Results 1 to 5 of 5
    Points: 10,044, Level: 23
    d123's Avatar
    Jun 2015
    1,759
    10,044
    23
    Help understanding solar battery use
    Battery: 12V DC, 125Ah. It says 'deep discharge' on the sticker.
    DC to ~230V AC inverter: It says 1200W/2500W on the sticker. I assume 1200W is for 230V AC and 2500W for 120V AC.
    Can someone please tell me battery duration with the examples below of what can be powered at 230V AC and for how many hours when the battery is fully charged?
    e.g.
    A laptop that uses 1.6A at 230V AC
    A 600W, 230V AC vacuum cleaner
    A 30W, 230V AC soldering iron: how many hours can each be powered, theoretically?
    I don't trust my own guesstimates much as they must be wrong and would appreciate input from someone who knows the formulas.
    Many thanks.
    Points: 80,975, Level: 69
    Apr 2014
    16,420
    80,975
    69
    Re: Help understanding solar battery use
    I won't do simple + - × ÷ math for you....
    Energy = power x time.
    I assume you are able to calculate the energy stored in the battery by your own.
    Now divide it by the load power to get the time.
    Multiply the time with the expected power conversion efficiency.
    is no useful value, because power factor is missing.
    Use the "actally drawn power" instead of the "rated power".
    Example: My 50W soldering iron will draw about 25W when "active" ... and even less when it's in sleep mode (when placed in the holder).
    d123's Avatar
    Jun 2015
    1,759
    10,044
    23
    Hi Klaus,
    Thank you, that helps a lot.
    Points: 83,016, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,645
    83,016
    70
    A laptop drawing 1.6A at 230V AC..... That is approximately 370W !
    You must have a very big lap d123, or at least a very hot one!
    d123's Avatar
    Jun 2015
    1,759
    10,044
    23
    Hi Brian,
    The sticker says that and then 19.5 V DC, 3.3A; the laptop is about 18 years old... Here's a fair comparison:
