Results 1 to 16 of 16
    Points: 13,214, Level: 27
    Aug 2011
    2,618
    13,214
    27
    Writing one file into another in C++
    I have a BIN file called "some_file.bin"
    I want to copy the contents of this file to another file named : "some_file_2.bin"
    However, while copying I want to skip every 4th byte.
    For example :
    Contents of "some_file.bin" :
    0xA5 0x3 0x11 0x34 0x33 0x12 0x37 0xDE 0xCE 0x0F 0xEE 0xFF 0x77
    Contents of "some_file_2.bin" - after copying ( 0x34 , 0xDE and 0xFF weren't copied ) :
    0xA5 0x3 0x11 0x33 0x12 0x37 0xCE 0x0F 0xEE 0x77
    Can you please post an example of a C++ code that does that ?
    Points: 30,099, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,978
    30,099
    42
    Blog Entries
    9
    Re: Writing one file into another in C++
    Instead of asking for something that does exactly what you want, why don't you look for an example that makes the exact copy, and then seeks into the code for the part that scan each byte and then put there your own logic (cyclically skipping one at each four bytes) ?
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Aug 2011
    2,618
    13,214
    27
    That's exactly what I tried to do before posting.
    I found too many examples that supposedly do the same thing in many different ways. Some of them didn't even compile...
    My request is for someone on this forum to post an example that does what I described and for us to dissect the code step-by-step and learn about the nuances (compared to C).
    Points: 83,031, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,648
    83,031
    70
    1. open "some_file.bin" in input mode.
    2. create "new_file.bin" in append mode.
    3. initialize a variable as a counter.
    4. read the input file byte
    5. if the counter modulo 4 isn't zero, write the byte to the output file
    6. increment the counter.
    7. stop when you reach the end of the input file.
    8. close both files.
    The actual coding isn't much different to the list of instructions above, you should be able to work it out for yourself.
    Points: 264,156, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,155
    264,156
    100
    Presumedly the code uses a few basic file-I/O function calls and no C++ specific language elements. No good example to learn about C++.
    Aug 2011
    2,618
    13,214
    27
    betwixt,
    1. What's the C++ function that does that ?
    2. What are the other modes that a file can be opened in ?
  7. #7
    Nov 2006
    Brazil
    8,978
    30,099
    42
    Blog Entries
    9
    Quote Originally Posted by shaiko View Post
    Review fundamentals of C++ programming, it is not difficult to find any reference.
    Please chose some of them and then ask specific questions regarding the issues you cannot solve by yourself.
  8. #8
    Points: 12,785, Level: 27
    Apr 2010
    1,938
    12,785
    27
    if your task is only to skip(delete) every 4th byte and have a new bin file , use a hexeditor.
    if you have to write a program for doing the same then learn programming.
  9. #9
    Aug 2011
    2,618
    13,214
    27
    The (real) file I'm working with has 512M Bytes.
    I haven't found a hex editor that can do it efficiently (not manually).
    Although it would be a nice side effect - my immediate goal isn't to "learn programming".
    I need this modified file for a project I'm working on. You see...I'm trying to save the world.
    And with the extra 4th byte my machine won't work properly - everything will be lost.
    Hope your conscience is clear srizbf...
  10. #10
    Apr 2010
    1,938
    12,785
    27
    The size of your file not specified earlier . So hex editor is ruled out.
    ...Hope your conscience is clear srizbf...
    I am wondering how conscience is related to this .
  11. #11
    Nov 2006
    Brazil
    8,978
    30,099
    42
    Blog Entries
    9
    I did not spent much time to find a possible solution, few minutes actually, searching for tips on the Web, and added the constraint you have defined, exactly as Brian suggested above at post #4.
    FILE *fin, *fout;
    fin= fopen("some_file.bin");
    fout = fopen("some_file_2.bin");
    int skip = 4, c, idx;
    for (idx = 1; c = (getc(fin)) != EOF; ++idx)
      if (idx % skip == 0)
         putc(fout );
    fclose(fin);
    fclose(fout);
    You could save a lot of time doing the same, note it is somewhat straightfoward, don't even need to add comments to explain how it works; regardless of how familiar one is with the C++ language, it is possible to distinguish the main operations: Open both files, read each byte from one, skip each 4th byte, and record the result into another file byte per byte, just that.
    Once I did not compiled it, you should make experiments by yourself, and report specific issues you are not able to fix, it is more productive than keep posting argumentations not code related.
  12. #12
    Aug 2011
    2,618
    13,214
    27
    I tried to append (binary not string) 0x01 to the end of the existing file.
    This is my code:
    #include <iostream>
    #include <fstream>
    using namespace std ;
    int main ( )
        ofstream some_file ("some_file.bin", ios::out | ios::app | ios::binary);
        some_file << 0x01 ;
        some_file.close( );
        return 0;
    I observed the contents of the file with a HEX editor.
    I didn't see 0x01. Instead I found 0x31.
    What went wrong ?
    Thanks andre_teprom!
    I decided to do it with C++ from scratch myself. I'll use your code as basis.
    Can you help with #12 ?
  13. #13
    Nov 2006
    Brazil
    8,978
    30,099
    42
    Blog Entries
    9
    No, I never used the ofstream method, and have no idea how this works.
    BTW, why not starting with a even simplest approach, such as suggested on #11?
  14. #14
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,648
    83,031
    70
    Andre, your code example is missing the file opening modes but I think most compilers would use 'r' and 'w' by default anyway. It is C rather than C++ but should still work fine. I love C and find C++ overly long and complicated.
    Shaiko, your code in post #12 should work in principle but I suspect you actually created a single byte file with 0x01 in it rather than appending to an existing file. 0x31 is character '1' in ASCII but the program should not have done any conversion.
  15. #15
    Aug 2011
    2,618
    13,214
    27
    Why ?
    I explicitly used "ios::app"
    Doesn't this open the file in append mode ?
  16. #16
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,155
    264,156
    100
    You misunderstand the operation of fstream << operator. Without format specifier, it does decimal output, hence you see 0x31. For binary byte output, you more simply use ostream::put, or the generic C code suggested in post #11.
