Results 1 to 5 of 5
    Newbie level 6
    Points: 351, Level: 4
    Jun 2018
    11
    351
    "Current adds up in phase"
    what do we mean when we say "current adds up in phase"? For a wire antenna, there's already a current arises from feed source and it causes antenna to radiate, then why we emphasize 'adds up in phase'. It sounds like we use a second source to increase the radiation. Doesn't it?
    Advanced Member level 2
    Points: 2,862, Level: 12
    Jan 2019
    523
    2,862
    12
    Re: "Current adds up in phase"
    current adds like a phasor
    if two (or more) current sources are in phase, the currents add
    sort of like constructive interference for waves
    if there are two current sources 180 degrees out of phase, they add to zero
    sort of like destructive interference for waves
    Points: 12,780, Level: 27
    Aug 2015
    Melbourne
    2,096
    12,780
    27
    if you have 2 equal currents 180 deg out of phase in a wire - the net current is zero - if there are in phase then the current is 2x - this is why knowing the phase relationship is important to an engineer ...!
    can you tell us the answer for 90 deg out of phase ...? if not learn vector addition ...
    for real power to be radiated in an antenna the volts and current must be in phase - i.e. a purely resistive load - if they are out of phase you get a voltage standing wave ( hence VSWR - R = ratio ) and less radiated power ....
    Full Member level 2
    Points: 993, Level: 7
    Jun 2018
    Turkey
    142
    993
    7
    search for Standing Wave Ratio and VSWR in an RF system; how can a Standing wave can load the line.
    Points: 10,347, Level: 24
    Feb 2007
    All over the Map.
    1,108
    10,347
    24
    A grasp of RF matters really needs an understanding of phasors and vector based mathematics. Starting there will make this more sensible or just think of it as magic.
    With RF sometimes 1+1 is 2. Sometimes 1+1 is 0. That is what makes RF so interesting.
