Junus2012
attached is the transient pic of the fully differential amplifier I have designed,
if you look to the vo+ and vo- you will see the sparks on it, however the differential coltage is clear due to the subtraction,
my question, should I be concirned about the individual outputs or only have to look to the differential output (Vo_diff)
thank you
thank you
