- Joined
- Apr 1, 2011
- Messages
- 15,162
- Helped
- 2,898
- Reputation
- 5,808
- Reaction score
- 2,977
- Trophy points
- 1,393
- Location
- Minneapolis, Minnesota, USA
- Activity points
- 113,548
* As wind generator installers are aware, winds are stronger at increased altitude. A heli-craft needs to be able to counteract these effects. It must not be carried away from the tether.
It should present minimal drag so wind gusts don't push it around as much.
Suppose a 30 mph breeze is at tether altitude. Your craft must remain stationary which means it needs to perform the equivalent of flying level at 30 mph. It also needs to be able to stop rotating if that were to begin. There may be an advantageous to mounting one or two propellers so they blow horizontally.
* For test flights you might wish to install on-board batteries so that an emergency landing is possible in case of tether separation.
Consider what pattern of support you'll construct for this amount. Does it require extraordinary effort? Difficult calculations? Struts attached at peculiar angles? Etc.
A 4x4 grid seems reasonable. That accommodates 13 motors, and gives you space at the center for a payload.
