Interpreting Timing Diagram of Encoder
curious_mind
Full Member level 4
I was going through SICK absolute encoder **broken link removed**. Referring to page No 7, timing diagram depicts that for 30 bits resolution, 33 clock pulses needs to be sent to retrieve position information. Is that right?
Always use the datasheet directly from the manufacturer, they are most up to date.
It depicts 34 clock cycles.
* 1 start (before the data: H-L-H cycle)
* 30 data
* 3 error
I agree, but what would happen if we transmit less no of pulses say 30 for data
