Results 1 to 3 of 3
    Newbie level 1
    Points: 17, Level: 1
    Jan 2020
    17
    Properties of MIM capacitors
    I have been looking and looking, yet I've found very little detailed information on MIM capacitors.
    What is the voltage coefficient?
    What is the temperature coefficient?
    Best Regards,
    Mykrolian
    Points: 40,679, Level: 49
    Mar 2008
    USA
    6,559
    40,679
    49
    Re: Properties of MIM capacitors
    You must not have been looking at the documentation
    from any foundry that offers MIM caps on their process
    flows.
    Looking at generic information isn't all that helpful
    because the MIM cap dielectric and its location in the
    interconnect stack, hence its explicit C, parasitic C and
    R, will vary fab to fab and flow to flow.
    But generically, voltco and tempco are zero-ish because
    there is no semiconductor element - only metal (duh)
    and insulator (duh) and more metal.
    If you can find the dielectric material (usually SiO2, but
    there are others) then you can go look up the permittivity
    of the material as a function of temperature and applied
    field.
    Advanced Member level 2
    Points: 5,758, Level: 18
    Feb 2008
    558
    5,758
    18
    There are tons of data on MIM capacitors in the literature - check this paper, as an example, and its citations:
    J. A. Babcock et al., "Analog characteristics of metal-insulator-metal capacitors using PECVD nitride dielectrics," in IEEE Electron Device Letters, vol. 22, no. 5, pp. 230-232, May 2001.
    https://ieeexplore.ieee.org/abstract...pers#citations
    Voltage dependence, frequency dependence, temperture dependence - are all important for precision analog applications.
    Of course, linearity is much better for MIM structures, than for semiconductor devices.
    But, there is a great variety of materials, structures, etc. used for MIM capacitors.
    Different foundries offer different options.
    For a specific foundry, you should look at the electrical design rule manual.
    For general properties, and for general information - look at the literature (e.g., at IEEEXplore).
