Results 1 to 13 of 13
    Advanced Member level 3
    Points: 3,607, Level: 14
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    Automatic Water Level Controller - Dynamic Dry-Run and OverLoad Current Calc Related
    I am doing a automatic water level controller using PIC18F46K22 which also monitors mains voltage and pump current and controls the Pump.
    I thought it is better to implement dynamic dry-run and overload current calculation method. So, Can I implement this method in the code?
    Target = 2-HP Pump, 1-Phase, 220V, 50Hz
    https://www.google.com/search?q=Hors...hrome&ie=UTF-8
    2 HP = 1471W
    Lets take 1500W for calculation purpose as it will be easier.
    1500W/220V = 6.8181A nominal pump current
    Dry-Run Current = nominal current - 20% of nominal current
    Overload Current = nominal current + 20% of nominal current
    Dry-Run Current = 6.8181A - (6.8181A * 20 / 100) = 5.4545A
    Overload Current = 6.8181A + (6.8181A * 20 / 100) = 8.1818A
    20/100 = 0.2 (this is known that is 20% value)
    1500W is known
    Voltage is known by measuring through ADC
    Current is known as measured through ADC
    What I want is a an equation to find out
    dynamic dry-run and overload currents that is when mains voltage supplied to pump varies then current also varies and so I need to get dry-run and overload currents in run-time.
    So, how to do that?
    Should I find out dynamic power from voltage and pump currents and then calculate?
    	mainsVoltageMeasuredInRunTime * pumpCurrentMeasuredInRunTime = pumpPowerInWatts
    	pumpPowerInWatts / mainsVoltageMeasuredInRunTime = pumpRunTimeNominalCurrent
    	pumpRunTimeDryRunCurrent = pumpRunTimeNominalCurrent - (20% pumpRunTimeNominalCurrent)
    	pumpRunTimeOverloadCurrent = pumpRunTimeNominalCurrent + (20% pumpRunTimeNominalCurrent)
    Is the above method correct?
    Points: 24,855, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,760
    24,855
    38
    Re: Automatic Water Level Controller - Dynamic Dry-Run and OverLoad Current Calc Rela
    I think you also need to consider power factor.
    Points: 53,787, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,108
    53,787
    56
    When starting up your motor is likely to draw several more Amperes than it does during normal running.
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    Yes, I am considering 7 times nominal current and so 6A * 7 = 42A and so I am using a 50A type ACS758 sensor. Is my method correct?
    How to use the Power Factor in the calculation?
    barry's Avatar
    Mar 2005
    California, USA
    4,760
    24,855
    38
    Points: 13,929, Level: 28
    nandhu015's Avatar
    Feb 2006
    India
    1,964
    13,929
    28
    Blog Entries
    18
    In my opinion, Dry run current and overload current should be set by end user.
    Nandhu
  7. #7
    Points: 18,454, Level: 32
    Nov 2012
    3,269
    18,454
    32
    Looks OK.
    For dry run (pump running without pumping anything), the actual current will depend on the type of motor. For simple capacitor start induction motors, 20% will be a conservative value.
    You need to see the boilerplate.
  8. #8
    Points: 83,103, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,668
    83,103
    70
    In a simple system with one power source and one load it probably isn't necessary to take power factor into account as the measured values will change according to conditions anyway and could just be monitored. I would agree that making the '20%' user programmable and independently for dry and overload would be a good idea as these may have to be found empirically. Additionally, it might be useful to add another user programmable parameter, the 'ignore' time when power is first applied as the start current time will depend somewhat on whether it starts dry or under loaded conditions.
    If the 'normal' values are calculated, or better still actually measured, they can be treated as constants, then all the program has to do is a comparison against real time values to determine the pump status.
    In a job I did recently, I used a moving target principle, the running current was averaged over a long period (several days in this application) and deviations from normal were used to detect fault conditions rather than absolute limits.
  9. #9
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    Finished the simulation. Have to test more.
    Made a quick simulation video.
    Will make PCB Layout today and get one assembled board manufactured and do the hardware testing. I Will update this thread after hardware test is done.
  10. #10
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    Forgot to mention. My code works for mains frequency 40Hz to 80Hz.
  11. #11
    Nov 2012
    3,269
    18,454
    32
    the running current was averaged over a long period...
    Sounds a good strategy. But...
    If you see a trend (current slowly increasing or decreasing over a long period), perhaps the motor is getting overheated or due to retire...
    If you see a periodicity, perhaps the power line supply voltage is changing or something like that...
    If you see voltage or current spikes, then perhaps you have a warning...
    Data is goldmine these days.
  12. #12
    baileychic's Avatar
    Aug 2017
    719
    3,607
    14
    Why there will be voltage / current spikes ifa MOV is put in parallel across the power line? I have one but not shown in the simulation. One MOV is used across transformer primary and also across the power supply which goes to motor.
  13. #13
    Full Member level 1
    Points: 1,138, Level: 7
    May 2017
    Canada
    98
    1,138
    7
    One big problem is induction motor current does not drop much with no or light loads. The magentization current is always high. You need to measure true power to the motor to determine if it has no load.
Name:	motor power curves.PNG
