Results 1 to 8 of 8
    Newbie level 2
    Points: 24, Level: 1
    Jan 2020
    24
    Freq computation without DIV instruction for 8bit MCU
    I am using 8bit MCU.
    Configuration:- Timer Capture to measure pulse width.
    S/W Computation: - Using pulse width calculate Frequency using formula - (Clock frequency/pulse width) << 2
    Problem:- The division instruction is taking 40usec which is too much overhead for the kind of application I am working on.
    Probable Remedy:- I was thinking to work out any alternative where I should not use DIV instruction and yet should be able to compute the frequency.
    Mandatory/What can't be changed:- MCU and timer capture is fixed. the clock source can be modified with prescalar.
    Any help?
    Points: 81,102, Level: 69
    Apr 2014
    16,449
    81,102
    69
    Re: Freq computation without DIV instruction for 8bit MCU
    40us?? Why that much time?
    Floating point? --> try integer solutions (what input values range, what expected calculation resolution and accuracy?)
    What microcontroller, what clock frequency, what language, libraries and compiler do you use?
    Points: 53,754, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,105
    53,754
    56
    Consider creating a lookup table. Say you want two digits of precision... Then you need an array of 100 elements. Exponents are a simple matter of reversing the sign (positive to negative, negative to positive).
    Newbie level 2
    Jan 2020
    24
    8Bit STM8S MCU, 16MHz clock, Timer clock - 250KHz, Expected freq input to the Timer Capture unit is 0-200Hz.
    I haven't used Float variables and no Math or standard libraries. C language Cosmic Compiler.
    Newbie level 2
    Jan 2020
    24
    Thought of doing that too.... but since it is low end 8bit MCU... the available RAM is only 2K... I can't afford to use LUT.
    Apr 2014
    16,449
    81,102
    69
    LUT does not neccessarily be in SRAM.
    But an integer division should be fast. But without ranges...accuracy, resolution...
  7. #7
    Points: 30,107, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,984
    30,107
    42
    Blog Entries
    9
    Your requirements are restrictive; you could consider setting timer scaler to a interval between acquisitions as a rational number power of two, so that division could be replaced by a simple right shift (>>) operation.
    For example, by setting timer period as 1,024s, the division operation can be made by right-shifting 10 digits, so if e.g 512 pulses are accounted during this time, the computed frequency is 500Hz with a reasonable resolution.
    Needless to say that a timer with the largest magnitude should be choosen; many 8 bit MCU's have either 8 and 16 bits timers available.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  8. #8
    Points: 264,236, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,168
    264,236
    100
    If you perform only 1 measurement per second, 40 ĩs division time (0.004 %) would be absolutely no issue. But I guess 1 Hz is too slow. For reasonable measurement rate and resolution, you are tied to (multi-)periode measurement method and hence need division step.
    Although the specification is incomplete (didn't mention measurement rate, resolution, minimal input frequency), I presume long unsigned (uint32) arithmetic is used here. Thus tables are hardly an option. However, if you choose a rate equal to the maximum input frequency of 200 Hz, what's the problem with spending 40 ĩs for the calculation?
