Results 1 to 2 of 2
    Newbie level 6
    Points: 453, Level: 4
    Dec 2017
    Pune, Maharashtra, India
    12
    453
    Issue in flashing code with P89V51RD2 and SST89E516RD
    Hello all,
    I am currently using the P89V51RD2 microcontroller from NXP. I am programming this controller using the Flash Magic tool. And it is working fine. But when I brought the new same controller I am unable to flash the code using Flash magic. One of the new controllers is having success in reading the Device ID and Manufacturing ID but I am unable to flash my .hex file.
    This same scenario happens with the SST89E516RD. I am unable to flash the code in newly brought controllers. I am using SSTFlashFlex51 Rev 6.0 tool for flashing the code in SST microcontrollers.
    Please let me know if anyone can help me with this.
    -Rohit
    Points: 81,036, Level: 69
    Apr 2014
    16,433
    81,036
    69
    Re: Issue in flashing code with P89V51RD2 and SST89E516RD
    You need a multi channel scope to check programming signals (including RESET) as well as power supplies...during programming.
    Check signal timing, voltage levels, ringing...
    Also check clock (frequency, levels, waveform)
    Use the exact datasheet to validate the signals.
    Besides the datasheet informations the problem may be caused by wiring and/or PCB layout, or incomplete circuit, like missing power supply decoupling capacitors.
