Results 1 to 12 of 12
    Member level 3
    Points: 1,685, Level: 9
    May 2012
    57
    1,685
    9
    three phase volt measurement using resistor network method
    hi all
    right now am designing three phase protection circuit
    for that i planned to measure the voltage using resistor net work method, herewith i had attached my circuit and my volt measuring code,
    everything working good but in sometimes the R phase connected to AN0 pin shows high reading, kindly go through my code and give your valuable suggestions.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    311
    312
    313
    314
    315
    316
    317
    318
    319
    320
    321
    322
    323
    324
    325
    326
    327
    #include "Includes.h"
    __CONFIG (DEBUGDIS & LVPDIS & BOREN & MCLRDIS& PWRTDIS & WDTDIS & INTIO ); //MCLREN
    //__CONFIG (DEBUGDIS & LVPDIS & BOREN & MCLRDIS& PWRTDIS & WDTDIS & EXTIO  ); //MCLREN
    //#define _XTAL_FREQ   20000000
    #define Tank RB7
    #define Sump RB6
    #define Auto RB0
    #define Off RB5
    #define On RB4
    #define Inc RB3
    #define Dec RB2
    #define Menu RB1
    #define Mon RC0
    #define Dry_run RC2
    #define Over_load RC1
    #define Volt_error RC5
    #define Tank_full RC6
    #define Sump_empty RC7
    #define Buzz RE2
    void Menu_Set();
    void delay(int);
    void Buzz_delay_small();
    //unsigned int GetVolt();
    unsigned int GetCurrent();
    void InitADC(void);
    float GetADCValue(unsigned char Channel );
    int GetVolt(unsigned char C );
    void GetVolt3();
    void Motor_On();
    void Motor_Off();
    //void display(unsigned int);
    void display(unsigned int disp);
    void displaycurrent(float value);
    void displayamps(unsigned int disp1);
    void InitTimer1();
    void InitTimer0();
    void Motor_amps_status();
    void Phase_seq();
    void Dry_pump();
    char temp=0;
    //unsigned int ADC_value = 0;
    int ADC_value = 0;
    int a,b,l=0,t1=0,t2=0;
    float ADC_value2 = 0, Current=0,Ol_amp=0,Dry_amp=0,Raw_Byte;
    unsigned int ADC_value1 = 0;
    unsigned int digit1, digit2, digit3,VloByte,VhiByte,Vlow,Vhigh,i,k=0;
     unsigned int Volt=220 ,Dry_time=0,Volt_R=0,Volt_Y=0,Volt_B=0,Menu_temp=0;
    char amp_temp,Dry_temp=0,pwr=0,Volt_temp=0,Seq_temp=0;
    //char Tank_temp=0,Sump_temp=0;
    //char int_temp=0;
    unsigned int temp0=0;
    unsigned max_point0 = 0;
    void main(void)
    TRISB=0xCF;
    PORTB=0xCf;
    TRISA=0xFF;
    PORTA=0x00;
    TRISC=0X00;
    //TRISD=0X00;
    PORTC=0X00;
    //PORTD=0X00;
    INTEDG=0;
    INTCON=0x00;
    GIE=1;
    PEIE=1;
    //INTE=1;
    //INTF=0;
    //RBPU=0;
    OSCCON=0x75;
    ANSELH=0x00;
    //ANSEL=0X0F;
    ANSEL=0Xff;
    //C1ON=C2ON=0;
    Auto=0;
    InitTimer1();
    InitADC();
    ADCON1  = 0x80;
    Buzz=1;
    __delay_ms(500);
    Buzz=0;
    InitLCD();                          // Initialize LCD in 4bit mode
    ClearLCDScreen();                   // Clear LCD screen
        while(1)
            ADCON1  = 0x80;
            __delay_ms(250);
            GetVolt3();
            WriteCommandToLCD(0xcc);
            display(Volt_R);
            Volt_R=Volt_R*1.732;
            Volt_Y=Volt_Y*1.732;
            Volt_B=Volt_B*1.732;
            WriteCommandToLCD(0x80);
            WriteStringToLCD("V-");
            WriteCommandToLCD(0x82);
            display(Volt_R);
            WriteCommandToLCD(0x86);
            display(Volt_Y);
            WriteCommandToLCD(0x8a);
            display(Volt_B);
            if((Volt_R>=Vhigh || Volt_R<=Vlow) || (Volt_Y>=Vhigh || Volt_Y<=Vlow) || (Volt_B>=Vhigh || Volt_B<=Vlow))
            Volt_error=1;
            Volt_temp=1;
            else
            Volt_error=0;
            Volt_temp=0;
            if(Volt_temp==1 && temp==1)
            //On=0;
            //Off=1;
            //delay(1);
            //Off=0;
            //Mon=0;
            temp=0;
            //WriteCommandToLCD(0xc0);
            //WriteStringToLCD("M-OFF");
            Motor_Off();
    void interrupt isr(void)
      if (TMR1IF)
        TMR1IF = 0;
        TMR1H    = 0x3c;
        TMR1L    = 0xb0;
        k++;
        if(k==300)
            Dry_time--;
            k=0;
        if(T0IF)
         T0IF    = 0;
         TMR0        = 6;
         l++;
    void InitTimer1()
      T1CON  = 0x31;
      TMR1IF     = 0;
      TMR1H  = 0x3c;
      TMR1L  = 0xb0;
      TMR1IE     = 1;
      INTCON     = 0x00;
      //INTCON   = 0xC0;
    void InitTimer0()
      OPTION     = 0x83;
      TMR0       = 6;
      //INTCON   = 0xA0;
      INTCON     = 0x00;
    void InitADC(void)
        //ADCON1  = 0xB0;     // amps   // Make PORTA and PORTE analog pins      // Also, Vref+ = 5v and Vref- = GND
    //  ADCON1  = 0x80;  // volt
        TRISA   = 0xff;      // Make RA5, RA3, RA2, RA1, RA0 input
        TRISE   = 0x0B;      // Make RE0, RE1 and RE2 input
        //ADCON0  = 0x81;        // Turn on the A/D Converter
    ADC_value1=0;
    ADC_value2=0;
    ADC_value=0;
    ADCON0  = 0x81;
                    ADCON0 &= 0xc7;         // Clear Channel selection bits
                    ADCON0 |= (C<<2); // Select channel pin as ADC input
                    __delay_us(50);         // Time for Acqusition capacitor
                                            // to charge up and show correct value
                    GODONE  = 1;            // Enable Go/Done
                    while(GODONE);        // Wait for conversion completion
                    ADC_value= ((ADRESH<<8)+ADRESL);   // Return 10 bit ADC value
    return  ADC_value;
    void GetVolt3()
    max_point0 = 0;
          for(i=0;i<1000;i++)
              //ADCON0 = 0b00000001;
              if(temp0 = GetVolt(0),temp0>max_point0)  //find the peak point
                 max_point0 = temp0;
            Volt_R=max_point0*1.16;
    max_point0 = 0;
          for(i=0;i<1000;i++)
              if(temp0 = GetVolt(1),temp0>max_point0)  //find the peak point
                 max_point0 = temp0;
            Volt_Y=max_point0*1.145;
    max_point0 = 0;
          for(i=0;i<1000;i++)
              if(temp0 = GetVolt(4),temp0>max_point0)  //find the peak point
                 max_point0 = temp0;
            Volt_B=max_point0*1.089;
    void displaycurrent(float value)              // Assume value = 123.456
           a = value;              // a = 123
          value = (value - (float)a) * (10);       // value = 45.6
           b = a;              // b = 45
          displayamps(a);
           WriteDataToLCD('.');
            b = value;
                WriteDataToLCD(b+0x30);
          //displayamps(b);
        digit1 = (unsigned int)(disp/100);                                   // Calculate digit1 of ADC_value
            digit2 = (unsigned int)((disp - digit1*100)/10);                         // Calculate digit2 of ADC_value
            digit3 = (unsigned int)(disp - (digit1*100+digit2*10));          // Calculate digit3 of ADC_value
            //digit4 = (unsigned int)(disp - (digit1*1000+digit2*100+digit3*10));    // Calculate digit4 of ADC_value
            WriteDataToLCD(digit1+0x30);        // Display digit1 of ADC_value on LCD
            WriteDataToLCD(digit2+0x30);        // Display digit2 of ADC_value on LCD
            WriteDataToLCD(digit3+0x30);        // Display digit3 of ADC_value on LCD
            //WriteDataToLCD(digit4+0x30);      // Display digit4 of ADC_value on LCD
    void delay(int x)
    for(i=0;i<x;i++)
    __delay_ms(1000);
    __delay_ms(1);
    Buzz=1;
    __delay_ms(100);
    Buzz=0;
    Points: 81,162, Level: 69
    Apr 2014
    16,461
    81,162
    69
    Re: three phase volt measurement using resistor network method
    327 lines of undocumented code. Thanks for this riddle.
    You want us to find the error around "AN0" but there is no "AN0" in your code.
    "Three phase" makes me assume you talk about "AC" .... then you talk about "shows high reading"
    * is it logic level HIGH?
    * or high DC analog voltage?
    * or is it high calculated AC amplitude?
    We don't know about: the used microcontroller, schematic, compiler....
    --> give useful and complete informations.
    Member level 3
    May 2012
    57
    1,685
    9
    hi Klausst
    thanks for your reply.
    i ill tell you clearly am going to sense Three phase AC voltage using resistor divider method,
    Three phases say R Y B am converting high voltage AC to controller accepted voltage using resistor network and then i fed into PIC16f887 RA0(Rphase), RA1(Yphase), RA5(B phase)
    Phases Y and B are giving correct value but the trouble is in R phase which is connected to microcontroller Pin RA0( ADC input 0). some time its gives correct value say 415, but in sometimes the values goes upto 520 like that and after some time its shows the correct value...
    if there is and bug in my code kindly give your suggestion. i ill post the voltage measuring code here.... and also i attached the circuit in my previous post.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    void main(void)
    TRISB=0xCF;
    PORTB=0xCf;
    TRISA=0xFF;
    PORTA=0x00;
    TRISC=0X00;
    //TRISD=0X00;
    PORTC=0X00;
    //PORTD=0X00;
    INTEDG=0;
    INTCON=0x00;
    GIE=1;
    PEIE=1;
    //INTE=1;
    //INTF=0;
    //RBPU=0;
    OSCCON=0x75;
    ANSELH=0x00;
    //ANSEL=0X0F;
    ANSEL=0Xff;
    //C1ON=C2ON=0;
    Auto=0;
    InitTimer1();
    InitADC();
    ADCON1  = 0x80;
    Buzz=1;
    __delay_ms(500);
    Buzz=0;
        while(1)
            ADCON1  = 0x80;
            __delay_ms(250);
            GetVolt3();
            display(Volt_R);
            display(Volt_R);
            display(Volt_Y);
            display(Volt_B);
    void InitADC(void)
    ADC_value1=0;
    ADC_value2=0;
    ADC_value=0;
    ADCON0  = 0x81;
    return  ADC_value;
    void GetVolt3()
    max_point0 = 0;
          for(i=0;i<1000;i++)
                 max_point0 = temp0;
    max_point0 = 0;
          for(i=0;i<1000;i++)
                 max_point0 = temp0;
    max_point0 = 0;
          for(i=0;i<1000;i++)
                 max_point0 = temp0;
    Points: 264,335, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,192
    264,335
    100
    I don't see a specific reason in the code for getting outliers in the first channel.
    Determining the absolute maximum of instantaneous voltage is however a poor method to measure AC voltage. A simple reason might be that the input voltage is actually distorted, or there can be crosstalk on the PCB.
    I would try with a low pass filter, e.g. 100 nF in parallel to 3.3k voltage divider resistor.
    Member level 3
    May 2012
    57
    1,685
    9
    hi FvM
    thanks for your reply...
    the problem not comes all the times but some time only in first channel rest of the channel are ok...
    i ill add a low pass filter and check it again....
    Apr 2014
    16,461
    81,162
    69
    I guess the problem is in the schematic.Maybe floating inputs (digital or analog), noisy supply voltage, noisy reference voltage, unsuitable anti aliasing filters, pushing negative voltages into analog pins...all this is explained in datasheets and application notes)
    But all in all, the code is a very dirty solution...and I guess schematic and PCB layout, too.
    * Either learn to design mire clean solutions (there are more than enough tutorials, code examples, descriptions, forum threads, videos...available)
    * or accept dirty results
  7. #7
    Advanced Member level 2
    Points: 2,908, Level: 12
    Jan 2019
    529
    2,908
    12
    like KlausST said your code is undocumented
    (except in a few places, where is is redundant)
    you need to document your code because:
    it makes it a lot easier to help
    a few weeks after the project is done, you won't remember
    what you did, so you'll have to re-invent the whole thing
    so a change can be made
    you can pass it on to a newbie for maintenance
    you're stuck with this project forever and can't move on to
    something new and better
    there is no such thing as Dilberts holy Grail of programming -
    10,000 lines of spaghetti logic -it won't take long for management
    to get frustrated and fire you
  8. #8
    Member level 3
    May 2012
    57
    1,685
    9
    hi wwfeldman
    thanks for your wordings ! i will improve myself quickly....
  9. #9
    Advanced Member level 3
    Points: 3,607, Level: 14
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    This is wrong.
    casting to 16-bit variable needed.
    ADRESH is a 8-bit register.
    It is better if you use INT0 to detect ZC of Phase R and then after ZC is detected you start reading the phase voltages.
    Also, you cannot and should not feed AC voltage with negative part to PIC ADC input pins. Level shift the AC signal to so that the scaled AC signal doesn't have any negative part and it should vary between 0 to 5V DC. If nominal voltage is 440V then make scaled 2.5V = 440V AC voltage.
    My method of Phase voltage reading for your PIC is not so good because there is only one INT0 pin and you can only detect ZC of any one phase with it without using any external logic gates. The problem is then you have to use a timer interrupt to detect the ZC of other 2 Phases but the ZC will vary based on mains frequency and when that happens you will not get precise voltage readings.
    I have done a 3-Phase voltage measurement using PIC18F46K22 which has 3 INTx pins and I have used them with 3 ZCD circuits and I start measuring the voltages on ZCs based upon mains frequency. I, however, assume that at all times the frequency of all the phases will be the same.
    Your circuit modified to handle 500Vrms max for the Phase voltages. +5V DC Offset obtained from PIC's 5V Power Supply.
    Initially, I designed the 3x ZCD circuits for PIC18F46K22 for my Pump Starter Cum Automatic Water Level Controller but later modified it for you. You can either use the 3x ZCD circuits and XOR gates to get the ZC signal or just one ZCD say ZC_R circuit to get the ZC signal without XOR gates.
    In the XOR circuit, the high-to-low of ZC signal gives the zero crossings of the ZC_R signal.
    My previous circuit (PDF file) had issues related to ADC input voltage.
    I have fixed it. Here is the new circuit. You can use it. It handles max 500Vrms.
  10. #10
    Member level 3
    May 2012
    57
    1,685
    9
    hi baileychic
    First of all i would like to say Thanks for your wonderful effort for me... i really appreciate your works..
    ya there is some problem in my code and my hardware too... but unfortunately the pcb design over and i got 110 nos of pcb, i could not able to modify the PCB right now, but i will made some changes in my code and i use it for rightnow ! later i ill consider your suggestion and i ill work in bread board and i ill update here..
  11. #11
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    Your
    void GetVolt3()
    code is not good. It tries to find the peak value of voltages but that is only good for sinusoidal voltage. If your voltage is distorted due to load then you will not get the correct voltage readings.
  12. #12
    Member level 3
    May 2012
    57
    1,685
    9
    hi to all
    thanks for your support
    now the problem is solved previously i used 5% resistor and now i changed to 1% resistor now am getting the correct voltage on lcd..
    am going to test the unit with load connected... i ill update the result once testing completed...
