
    1487
    1488
    1489
    1490
    1491
    1492
    1493
    1494
    1495
    1496
    1497
    1498
    1499
    1500
    1501
    1502
    1503
    1504
    1505
    1506
    1507
    1508
    1509
    1510
    1511
    1512
    1513
    1514
    1515
    1516
    1517
    1518
    1519
    1520
    1521
    1522
    1523
    1524
    1525
    1526
    1527
    1528
    1529
    1530
    1531
    1532
    1533
    1534
    1535
    1536
    1537
    1538
    1539
    1540
    1541
    1542
    1543
    1544
    1545
    1546
    1547
    1548
    1549
    1550
    1551
    1552
    1553
    1554
    1555
    1556
    1557
    1558
    1559
    1560
    1561
    1562
    1563
    1564
    1565
    1566
    1567
    1568
    1569
    1570
    1571
    1572
    1573
    1574
    1575
    1576
    1577
    1578
    1579
    1580
    1581
    1582
    1583
    1584
    1585
    1586
    1587
    1588
    1589
    1590
    1591
    1592
    1593
    1594
    1595
    1596
    1597
    1598
    1599
    1600
    1601
    1602
    1603
    1604
    1605
    1606
    1607
    1608
    1609
    1610
    1611
    1612
    1613
    1614
    1615
    1616
    1617
    1618
    1619
    1620
    1621
    1622
    1623
    1624
    1625
    1626
    1627
    1628
    1629
    1630
    1631
    -- SRL_FIFO entity and architecture
    -- ** DISCLAIMER OF LIABILITY                                             **
    -- ** This text/file contains proprietary, confidential                   **
    -- ** information of Xilinx, Inc., is distributed under                   **
    -- ** license from Xilinx, Inc., and may be used, copied                  **
    -- ** and/or disclosed only pursuant to the terms of a valid              **
    -- ** license agreement with Xilinx, Inc. Xilinx hereby                   **
    -- ** grants you a license to use this text/file solely for               **
    -- ** design, simulation, implementation and creation of                  **
    -- ** design files limited to Xilinx devices or technologies.             **
    -- ** Use with non-Xilinx devices or technologies is expressly            **
    -- ** prohibited and immediately terminates your license unless           **
    -- ** covered by a separate agreement.                                    **
    -- ** Xilinx is providing this design, code, or information               **
    -- ** "as-is" solely for use in developing programs and                   **
    -- ** solutions for Xilinx devices, with no obligation on the             **
    -- ** part of Xilinx to provide support. By providing this design,        **
    -- ** code, or information as one possible implementation of              **
    -- ** this feature, application or standard, Xilinx is making no          **
    -- ** representation that this implementation is free from any            **
    -- ** claims of infringement. You are responsible for obtaining           **
    -- ** any rights you may require for your implementation.                 **
    -- ** Xilinx expressly disclaims any warranty whatsoever with             **
    -- ** respect to the adequacy of the implementation, including            **
    -- ** but not limited to any warranties or representations that this      **
    -- ** implementation is free from claims of infringement, implied         **
    -- ** warranties of merchantability or fitness for a particular           **
    -- ** purpose.                                                            **
    -- ** Xilinx products are not intended for use in life support            **
    -- ** appliances, devices, or systems. Use in such applications is        **
    -- ** expressly prohibited.                                               **
    -- ** Any modifications that are made to the Source Code are              **
    -- ** done at the user’s sole risk and will be unsupported.               **
    -- ** The Xilinx Support Hotline does not have access to source           **
    -- ** code and therefore cannot answer specific questions related         **
    -- ** to source HDL. The Xilinx Hotline support of original source        **
    -- ** code IP shall only address issues and questions related             **
    -- ** to the standard Netlist version of the core (and thus               **
    -- ** indirectly, the original core source).                              **
    -- ** Copyright (c) 2001-2013 Xilinx, Inc. All rights reserved.           **
    -- ** This copyright and support notice must be retained as part          **
    -- ** of this text at all times.                                          **
    -- Filename:        srl_fifo.vhd
    -- Description:
    -- VHDL-Standard:   VHDL'93
    -- Structure:
    --              srl_fifo.vhd
    -- Author:          goran
    -- Revision:        $Revision: 1.1.4.1 $
    -- Date:            $Date: 2010/09/14 22:35:47 $
    -- History:
    --   goran  2001-05-11    First Version
    --   KC     2001-06-20    Added Addr as an output port, for use as an occupancy
    --                        value
    --   DCW    2002-03-12    Structural implementation of synchronous reset for
    --                        Data_Exists DFF (using FDR)
    --   jam    2002-04-12    added C_XON generic for mixed vhdl/verilog sims
    --   als    2002-04-18    added default for XON generic in SRL16E, FDRE, and FDR
    --                        component declarations
    --     DET     1/17/2008     v4_00_a
    --     - Incorporated new disclaimer header
    -- Naming Conventions:
    --      active low signals:                     "*_n"
    --      clock signals:                          "clk", "clk_div#", "clk_#x"
    --      reset signals:                          "rst", "rst_n"
    --      generics:                               "C_*"
    --      user defined types:                     "*_TYPE"
    --      state machine next state:               "*_ns"
    --      state machine current state:            "*_cs"
    --      combinatorial signals:                  "*_com"
    --      pipelined or register delay signals:    "*_d#"
    --      counter signals:                        "*cnt*"
    --      clock enable signals:                   "*_ce"
    --      internal version of output port         "*_i"
    --      device pins:                            "*_pin"
    --      ports:                                  - Names begin with Uppercase
    --      processes:                              "*_PROCESS"
    --      component instantiations:               "<ENTITY_>I_<#|FUNC>
    library IEEE;
    use IEEE.std_logic_1164.all;
    library unisim;
    use unisim.all;
    entity SRL_FIFO is
      generic (
        C_DATA_BITS : natural := 8;
        C_DEPTH     : natural := 16;
        C_XON       : boolean := false
      port (
        Clk         : in  std_logic;
        Reset       : in  std_logic;
        FIFO_Write  : in  std_logic;
        Data_In     : in  std_logic_vector(0 to C_DATA_BITS-1);
        FIFO_Read   : in  std_logic;
        Data_Out    : out std_logic_vector(0 to C_DATA_BITS-1);
        FIFO_Full   : out std_logic;
        Data_Exists : out std_logic;
        Addr        : out std_logic_vector(0 to 3) -- Added Addr as a port
    end entity SRL_FIFO;
    architecture IMP of SRL_FIFO is
    attribute DowngradeIPIdentifiedWarnings: string;
    attribute DowngradeIPIdentifiedWarnings of IMP : architecture is "yes";
      component SRL16E is
          -- pragma translate_off
        generic (
          INIT : bit_vector := X"0000"
          -- pragma translate_on
        port (
          CE  : in  std_logic;
          D   : in  std_logic;
          Clk : in  std_logic;
          A0  : in  std_logic;
          A1  : in  std_logic;
          A2  : in  std_logic;
          A3  : in  std_logic;
          Q   : out std_logic);
      end component SRL16E;
      component LUT4
        generic(
        port (
          O  : out std_logic;
          I0 : in  std_logic;
          I1 : in  std_logic;
          I2 : in  std_logic;
          I3 : in  std_logic);
      end component;
      component MULT_AND
        port (
          I0 : in  std_logic;
          I1 : in  std_logic;
          LO : out std_logic);
      end component;
      component MUXCY_L
        port (
          DI : in  std_logic;
          CI : in  std_logic;
          S  : in  std_logic;
      end component;
      component XORCY
        port (
          LI : in  std_logic;
          CI : in  std_logic;
          O  : out std_logic);
      end component;
      component FDRE is
        port (
          Q  : out std_logic;
          C  : in  std_logic;
          CE : in  std_logic;
          D  : in  std_logic;
          R  : in  std_logic);
      end component FDRE;
      component FDR is
        port (
          Q  : out std_logic;
          C  : in  std_logic;
          D  : in  std_logic;
          R  : in  std_logic);
      end component FDR;
      signal addr_i       : std_logic_vector(0 to 3);
      signal buffer_Full  : std_logic;
      signal buffer_Empty : std_logic;
      signal next_Data_Exists : std_logic;
      signal data_Exists_I    : std_logic;
      signal valid_Write : std_logic;
      signal hsum_A  : std_logic_vector(0 to 3);
      signal sum_A   : std_logic_vector(0 to 3);
      signal addr_cy : std_logic_vector(0 to 4);
    begin  -- architecture IMP
      buffer_Full <= '1' when (addr_i = "1111") else '0';
      FIFO_Full   <= buffer_Full;
      buffer_Empty <= '1' when (addr_i = "0000") else '0';
      next_Data_Exists <= (data_Exists_I and not buffer_Empty) or
                          (buffer_Empty and FIFO_Write) or
                          (data_Exists_I and not FIFO_Read);
      Data_Exists_DFF : FDR
        port map (
          Q  => data_Exists_I,            -- [out std_logic]
          C  => Clk,                      -- [in  std_logic]
          D  => next_Data_Exists,         -- [in  std_logic]
          R  => Reset);                   -- [in std_logic]
      Data_Exists <= data_Exists_I;
      valid_Write <= FIFO_Write and (FIFO_Read or not buffer_Full);
      addr_cy(0) <= valid_Write;
      Addr_Counters : for I in 0 to 3 generate
        hsum_A(I) <= (FIFO_Read xor addr_i(I)) and (FIFO_Write or not buffer_Empty);
        MUXCY_L_I : MUXCY_L
          port map (
            DI => addr_i(I),                  -- [in  std_logic]
            CI => addr_cy(I),               -- [in  std_logic]
            S  => hsum_A(I),                -- [in  std_logic]
            LO => addr_cy(I+1));            -- [out std_logic]
        XORCY_I : XORCY
          port map (
            LI => hsum_A(I),                -- [in  std_logic]
            O  => sum_A(I));                -- [out std_logic]
        FDRE_I : FDRE
          port map (
            Q  => addr_i(I),                  -- [out std_logic]
            CE => data_Exists_I,            -- [in  std_logic]
            D  => sum_A(I),                 -- [in  std_logic]
      end generate Addr_Counters;
      FIFO_RAM : for I in 0 to C_DATA_BITS-1 generate
        SRL16E_I : SRL16E
          generic map (
            INIT => x"0000")
          port map (
            CE  => valid_Write,             -- [in  std_logic]
            D   => Data_In(I),              -- [in  std_logic]
            Clk => Clk,                     -- [in  std_logic]
            A0  => addr_i(0),                 -- [in  std_logic]
            A1  => addr_i(1),                 -- [in  std_logic]
            A2  => addr_i(2),                 -- [in  std_logic]
            A3  => addr_i(3),                 -- [in  std_logic]
            Q   => Data_Out(I));            -- [out std_logic]
      end generate FIFO_RAM;
    -- INT_ADDR_PROCESS
    -- This process assigns the internal address to the output port
      INT_ADDR_PROCESS:process (addr_i)
      begin   -- process
        Addr <= addr_i;
      end process;
    end architecture IMP;
    -- axi_bram_ctrl_funcs.vhd
    -- (c) Copyright [2010 - 2013] Xilinx, Inc. All rights reserved.
    -- This file contains confidential and proprietary information
    -- of Xilinx, Inc. and is protected under U.S. and
    -- international copyright and other intellectual property
    -- laws.
    -- DISCLAIMER
    -- This disclaimer is not a license and does not grant any
    -- rights to the materials distributed herewith. Except as
    -- otherwise provided in a valid license issued to you by
    -- Xilinx, and to the maximum extent permitted by applicable
    -- law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
    -- WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
    -- AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
    -- BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
    -- INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
    -- (2) Xilinx shall not be liable (whether in contract or tort,
    -- including negligence, or under any other theory of
    -- liability) for any loss or damage of any kind or nature
    -- related to, arising under or in connection with these
    -- materials, including for any direct, or any indirect,
    -- special, incidental, or consequential loss or damage
    -- (including loss of data, profits, goodwill, or any type of
    -- loss or damage suffered as a result of any action brought
    -- by a third party) even if such damage or loss was
    -- reasonably foreseeable or Xilinx had been advised of the
    -- possibility of the same.
    -- CRITICAL APPLICATIONS
    -- Xilinx products are not designed or intended to be fail-
    -- safe, or for use in any application requiring fail-safe
    -- performance, such as life-support or safety devices or
    -- systems, Class III medical devices, nuclear facilities,
    -- applications related to the deployment of airbags, or any
    -- other applications that could lead to death, personal
    -- injury, or severe property or environmental damage
    -- (individually and collectively, "Critical
    -- Applications"). Customer assumes the sole risk and
    -- liability of any use of Xilinx products in Critical
    -- Applications, subject only to applicable laws and
    -- regulations governing limitations on product liability.
    -- THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
    -- PART OF THIS FILE AT ALL TIMES.
    -- Filename:        axi_bram_ctrl_funcs.vhd
    -- Description:     Support functions for axi_bram_ctrl library modules.
    -- History:
    -- JLJ      2/1/2011         v1.03a
    --  Migrate to v1.03a.
    --  Plus minor code cleanup.
    -- JLJ      2/16/2011      v1.03a
    --  Update ECC size on 128-bit data width configuration.
    -- JLJ      2/23/2011      v1.03a
    --  Add MIG functions for Hsiao ECC.
    -- JLJ      2/24/2011      v1.03a
    --  Add Find_ECC_Size function.
    -- JLJ      3/15/2011      v1.03a
    --  Add REDUCTION_OR function.
    -- JLJ      3/17/2011      v1.03a
    --  Recode Create_Size_Max with a case statement.
    -- JLJ      3/31/2011      v1.03a
    --  Add coverage tags.
    -- JLJ      5/6/2011      v1.03a
    --  Remove usage of C_FAMILY.
    --  Remove Family_To_LUT_Size function.
    --  Remove String_To_Family function.
    --      generics:                               "C_*"
    library IEEE;
    package axi_bram_ctrl_funcs is
      type TARGET_FAMILY_TYPE is (
                                  -- pragma xilinx_rtl_off
                                  SPARTAN3,
                                  VIRTEX4,
                                  VIRTEX5,
                                  SPARTAN3E,
                                  SPARTAN3A,
                                  SPARTAN3AN,
                                  SPARTAN3Adsp,
                                  SPARTAN6,
                                  VIRTEX6,
                                  VIRTEX7,
                                  KINTEX7,
                                  -- pragma xilinx_rtl_on
                                  RTL
      -- function String_To_Family (S : string; Select_RTL : boolean) return TARGET_FAMILY_TYPE;
      -- Get the maximum number of inputs to a LUT.
      -- function Family_To_LUT_Size(Family : TARGET_FAMILY_TYPE) return integer;
      function Equal_String( str1, str2 : STRING ) RETURN BOOLEAN;
      function log2(x : natural) return integer;
      function Int_ECC_Size (i: integer) return integer;
      function Find_ECC_Size (i: integer; j: integer) return integer;
      function Find_ECC_Full_Bit_Size (i: integer; j: integer) return integer;
      function Create_Size_Max (i: integer) return std_logic_vector;
      function REDUCTION_OR (A: in std_logic_vector) return std_logic;
      function REDUCTION_XOR (A: in std_logic_vector) return std_logic;
      function REDUCTION_NOR (A: in std_logic_vector) return std_logic;
      function BOOLEAN_TO_STD_LOGIC (A: in BOOLEAN) return std_logic;
    end package axi_bram_ctrl_funcs;
    library IEEE;
    use IEEE.numeric_std.all;
    package body axi_bram_ctrl_funcs is
    -- Function:    Int_ECC_Size
    -- Purpose:     Determine internal size of ECC when enabled.
    function Int_ECC_Size (i: integer) return integer is
    begin
    --coverage off
        if (i = 32) then
            return 7;   -- 7-bits ECC for 32-bit data
                        -- ECC port size fixed @ 8-bits
        elsif (i = 64) then
            return 8;
        elsif (i = 128) then
            return 9;   -- Hsiao is 9-bits for 128-bit data.
        else
            return 0;
        end if;
    --coverage on
    end Int_ECC_Size;
    -- Function:    Find_ECC_Size
    -- Purpose:     Determine external size of ECC signals when enabled.
    function Find_ECC_Size (i: integer; j: integer) return integer is
    begin
    --coverage off
        if (i = 1) then
            if (j = 32) then
                return 8;   -- Keep at 8 for port size matchings
                            -- Only 7-bits ECC per 32-bit data
            elsif (j = 64) then
                return 8;
            elsif (j = 128) then
                return 9;
            else
                return 0;
            end if;
        else
            return 0;
            -- ECC data width = 0 when C_ECC = 0 (disabled)
        end if;
    --coverage on
    end Find_ECC_Size;
    -- Function:    Find_ECC_Full_Bit_Size
    -- Purpose:     Determine external size of ECC signals when enabled in bytes.
    function Find_ECC_Full_Bit_Size (i: integer; j: integer) return integer is
    begin
    --coverage off
        if (i = 1) then
            if (j = 32) then
                return 8;
            elsif (j = 64) then
                return 8;
                return 16;
            else
                return 0;
            end if;
        else
            return 0;
        end if;
    --coverage on
    end Find_ECC_Full_Bit_Size;
    -- Function:    Create_Size_Max
    -- Purpose:     Create maximum value for AxSIZE based on AXI data bus width.
        return std_logic_vector is
    variable size_vector : std_logic_vector (2 downto 0);
    begin
        case (i) is
            when 32 =>      size_vector := "010";           -- 2h (4 bytes)
            when 64 =>      size_vector := "011";           -- 3h (8 bytes)
            when 128 =>     size_vector := "100";           -- 4h (16 bytes)
            when 256 =>     size_vector := "101";           -- 5h (32 bytes)
            when 512 =>     size_vector := "110";           -- 5h (32 bytes)
            when 1024 =>    size_vector := "111";           -- 5h (32 bytes)
    --coverage off
            when others =>  size_vector := "000";           -- 0h
    --coverage on
        end case;
        return (size_vector);
    end function Create_Size_Max;
    -- Function:    REDUCTION_OR
    -- Purpose:     New in v1.03a
    function REDUCTION_OR (A: in std_logic_vector) return std_logic is
    variable tmp : std_logic := '0';
    begin
        for i in A'range loop
           tmp := tmp or A(i);
        end loop;
        return tmp;
    end function REDUCTION_OR;
    -- Function:    REDUCTION_XOR
    -- Purpose:     Derived from MIG v3.7 ecc_gen module for use by Hsiao ECC.
    --              New in v1.03a
    function REDUCTION_XOR (A: in std_logic_vector) return std_logic is
    begin
           tmp := tmp xor A(i);
      end loop;
      return tmp;
    end function REDUCTION_XOR;
    -- Function:    REDUCTION_NOR
    -- Purpose:     Derived from MIG v3.7 ecc_dec_fix module for use by Hsiao ECC.
    --              New in v1.03a
    function REDUCTION_NOR (A: in std_logic_vector) return std_logic is
    begin
           tmp := tmp or A(i);
      end loop;
      return not tmp;
    end function REDUCTION_NOR;
    -- Function:    BOOLEAN_TO_STD_LOGIC
    --              New in v1.03a
    function BOOLEAN_TO_STD_LOGIC (A : in BOOLEAN) return std_logic is
    begin
       if A = true then
           return '1';
       else
           return '0';
       end if;
    end function BOOLEAN_TO_STD_LOGIC;
    function LowerCase_Char(char : character) return character is
    begin
    --coverage off
        -- If char is not an upper case letter then return char
        if char < 'A' or char > 'Z' then
          return char;
        end if;
        -- Otherwise map char to its corresponding lower case character and
        -- return that
        case char is
          when 'A'    => return 'a'; when 'B' => return 'b'; when 'C' => return 'c'; when 'D' => return 'd';
          when 'E'    => return 'e'; when 'F' => return 'f'; when 'G' => return 'g'; when 'H' => return 'h';
          when 'I'    => return 'i'; when 'J' => return 'j'; when 'K' => return 'k'; when 'L' => return 'l';
          when 'M'    => return 'm'; when 'N' => return 'n'; when 'O' => return 'o'; when 'P' => return 'p';
          when 'Q'    => return 'q'; when 'R' => return 'r'; when 'S' => return 's'; when 'T' => return 't';
          when 'U'    => return 'u'; when 'V' => return 'v'; when 'W' => return 'w'; when 'X' => return 'x';
          when 'Y'    => return 'y'; when 'Z' => return 'z';
          when others => return char;
        end case;
    --coverage on
    end LowerCase_Char;
    -- Returns true if case insensitive string comparison determines that
    -- str1 and str2 are equal
    function Equal_String ( str1, str2 : STRING ) RETURN BOOLEAN IS
      CONSTANT len1 : INTEGER := str1'length;
      CONSTANT len2 : INTEGER := str2'length;
      VARIABLE equal : BOOLEAN := TRUE;
    BEGIN
    --coverage off
        IF NOT (len1=len2) THEN
          equal := FALSE;
        ELSE
          FOR i IN str1'range LOOP
            IF NOT (LowerCase_Char(str1(i)) = LowerCase_Char(str2(i))) THEN
              equal := FALSE;
            END IF;
          END LOOP;
        END IF;
    --coverage on
        RETURN equal;
    END Equal_String;
    -- Remove usage of String_To_Family function.
    --    function String_To_Family (S : string; Select_RTL : boolean) return TARGET_FAMILY_TYPE is
    --    begin  -- function String_To_Family
    --    --coverage off
    --        if ((Select_RTL) or Equal_String(S, "rtl")) then
    --          return RTL;
    --        elsif Equal_String(S, "spartan3") or Equal_String(S, "aspartan3") then
    --          return SPARTAN3;
    --        elsif Equal_String(S, "spartan3E") or Equal_String(S, "aspartan3E") then
    --          return SPARTAN3E;
    --        elsif Equal_String(S, "spartan3A") or Equal_String(S, "aspartan3A") then
    --          return SPARTAN3A;
    --        elsif Equal_String(S, "spartan3AN") then
    --          return SPARTAN3AN;
    --        elsif Equal_String(S, "spartan3Adsp") or Equal_String(S, "aspartan3Adsp") then
    --          return SPARTAN3Adsp;
    --        elsif Equal_String(S, "spartan6")  or Equal_String(S, "spartan6l") or
    --              Equal_String(S, "qspartan6") or Equal_String(S, "aspartan6") or Equal_String(S, "qspartan6l") then
    --          return SPARTAN6;
    --        elsif Equal_String(S, "virtex4") or Equal_String(S, "qvirtex4")
    --           or Equal_String(S, "qrvirtex4") then
    --          return VIRTEX4;
    --        elsif Equal_String(S, "virtex5") or Equal_String(S, "qrvirtex5") then
    --          return VIRTEX5;
    --        elsif Equal_String(S, "virtex6") or Equal_String(S, "virtex6l") or Equal_String(S, "qvirtex6") then
    --          return VIRTEX6;
    --        elsif Equal_String(S, "virtex7") then
    --          return VIRTEX7;
    --        elsif Equal_String(S, "kintex7") then
    --          return KINTEX7;
    --    --coverage on
    --        else
    --          -- assert (false) report "No known target family" severity failure;
    --          return RTL;
    --        end if;
    --    end function String_To_Family;
    -- Remove usage of Family_To_LUT_Size function.
    --    function Family_To_LUT_Size (Family : TARGET_FAMILY_TYPE) return integer is
    --    begin
    --    --coverage off
    --        if (Family = SPARTAN3) or (Family = SPARTAN3E) or (Family = SPARTAN3A) or
    --           (Family = SPARTAN3AN) or (Family = SPARTAN3Adsp) or (Family = VIRTEX4) then
    --          return 4;
    --        end if;
    --        return 6;
    --    --coverage on
    --    end function Family_To_LUT_Size;
    -- Function log2 -- returns number of bits needed to encode x choices
    --   x = 0  returns 0
    --   x = 1  returns 0
    --   x = 2  returns 1
    --   x = 4  returns 2, etc.
    function log2(x : natural) return integer is
      variable i  : integer := 0;
      variable val: integer := 1;
    begin
    --coverage off
        if x = 0 then return 0;
        else
          for j in 0 to 29 loop -- for loop for XST
            if val >= x then null;
            else
              i := i+1;
              val := val*2;
            end if;
          end loop;
        -- Fix per CR520627  XST was ignoring this anyway and printing a
        -- Warning in SRP file. This will get rid of the warning and not
        -- impact simulation.
        -- synthesis translate_off
          assert val >= x
            report "Function log2 received argument larger" &
                   " than its capability of 2^30. "
            severity failure;
        -- synthesis translate_on
          return i;
        end if;
    --coverage on
    end function log2;
    end package body axi_bram_ctrl_funcs;
    -- coregen_comp_defs - entity/architecture pair
    -- ** purpose.                                                            **
    -- ** Copyright (c) 2008-2013 Xilinx, Inc. All rights reserved.           **
    -- Filename:        coregen_comp_defs.vhd
    -- Version:         initial
    -- Description:
    --   Component declarations for all black box netlists generated by
    --   running COREGEN and AXI BRAM CTRL when XST elaborated the client core
    -- Structure:
    --                      -- coregen_comp_defs.vhd
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    PACKAGE coregen_comp_defs IS
    -- Start Block Memory Generator Component for blk_mem_gen_v8_3_6
    -- Component declaration for blk_mem_gen_v8_3_6 pulled from the  blk_mem_gen_v8_3_6.v
    -- Verilog file used to match paramter order for NCSIM compatibility
    component blk_mem_gen_v8_3_6
      generic (
      -- Generic Declarations
      --Device Family & Elaboration Directory Parameters:
        C_FAMILY                    : STRING  := "virtex4";
        C_XDEVICEFAMILY             : STRING  := "virtex4";
    --    C_ELABORATION_DIR           : STRING  := "";
        C_INTERFACE_TYPE            : INTEGER := 0;
        C_AXI_TYPE                  : INTEGER := 1;
        C_AXI_SLAVE_TYPE            : INTEGER := 0;
        C_HAS_AXI_ID                : INTEGER := 0;
        C_AXI_ID_WIDTH                : INTEGER := 4;
      --General Memory Parameters:
        C_MEM_TYPE                  : INTEGER := 2;
        C_BYTE_SIZE                 : INTEGER := 9;
        C_ALGORITHM                 : INTEGER := 0;
        C_PRIM_TYPE                 : INTEGER := 3;
      --Memory Initialization Parameters:
        C_LOAD_INIT_FILE            : INTEGER := 0;
        C_INIT_FILE_NAME            : STRING  := "";
        C_USE_DEFAULT_DATA          : INTEGER := 0;
        C_DEFAULT_DATA              : STRING  := "111111111";
        C_RST_TYPE                  : STRING  := "SYNC";
      --Port A Parameters:
        --Reset Parameters:
        C_HAS_RSTA                  : INTEGER := 0;
        C_RST_PRIORITY_A            : STRING  := "CE";
        C_RSTRAM_A                  : INTEGER := 0;
        C_INITA_VAL                 : STRING  := "0";
        --Enable Parameters:
        C_HAS_ENA                   : INTEGER := 1;
        C_HAS_REGCEA                : INTEGER := 0;
        --Byte Write Enable Parameters:
        C_USE_BYTE_WEA              : INTEGER := 0;
        C_WEA_WIDTH                 : INTEGER := 1;
        --Write Mode:
        C_WRITE_MODE_A              : STRING  := "WRITE_FIRST";
        --Data-Addr Width Parameters:
        C_WRITE_WIDTH_A             : INTEGER := 4;
        C_READ_WIDTH_A              : INTEGER := 4;
        C_WRITE_DEPTH_A             : INTEGER := 4096;
        C_READ_DEPTH_A              : INTEGER := 4096;
        C_ADDRA_WIDTH               : INTEGER := 12;
      --Port B Parameters:
        --Reset Parameters:
        C_HAS_RSTB                  : INTEGER := 0;
        C_RST_PRIORITY_B            : STRING  := "CE";
        C_RSTRAM_B                  : INTEGER := 0;
        C_INITB_VAL                 : STRING  := "0";
        C_HAS_ENB                   : INTEGER := 1;
        C_HAS_REGCEB                : INTEGER := 0;
        C_USE_BYTE_WEB              : INTEGER := 0;
        C_WEB_WIDTH                 : INTEGER := 1;
        --Write Mode:
        C_WRITE_MODE_B              : STRING  := "WRITE_FIRST";
        C_WRITE_WIDTH_B             : INTEGER := 4;
        C_READ_WIDTH_B              : INTEGER := 4;
        C_WRITE_DEPTH_B             : INTEGER := 4096;
        C_READ_DEPTH_B              : INTEGER := 4096;
        C_ADDRB_WIDTH               : INTEGER := 12;
      --Output Registers/ Pipelining Parameters:
        C_HAS_MEM_OUTPUT_REGS_A     : INTEGER := 0;
        C_HAS_MEM_OUTPUT_REGS_B     : INTEGER := 0;
        C_HAS_MUX_OUTPUT_REGS_A     : INTEGER := 0;
        C_HAS_MUX_OUTPUT_REGS_B     : INTEGER := 0;
        C_MUX_PIPELINE_STAGES       : INTEGER := 0;
       --Input/Output Registers for SoftECC :
        C_HAS_SOFTECC_INPUT_REGS_A  : INTEGER := 0;
        C_HAS_SOFTECC_OUTPUT_REGS_B : INTEGER := 0;
      --ECC Parameters
        C_USE_ECC                   : INTEGER := 0;
        C_USE_SOFTECC               : INTEGER := 0;
        C_HAS_INJECTERR             : INTEGER := 0;
      --Simulation Model Parameters:
        C_SIM_COLLISION_CHECK       : STRING  := "NONE";
        C_COMMON_CLK                : INTEGER := 0;
        C_DISABLE_WARN_BHV_COLL     : INTEGER := 0;
        C_DISABLE_WARN_BHV_RANGE    : INTEGER := 0
      PORT (
      -- Input and Output Declarations
      -- Native BMG Input and Output Port Declarations
      --Port A:
        CLKA                             : IN  STD_LOGIC := '0';
        RSTA                             : IN  STD_LOGIC := '0';
        ENA                              : IN  STD_LOGIC := '0';
        REGCEA                           : IN  STD_LOGIC := '0';
        WEA                              : IN  STD_LOGIC_VECTOR(C_WEA_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        ADDRA                            : IN  STD_LOGIC_VECTOR(C_ADDRA_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        DINA                             : IN  STD_LOGIC_VECTOR(C_WRITE_WIDTH_A-1 DOWNTO 0) := (OTHERS => '0');
        DOUTA                            : OUT STD_LOGIC_VECTOR(C_READ_WIDTH_A-1 DOWNTO 0);
      --Port B:
        CLKB                             : IN  STD_LOGIC := '0';
        RSTB                             : IN  STD_LOGIC := '0';
        ENB                              : IN  STD_LOGIC := '0';
        REGCEB                           : IN  STD_LOGIC := '0';
        WEB                              : IN  STD_LOGIC_VECTOR(C_WEB_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        ADDRB                            : IN  STD_LOGIC_VECTOR(C_ADDRB_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        DINB                             : IN  STD_LOGIC_VECTOR(C_WRITE_WIDTH_B-1 DOWNTO 0) := (OTHERS => '0');
        DOUTB                            : OUT STD_LOGIC_VECTOR(C_READ_WIDTH_B-1 DOWNTO 0);
      --ECC:
        INJECTSBITERR                    : IN  STD_LOGIC := '0';
        INJECTDBITERR                    : IN  STD_LOGIC := '0';
        SBITERR                          : OUT STD_LOGIC;
        DBITERR                          : OUT STD_LOGIC;
        RDADDRECC                        : OUT STD_LOGIC_VECTOR(C_ADDRB_WIDTH-1 DOWNTO 0);
      -- AXI BMG Input and Output Port Declarations
        -- AXI Global Signals
        S_AClk                         : IN  STD_LOGIC := '0';
        S_ARESETN                      : IN  STD_LOGIC := '0';
        -- AXI Full/Lite Slave Write (write side)
        S_AXI_AWID                     : IN  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_AWADDR                   : IN  STD_LOGIC_VECTOR(31 DOWNTO 0) := (OTHERS => '0');
        S_AXI_AWLEN                    : IN  STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0');
        S_AXI_AWSIZE                   : IN  STD_LOGIC_VECTOR(2 DOWNTO 0) := (OTHERS => '0');
        S_AXI_AWBURST                  : IN  STD_LOGIC_VECTOR(1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_AWVALID                  : IN  STD_LOGIC := '0';
        S_AXI_AWREADY                  : OUT STD_LOGIC;
        S_AXI_WDATA                    : IN  STD_LOGIC_VECTOR(C_WRITE_WIDTH_A-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_WSTRB                    : IN  STD_LOGIC_VECTOR(C_WEA_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_WLAST                    : IN  STD_LOGIC := '0';
        S_AXI_WVALID                   : IN  STD_LOGIC := '0';
        S_AXI_WREADY                   : OUT STD_LOGIC;
        S_AXI_BID                      : OUT  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_BRESP                    : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
        S_AXI_BVALID                   : OUT STD_LOGIC;
        S_AXI_BREADY                   : IN  STD_LOGIC := '0';
        -- AXI Full/Lite Slave Read (Write side)
        S_AXI_ARID                     : IN  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_ARADDR                   : IN  STD_LOGIC_VECTOR(31 DOWNTO 0) := (OTHERS => '0');
        S_AXI_ARLEN                    : IN  STD_LOGIC_VECTOR(8-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_ARSIZE                   : IN  STD_LOGIC_VECTOR(2 DOWNTO 0) := (OTHERS => '0');
        S_AXI_ARBURST                  : IN  STD_LOGIC_VECTOR(1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_ARVALID                  : IN  STD_LOGIC := '0';
        S_AXI_ARREADY                  : OUT STD_LOGIC;
        S_AXI_RID                      : OUT  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
        S_AXI_RDATA                    : OUT STD_LOGIC_VECTOR(C_WRITE_WIDTH_B-1 DOWNTO 0);
        S_AXI_RRESP                    : OUT STD_LOGIC_VECTOR(2-1 DOWNTO 0);
        S_AXI_RLAST                    : OUT STD_LOGIC;
        S_AXI_RVALID                   : OUT STD_LOGIC;
        S_AXI_RREADY                   : IN  STD_LOGIC := '0';
        -- AXI Full/Lite Sideband Signals
        S_AXI_INJECTSBITERR              : IN  STD_LOGIC := '0';
        S_AXI_INJECTDBITERR              : IN  STD_LOGIC := '0';
        S_AXI_SBITERR                    : OUT STD_LOGIC;
        S_AXI_DBITERR                    : OUT STD_LOGIC;
        S_AXI_RDADDRECC                  : OUT STD_LOGIC_VECTOR(C_ADDRB_WIDTH-1 DOWNTO 0)
      END COMPONENT; --blk_mem_gen_v8_3_6
    END coregen_comp_defs;
    -- axi_lite_if.vhd
    -- laws.
    -- DISCLAIMER
    -- Filename:        axi_lite_if.vhd
    -- Description:     Derived AXI-Lite interface module.
    -- Structure:
    --              axi_bram_ctrl.vhd (v1_03_a)
    --                      |-- full_axi.vhd
    --                      |   -- sng_port_arb.vhd
    --                      |   -- lite_ecc_reg.vhd
    --                      |       -- axi_lite_if.vhd
    --                      |   -- wr_chnl.vhd
    --                      |       -- wrap_brst.vhd
    --                      |       -- ua_narrow.vhd
    --                      |       -- checkbit_handler.vhd
    --                      |           -- xor18.vhd
    --                      |           -- parity.vhd
    --                      |       -- checkbit_handler_64.vhd
    --                      |           -- (same helper components as checkbit_handler)
    --                      |       -- parity.vhd
    --                      |       -- correct_one_bit.vhd
    --                      |       -- correct_one_bit_64.vhd
    --                      |   -- rd_chnl.vhd
    --                      |           -- xor18.vhd
    --                      |           -- parity.vhd
    --                      |       -- parity.vhd
    --                      |-- axi_lite.vhd
    --                      |       -- xor18.vhd
    --                      |       -- parity.vhd
    -- History:
    --      generics:                               "C_*"
    library IEEE;
    entity axi_lite_if is
      generic (
        -- AXI4-Lite slave generics
        -- C_S_AXI_BASEADDR        : std_logic_vector       := X"FFFF_FFFF";
        -- C_S_AXI_HIGHADDR        : std_logic_vector       := X"0000_0000";
        C_S_AXI_ADDR_WIDTH      : integer                := 32;
        C_S_AXI_DATA_WIDTH      : integer                := 32;
        C_REGADDR_WIDTH         : integer                := 4;    -- Address bits including register offset.
        C_DWIDTH                : integer                := 32);  -- Width of data bus.
      port (
        LMB_Clk : in std_logic;
        LMB_Rst : in std_logic;
        -- AXI4-Lite SLAVE SINGLE INTERFACE
        S_AXI_AWADDR  : in  std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
        S_AXI_AWVALID : in  std_logic;
        S_AXI_AWREADY : out std_logic;
        S_AXI_WDATA   : in  std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        S_AXI_WSTRB   : in  std_logic_vector((C_S_AXI_DATA_WIDTH/8)-1 downto 0);
        S_AXI_WVALID  : in  std_logic;
        S_AXI_WREADY  : out std_logic;
        S_AXI_BRESP   : out std_logic_vector(1 downto 0);
        S_AXI_BVALID  : out std_logic;
        S_AXI_BREADY  : in  std_logic;
        S_AXI_ARADDR  : in  std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
        S_AXI_ARVALID : in  std_logic;
        S_AXI_ARREADY : out std_logic;
        S_AXI_RDATA   : out std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        S_AXI_RRESP   : out std_logic_vector(1 downto 0);
        S_AXI_RVALID  : out std_logic;
        S_AXI_RREADY  : in  std_logic;
        -- lmb_bram_if_cntlr signals
        RegWr         : out std_logic;
        RegWrData     : out std_logic_vector(0 to C_DWIDTH - 1);
        RegAddr       : out std_logic_vector(0 to C_REGADDR_WIDTH-1);
        RegRdData     : in  std_logic_vector(0 to C_DWIDTH - 1));
    end entity axi_lite_if;
    library unisim;
    use unisim.vcomponents.all;
    architecture IMP of axi_lite_if is
      -- Signal declaration
      signal new_write_access       : std_logic;
      signal new_read_access        : std_logic;
      signal ongoing_write          : std_logic;
      signal ongoing_read           : std_logic;
      signal S_AXI_RVALID_i         : std_logic;
      signal RegRdData_i            : std_logic_vector(C_DWIDTH - 1 downto 0);
      -- Handling the AXI4-Lite bus interface (AR/AW/W)
      -- Detect new transaction.
      -- Only allow one access at a time
      new_write_access  <= not (ongoing_read or ongoing_write) and S_AXI_AWVALID and S_AXI_WVALID;
      new_read_access   <= not (ongoing_read or ongoing_write) and S_AXI_ARVALID and not new_write_access;
      -- Acknowledge new transaction.
      S_AXI_AWREADY <= new_write_access;
      S_AXI_WREADY  <= new_write_access;
      S_AXI_ARREADY <= new_read_access;
      -- Store register address and write data
      Reg: process (LMB_Clk) is
      begin
        if LMB_Clk'event and LMB_Clk = '1' then
          if LMB_Rst = '1' then
            RegAddr   <= (others => '0');
            RegWrData <= (others => '0');
          elsif new_write_access = '1' then
            RegAddr   <= S_AXI_AWADDR(C_REGADDR_WIDTH-1+2 downto 2);
            RegWrData <= S_AXI_WDATA(C_DWIDTH-1 downto 0);
          elsif new_read_access = '1' then
            RegAddr   <= S_AXI_ARADDR(C_REGADDR_WIDTH-1+2 downto 2);
          end if;
        end if;
      end process Reg;
      -- Handle write access.
      WriteAccess: process (LMB_Clk) is
      begin
            ongoing_write <= '0';
            ongoing_write <= '1';
          elsif ongoing_write = '1' and S_AXI_BREADY = '1' then
          end if;
          RegWr <= new_write_access;
        end if;
      end process WriteAccess;
      S_AXI_BVALID <= ongoing_write;
      S_AXI_BRESP  <= (others => '0');
      -- Handle read access
      ReadAccess: process (LMB_Clk) is
      begin
            ongoing_read   <= '0';
            S_AXI_RVALID_i <= '0';
            ongoing_read   <= '1';
          elsif ongoing_read = '1' then
            if S_AXI_RREADY = '1' and S_AXI_RVALID_i = '1' then
            else
              S_AXI_RVALID_i <= '1'; -- Asserted one cycle after ongoing_read to match S_AXI_RDDATA
            end if;
          end if;
        end if;
      end process ReadAccess;
      S_AXI_RVALID <= S_AXI_RVALID_i;
      S_AXI_RRESP  <= (others => '0');
      Not_All_Bits_Are_Used: if (C_DWIDTH < C_S_AXI_DATA_WIDTH) generate
      begin
        S_AXI_RDATA(C_S_AXI_DATA_WIDTH-1 downto C_S_AXI_DATA_WIDTH - C_DWIDTH)  <= (others=>'0');
      end generate Not_All_Bits_Are_Used;
      RegRdData_i <= RegRdData;             -- Swap to - downto
      S_AXI_RDATA_DFF : for I in C_DWIDTH - 1 downto 0 generate
      begin
        S_AXI_RDATA_FDRE : FDRE
          port map (
            Q  => S_AXI_RDATA(I),
            C  => LMB_Clk,
            CE => ongoing_read,
            D  => RegRdData_i(I),
            R  => LMB_Rst);
      end generate S_AXI_RDATA_DFF;
    -- laws.
    -- DISCLAIMER
    -- Filename:        checkbit_handler_64.vhd
    -- Description:     Generates the ECC checkbits for the input vector of
    --                  64-bit data widths.
    -- VHDL-Standard:   VHDL'93/02
    -- Structure:
    --                      |-- full_axi.vhd
    --                      |   -- wr_chnl.vhd
    --                      |           -- xor18.vhd
    --                      |           -- parity.vhd
    --                      |       -- parity.vhd
    --                      |   -- rd_chnl.vhd
    --                      |           -- xor18.vhd
    --                      |           -- parity.vhd
    --                      |       -- parity.vhd
    --                      |-- axi_lite.vhd
    --                      |       -- xor18.vhd
    --                      |       -- parity.vhd
    -- History:
    -- JLJ      2/2/2011         v1.03a
    --      generics:                               "C_*"
    library IEEE;
    entity checkbit_handler_64 is
      generic (
        C_ENCODE   : boolean := true;
        C_REG      : boolean := false;
        C_USE_LUT6 : boolean := true);
      port (
        Clk             : in    std_logic;
        DataIn          : in  std_logic_vector (63 downto 0);
        CheckIn         : in  std_logic_vector (7 downto 0);
        CheckOut        : out std_logic_vector (7 downto 0);
        Syndrome        : out std_logic_vector (7 downto 0);
        Syndrome_7      : out std_logic_vector (11 downto 0);
        Syndrome_Chk    : in  std_logic_vector (0 to 7);
        Enable_ECC : in  std_logic;
        UE_Q       : in  std_logic;
        CE_Q       : in  std_logic;
        UE         : out std_logic;
        CE         : out std_logic
    end entity checkbit_handler_64;
    library unisim;
    -- library axi_bram_ctrl_v1_02_a;
    -- use axi_bram_ctrl_v1_02_a.all;
    architecture IMP of checkbit_handler_64 is
      component XOR18 is
        generic (
          C_USE_LUT6 : boolean);
        port (
          InA : in  std_logic_vector(0 to 17);
          res : out std_logic);
      end component XOR18;
      component Parity is
        generic (
          C_USE_LUT6 : boolean;
          C_SIZE     : integer);
        port (
          InA : in  std_logic_vector(0 to C_SIZE - 1);
          Res : out std_logic);
      end component Parity;
     --    component ParityEnable
     --      generic (
     --        C_USE_LUT6 : boolean;
     --        C_SIZE     : integer);
     --      port (
     --        InA    : in  std_logic_vector(0 to C_SIZE - 1);
     --        Enable : in  std_logic;
     --        Res    : out std_logic);
     --    end component ParityEnable;
      signal data_chk0          : std_logic_vector(0 to 34);
      signal data_chk1          : std_logic_vector(0 to 34);
      signal data_chk2          : std_logic_vector(0 to 34);
      signal data_chk3          : std_logic_vector(0 to 30);
      signal data_chk4          : std_logic_vector(0 to 30);
      signal data_chk5          : std_logic_vector(0 to 30);
      signal data_chk6          : std_logic_vector(0 to 6);
      signal data_chk6_xor      : std_logic;
      -- signal data_chk7_a        : std_logic_vector(0 to 17);
      -- signal data_chk7_b        : std_logic_vector(0 to 17);
      -- signal data_chk7_i        : std_logic;
      -- signal data_chk7_xor      : std_logic;
      -- signal data_chk7_i_xor    : std_logic;
      -- signal data_chk7_a_xor      : std_logic;
      -- signal data_chk7_b_xor    : std_logic;
        -- Add bits for 64-bit ECC
        -- 0 <= 0 1 3 4 6 8 10 11 13 17 19 21 23 25 26 28 30
        --      32 34 36 38 40 42 44 46 48 50 52 54 56 57 59 61 63
      data_chk0 <= DataIn(0) & DataIn(1) & DataIn(3) & DataIn(4) & DataIn(6) & DataIn(8) & DataIn(10) &
                   DataIn(11) & DataIn(13) & DataIn(15) & DataIn(17) & DataIn(19) & DataIn(21) &
                   DataIn(23) & DataIn(25) & DataIn(26) & DataIn(28) & DataIn(30) &
                   DataIn(32) & DataIn(34) & DataIn(36) & DataIn(38) &
  10. #130
    Points: 32,415, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,494
    32,415
    43
    Posting that much code in a syntax window is ridiculous nobody is going to want to scroll through 1631 lines of code to look for one signal, that is not even in the posted code (I had to copy the code to a text editor). If you have this much code to post zip the code and add it as an edaboard attachment.
