Results 1 to 11 of 11
    Junior Member level 3
    Points: 1,700, Level: 9
    Jun 2011
    26
    1,700
    9
    Antenna Setup in different configuration
    I am trying a 2 cases setup like this where there will be 2 horn antenna facing each other and S parameter data will be extracted.
    For the 2nd case using the similar setup there will be a large metal plate in the middle of the line of sight of horn antenna. I should expect antenna with metal plate, the S parameter value should be very different as metal plate will block almost everything to propagate from antenna 1 to antenna 2 or vice versa.
    Horn_Ant_1.zip
    However, I am getting similar response for both cases. Is there any design issues that I am missing?Click image for larger version.
    Last edited by swadesh07; 9th January 2020 at 23:30. Reason: upload simulation file
    Points: 34,903, Level: 45
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Sep 2007
    Richmond Hill, ON, Canada
    6,734
    34,903
    45
    Blog Entries
    7
    Re: Antenna Setup in different configuration
    Is the plate is thin and floating?
    A best design is easily achieved with good test specs™
    A better question deserves a better answer. ™
    ... so include all your acceptance criteria ( values, % tolerance) and assumptions in your question or any design.
    ... Tony Stewart EE since 1975
    - slightly north of Toronto
    Jun 2011
    26
    1,700
    9
    Quote Originally Posted by SunnySkyguy View Post
    Yes plate is thin and has been kept at the middle of two antennas.
    Points: 263,483, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,036
    263,483
    100
    Yes, s21 and s12 should be considerably different, most frequencies blocked with some resonances.
    Points: 34,275, Level: 45
    Oct 2001
    4,894
    34,275
    45
    You have placed a solid sheet at 42.5cm from each horn antenna. This is in the far field of the antennas, horn antennas which have the low cut-off at about 6.7GHz (lamda = 4.4cm).
    To see a difference in S21, use instead of the undefined solid sheet, a solid copper plate with some thickness.
    The plate dimensions should be bigger than the distance of 42.5cm.
    Also you can place the copper plate not in the middle, but closer to one of the horn antennas.
    Jun 2011
    26
    1,700
    9
    This is not anisotropic setup, so why should S12 and S21 will be different? What metal plate should do to block transmitted signal from both antenna with respect to free space transmission.
    Quote Originally Posted by vfone View Post
    Thanks. Understood. But why the thickness should be important, practically a thin metal is enough to block S12 and S21 from antennas. In my opinion thickness should not be very important because all we need to care about skindepth and GHz range which is very low. What I did in Ansys to define this metal as IE region and assign some finite conductivity. It worked.
  7. #7
    Oct 2001
    4,894
    34,275
    45
    What do you mean thin metal? Your undefined solid sheet doesn't have ANY thickness.
    You need a real material with some thickness to be able to see changes in transmissions of radiowaves. Or to define the sheet with finite conductivity (how you mentioned above), but this is a kind of theoretical behavior and not real life one.
  8. #8
    Jun 2011
    26
    1,700
    9
    I define sheet with finite conductivity and assign IE region for that.
  9. #9
    Full Member level 2
    Points: 965, Level: 7
    Jun 2018
    Turkey
    141
    965
    7
    Quote Originally Posted by swadesh07 View Post
    I think your sheet does not cover the whole main lobe of your antenna pattern. It may sound cheeky but try using a bigger plate with thickness enough to attenuate it enough.
    And are you doing this in an anechoic chamber?
  10. #10
    Jun 2011
    26
    1,700
    9
    Thanks @ktr
    Yes, for practical measurement, I am using anechoic chamber and I am trying to simulate the same setup in HFSS as well.
  11. #11
    Sep 2007
    6,734
    34,903
    45
    Blog Entries
    7
    Unless the plate is low impedance grounded, it will appear transparent
