Results 1 to 3 of 3
    Junior Member level 2
    Points: 1,623, Level: 9
    Oct 2011
    Singapore
    23
    1,623
    9
    DFT Reset Constraints Handling in Spyglass DFT SGDC
    Hi all,
    I have a problem in defining RESETs in Spyglass DFT flow. Can any body point to me the correct way of defining the Resets in the flow.
    Junior Member level 3
    Points: 1,007, Level: 7
    Jun 2015
    26
    1,007
    7
    Re: DFT Reset Constraints Handling in Spyglass DFT SGDC
    Have you tried using below for defining resets in Spyglass DFT?
    reset -name "scan_rstn" -value 0
    test_mode -name "scan_rstn" -value 1 -scanshift'
    Hope it helps!
    -Shalin
    Oct 2011
    Singapore
    23
    1,623
    9
    Thanks Shalin.
    The below update has been done in SGDC, it helped in shift violations but not in capture violations.
    Still I am getting violations in Capture - "Reset/Set to XXX flops is not controlled in Capture Mode"
    Reset Scheme is as below -
    IO --> PAD --> Scan Mux --> Flop
    Now I have defined the constraints as below -
    reset -name "PAD.scan_rstn" -value 0
    test_mode -name "PAD.scan_rstn" -value 1 -scanshift'
    Still the issue in Capture Mode persists.
    Quote Originally Posted by shalin mandiwala View Post
    Hope it helps!
    -Shalin
