Results 1 to 7 of 7
    Newbie level 6
    Points: 251, Level: 3
    Mar 2019
    14
    251
    Power Oring Using Mosfet
    Here's the Circuit, as shown in fig1, There's Supply from adapter(9.5V DC), there's also a supply from the battery(8.4V Max). Diodes used(D1,D2) are shottky diodes, with a typical drop of (0.3V-0.5V). The problem i was facing was even though battery voltage at given point of time is less than Adapter Voltage(ADPT), At TP3, I was still getting battery Voltage.
    The issue was resolved when Implemented the same circuit with a small change(Adding a resistor RL1), as shown in fig2.
    Queries:
    1. I would want to know what was the issue with the circuit in fig1 and how did it get resolved in fig2?
    2.Is there a batter solution to the given problem ?
    Part Numbers Used:
    D1,D2 : SK85
    U4: Pmk35EP,518
    LI-Ion Battery (7.4V, 8.4V Max)
    Points: 81,053, Level: 69
    Apr 2014
    16,438
    81,053
    69
    Re: Power Oring Using Mosfet
    Without the resistor the node is called "floating". (No predictable current flow through either diode)
    The voltage of floating nodes is undetermined.
    When you measure the voltage of a floating node you get unpredictable values.
    As soon as you connect the resistor you get predictable current flow through (at least one of) the diodes. Thus you get predictable voltage of the node.
    If you write "better" then you also need to write "in regards if what".
    "Better" in your case can have a lot of meanings:
    * lower cost
    * low part count
    * least board space
    * lower power consumption
    * less voltage drop
    * higher current capability
    * fast response
    * better availability
    Points: 264,188, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,161
    264,188
    100
    The report makes no sense. According to given schematic, the MOSFET is switched off when V(ADPT) - V(out) > Vth. Assuming a threshold of 1 V, this happens already with V(ADPT) > V(bat) - 1.
    The purpose of RL is probably different, avoid inadvertent charging of V(ADPT) by diode leakage.
    Newbie level 6
    Mar 2019
    14
    251
    Better means in terms of better circuit design and stability, also would be better if its a low-cost Solution
    Points: 10,052, Level: 24
    d123's Avatar
    Jun 2015
    1,760
    10,052
    24
    Quote Originally Posted by zuirgham View Post
    Depending on current draw, a simple solution is to replace all of the PMOS + Schottkys + etc. section/circuit with a DC barrel jack, pcb mount or panel mount, the type that have three pins: one for gnd, and two for V+ (insert connector = disconnect battery from circuit, remove connector = connect battery to circuit).
    If a barrel connector is the wrong shape, there must be other types that fulfil the same connect/disconnect function, e.g. some audio jack connectors do this, too.
    Newbie level 6
    Mar 2019
    14
    251
    There is also a charging circuit present. That will not work as the battery gets disconnected when adapter is connected.
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,161
    264,188
    100
    Why are you telling this now? There's no information about a charging circuit, it's operation principle and how it's connected in your posts up to now.
    You should either tell the full complete story or omit the point.
