Results 1 to 10 of 10
    Junior Member level 1
    Points: 168, Level: 2
    Jul 2019
    15
    168
    Pipeline: For Loop comparing Module (VHDL)
    Hi, Iḿ trying to compare 40 values from a memory array to my input data. If any of those 40 data matches to my input data I go to next state.
    Iīm using a FOR LOOP for comparing the values in one clock cycle. But it limits my Fmax clock frequency.
    How do I write a pipeline based code to check my input data with those 40 values in such a wau that increases my clock frequency?
    -> It doesnīt matter if it takes even 40 clock cycles to do the whole thing
    signal checksum_Y      : std_logic_vector(8 downto 0);
    signal y_data          : std_logic_vector(9 downto 0);
    type did_reg is array (0 to did_width-1) of std_logic_vector (9 downto 0);            --intiating inferred memory
      signal did_arr : did_reg;
        when DID_Y =>
                  checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0)) + unsigned(checksum_Y)); -- load check sum with previous checksum and current data value
                  for i in 0 to (did_width) loop                        -- Loop the did array
                    if i = did_width then                            -- If counter reaches the max amount of DID present+1 due to no DID match
                      curr_state_Y       <= IDLE_Y;                     -- jump tp next state, IDLE_Y
    					      elsif y_data = did_arr(i) then                         -- check if y_data matches with the element of the did array
                      mem_arr_Y(count_Y) <= y_data;                     -- if true, load the data to memeory
                      count_Y            <= count_Y+1;                  -- increase the memory adress counter
                      curr_state_Y       <= SDID_Y;                     -- jump to next state, SDID_Y
                      id_pair_cnt_Y      <= i;                          -- ID pair adrs counter, for SDID pair adrs
                    exit;                                             -- exit the loop when true
    					      end if;
                  end loop;
    Right now the Fmax is 141 MHz
    I want to increase it to it max value.
    Points: 264,204, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,168
    264,204
    100
    Re: Pipeline: For Loop comparing Module (VHDL)
    Incomplete specification. What about the compare value, is it expected to change during processing?
    If not, you don't need a pipeline, just a sequential process that steps through all memory addresses, one per clock cycle.
    If it changes at arbitrary times, you need to put the compare value into a pipeline register array. And you get a multidimensional state array.
    Points: 38,244, Level: 47
    Jun 2010
    6,922
    38,244
    47
    First of all, you have only provided a code snippet, not the whole code. You don't show libraries or the process so we can only assume it's a synchronous process.
    If you're happy with multiple clocks for the search, remove the for loops and use a counter instead. Currently it does all compares in parallel with the lowest index match getting priority.
    Jul 2019
    15
    168
    Yes, I have to compare my input data(y_data) with multiple did values. And have a enable signal high as a flag to indicate a match.
    I think, a sequential process is a good option and I agree with your suggestion of multidimensional array.
    Also we need to delay the data behind the DID value, to the same no. of clock cyles .
    Could you help me with the code, too?
      type did_reg is array (0 to did_width-1) of std_logic_vector (9 downto 0);            --instiating register based array of size equal to did width generic
      type did_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
      signal did_in : did_in_delay  := (others => '0');
      type y_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
      signal y_data_delay : y_in_delay  := (others => '0');
    y_data   <= DIN(19 downto 10);
    	when DID_Y =>
         for i in did_width loop
          did_in(i) <=  y_data;
         if did_in(i) = did_array(i) then
          enable = '1';
         else
         enable = '0';
      end if;
          y_data_delay(i) <= y_data_delay(i)((y_data_delay(i)'high-1) downto 0)) & did_in(i)(i);
    end loop;
    Can you see whatīs the problem in the code?
    Jun 2010
    6,922
    38,244
    47
    The problem with the code is that it is not a complete example and you do not explain exactly what problems you're having with it.
    Jul 2019
    15
    168
    Hi, sorry for the late reply.
    Iīm trying to extract ancillary data based on their DID/SDID. Ancillarya data is found in video data, and is serial data.
    The ancillary data follows the protocol SMPTE 291M
    Format -> FLAG1 -> FLAG2 -> FLAG3 -> DID-> SDID -> DC ->UDW-> CS
    DID/SDID - DATA id
    DC -> no of UDW
    UDW -> user data words (0 to 255)
    CS -> Error bit
    I have to compare the incoming data packets DID with the one stored in the memory before. If matched then stored in the memory.
    Right now, I am comparing the incoming DID with the stored DID values by using a for loop. This reduces my clk frq.
    I want to piepline this process.
    I want to compare the input data DID value with one of the stored DID value one at a time every clk cycle. So, if there are 40 DID values to compare with, then we delay the data 40 clk cycles.
    *NOTE :- The packets are contiguous, I.E. , there is no space in between 2 packets. There can be 0 to 7 ancillary data packets in one vertical video line. A 1920x1020 has 1020 vertical video lines in one frame.
    The size of packets are varying.
    entity generic_anc_extractor is
    generic(
            did_width  : integer ;
            sdid_width : integer
    port(
      output_data_at_vcount : in integer;  --simulation specific feature. determines when to output the data.
                                           -- x=0 -> output data at last vcount of frame- default value
                                           -- 0<x -> output data at every vcount sel when hav = 1
      VIDEO_CLK    : in std_logic;
      DATA_OUT_CLK : in std_logic;
      RESET_N      : in std_logic;
      SOF          : in std_logic;
      HAV          : in std_logic;
      V_COUNT      : in std_logic_vector(10 downto 0);
      H_COUNT      : in std_logic_vector(12 downto 0);
      DIN_VALID    : in std_logic;
      DIN          : in std_logic_vector(19 downto 0);
      DIN_FORMAT   : in std_logic_vector(3 downto 0);
      DID_data     : in std_logic_vector(9 downto 0);
      SDID_data    : in std_logic_vector(9 downto 0);
      D_WR         : in std_logic;
      D_ADRS       : in std_logic_vector(log2c(did_width)-1 downto 0);
      SD_WR        : in std_logic;
      SD_ADRS      : in std_logic_vector(log2c(sdid_width)-1 downto 0);
      DOUT_OUT     : out std_logic_vector(19 downto 0);
      DATA_VALID_Y : out std_logic;
      DATA_VALID_C : out std_logic
    end generic_anc_extractor;
    architecture rtl of generic_anc_extractor is
      constant C_ADF1        : std_logic_vector(9 downto 0 ) := "0000000000"; -- 0
      constant C_ADF2        : std_logic_vector(9 downto 0 ) := "1111111111"; -- 3FF
      constant C_ADF3        : std_logic_vector(9 downto 0 ) := "1111111111"; -- 3FF
      constant main_mem_N_Y  : integer := 10000;                -- Width of the main memory, equal to max anc data to be stored
      constant main_mem_N_C  : integer := 10000;                -- Width of the main memory, equal to max anc data to be stored
      -- constant did_width     : integer := 5;
      -- constant sdid_width    : integer := 5;
      type state_extrac_y is (IDLE_Y,
                              ADF_2_Y,
                              ADF_3_Y,
                              DID_Y,
                              SDID_Y,
                              DC_Y,
                              UDW_Y,
                              CS_Y
      type state_extrac_c is  (IDLE_C,
    					               ADF_2_C,
    						             ADF_3_C,
    						             DID_C,
    						             SDID_C,
                             DC_C,
    						             UDW_C,
    						             CS_C
      signal curr_state_Y    : state_extrac_Y_1;
      signal curr_state_C      : state_extrac_C;
      signal dc_count_Y        : integer := 0;
      signal dc_count_C        : integer := 0;
      signal reg_out_Y       : std_logic_vector(9 downto 0);
      signal reg_out_C       : std_logic_vector(9 downto 0);
      signal data_count_Y    : integer := 0;                    -- count is equal to DC_Y, representing the amount of UDW_Y data
      signal checksum_Y      : std_logic_vector(8 downto 0);    -- checksum is equal to the sum of DID_Y to UDW_Y, which is then checked against CS_Y 9 bits value
      signal count_Y         : integer := 0;                    -- count for adress of the register memory
      signal cnt_Y           : integer := 0;                    -- count for writing extracted data to output port
        signal data_count_C    : integer := 0;                  -- count is equal to DC_C, representing the amount of UDW_C data
      signal checksum_C      : std_logic_vector(8 downto 0);    -- checksum is equal to the sum of DID_C to UDW_C, which is then checked against CS_C 9 bits value
      signal count_C         : integer := 0;                    -- count for adress of the register memory
      signal cnt_C           : integer := 0;                    -- count for writing extracted data to output port
      signal did_cnt         : integer := 0;                    -- DID counter
      signal sdid_cnt        : integer := 0;                    -- SDID counter
      signal id_pair_cnt_Y   : integer := 0;                    -- Counter for the pair index for DID and SDID
      signal id_pair_cnt_C   : integer := 0;
      signal last_vcount_f2  : integer := 0;                   -- returns the last value of vcount of every format of frame 2
      signal last_vcount_f1  : integer := 0;                   -- returns the last value of vcount of every format of frmae 1
      signal y_data          : std_logic_vector(9 downto 0);   -- upper 10 bits of the video stream(20-11 / 20)
      signal c_data          : std_logic_vector(9 downto 0);   -- lower 10 bits of the video stream(10-0 / 20)
      signal DATA_VALID_Y_d  : std_logic := '0';
      signal DATA_VALID_C_d  : std_logic := '0';
      type main_mem_reg_Y is array (0 to main_mem_N_Y-1) of std_logic_vector (9 downto 0);  --instiating register based main memory of max size of anc data that can be stored
      signal mem_arr_Y : main_mem_reg_Y;
      type main_mem_reg_C is array (0 to main_mem_N_C-1) of std_logic_vector (9 downto 0);  --instiating register based main memory of max size of anc data that can be stored
      signal mem_arr_C : main_mem_reg_C;
      type sdid_reg is array (0 to sdid_width-1) of std_logic_vector (9 downto 0);          --instiating register based array of size equal to sdid width
      signal sdid_arr : sdid_reg;
      -- type did_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
      -- signal did_delay : did_in_delay ;
      -- type y_in_delay is array (0 to did_width-1) of std_logic_vector(9 downto 0);
      -- signal y_delay : y_in_delay;
      -- signal did_match : std_logic;
      -- signal c : std_logic_vector(8 downto 0);
      -- signal shreg_did : std_logic_vector(9 downto 0);
      -- signal shreg_y   : std_logic_vector(9 downto 0);
    begin
    -------------------------------------------------------------------------------------Generate output data signal for extracted data from y and c data
    process(DATA_OUT_CLK)
    begin
      if rising_edge(DATA_OUT_CLK) then      -- Output of the data on the rising edge of clk given by the outer interface
        if unsigned(H_COUNT) >= 4096 then   -- check for hcount 0, start of active video
          DOUT_OUT <= reg_out_Y&reg_out_C;   -- output the extracted the data from y and c data
          DATA_VALID_Y <= DATA_VALID_Y_d;
          DATA_VALID_C <= DATA_VALID_C_d;
        end if;
      end if;
    end process;
    ---------------------------------------------------------------------------------------------Loading DID_Y/SDID_Y serially to the array
    process(VIDEO_CLK)
    begin
    if rising_edge(VIDEO_CLK) then
      if D_WR = '1' then                                              -- check for did write enable signal
        did_cnt          <= to_integer(unsigned(D_ADRS));             -- loading the did adrs to did_cnt signal
        did_arr(did_cnt) <= DID_data;                                 -- load the did in to did array according to the adress signal
      end if;
      if SD_WR = '1' then                                             -- check for did write enable signal
        sdid_cnt           <= to_integer(unsigned(SD_ADRS));          -- loading the sid adrs to sdid_cnt signal
        sdid_arr(sdid_cnt) <= SDID_data;                              -- load the did in to did array according to the adress signal
      end if;
    end if;
    end process;
    ------------------------------------------------------------------------------------Current State Logic
    --Generate reset and next state signals
    --at every clock, update the curr_state value
    --when reset,curr_state is IDLE_Y
    	generate_state: process(VIDEO_CLK)
    	begin
        y_data   <= DIN(19 downto 10);                   -- loading the upper 10 bits
          if RESET_N = '0' then
            curr_state_Y    <= IDLE_Y;                   -- default state
    		  else
            if DIN_VALID = '1' then                      -- check for data valid signal
              case curr_state_Y_1 is
    	------  -------------------------------------------------------------------------------------------------------------IDLE_Y
                when IDLE_Y =>
                  checksum_Y   <= (others=>'0');                                     -- Reset checksum value for next anc data packet
                  DATA_VALID_Y_d <= '0';
                  last_vcount_f1 <= return_vcount_active_end_f1(DIN_FORMAT);        -- last vcount of frame according to the Video Format
                  last_vcount_f2 <= return_vcount_active_end_f2(DIN_FORMAT);
                  if y_data = C_ADF1 then                                          -- check for ADF_1 - 0
    				    		curr_state_Y <= ADF_2_Y;                                       -- jump to next state when true
                  else
                     curr_state_Y <= IDLE_Y;                                       -- Jump to IDLE_Y when false
                  end if;
                  --OUTPUTTING THE EXTRACTED DATA FROM THE MEMORY
                  if output_data_at_vcount = 0 and cnt_Y< count_Y and HAV = '1' and (unsigned(V_COUNT) = last_vcount_f1 or unsigned(V_COUNT) = last_vcount_f2) then -- check for last count according to frame 1 and 2; simulation specification -> FPGA implementation, check for space in memory and active video
                        reg_out_Y    <= mem_arr_Y(cnt_Y);                         -- output data of register buffer starting from adrs 0 to the data stored in one line
                        cnt_Y        <= cnt_Y+1;                                  -- increase the adrs cnt till all the data is read from the register
                        DATA_VALID_Y_d <= '1';                                    -- Trigger signal to indicate data valid when the data is being output
                  elsif output_data_at_vcount >= 1 and unsigned(V_COUNT) > 0 and cnt_Y< count_Y and HAV = '1' then-- simulation specification -> Simulation implementation,-- output only after vcount 0, check for space in memory and active video
                  end if;
    	-----------------------------------------------------------------------------------------------------------------ADF_2_Y / ANC DATA FLAG
    				    when ADF_2_Y =>                                                     -- ADF_2_Y - 3FF
                  if y_data = C_ADF2 then                                           -- check for ADF_2_Y - 3FF
    				    		curr_state_Y <= ADF_3_Y;                                        -- jump to next state when true,ADF_3_Y
    				    	else
                  end if;
    	-----------------------------------------------------------------------------------------------------------------ADF_3_Y / ANC DATA FLAG
    				    when ADF_3_Y =>                                                     -- ADF_3_Y
                  if y_data = C_ADF3 then                                           -- check for ADF_3_Y - 3FF
    				    		curr_state_Y <= DID_Y;                                          -- jump to next state when true, DID_Y
                  else
                  end if;
                when DID_Y =>
                checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0)+checksum_Y)); -- load check sum with previous checksum and current data value
                  elsif i = did_width then                            -- If counter reaches the max amount of DID present+1 due to no DID match
                  end if;
                end loop;
    	------  -----------------------------------------------------------------------------------------------------------------SDID_Y/ SECONDARY DATA ID
                when SDID_Y =>
                checksum_Y <= std_logic_vector(unsigned(y_data(8 downto 0))+unsigned(checksum_Y));-- load check sum with previous checksum_C and current data value
                if y_data = sdid_arr(id_pair_cnt_Y then                   -- SDID array of adress of id pair cnt equal to y data
                  mem_arr_Y(count_Y) <= y_data;                            -- if true, then load the data to the memory
                  curr_state_Y       <= DC_Y;                              -- jump to next state, DC_Y
                else
                  curr_state_Y <= IDLE_Y;                                  -- if false, jump to default state, IDLE_Y
                  count_Y      <= count_Y-1;                               -- decrease the memory adres counter, to over write the data alerady written
                end if;
              -----------------------------------------------------------------------------------------------------------------DC_C/ DATA COUNT
              when DC_Y =>
                dc_count_Y       <= to_integer(unsigned(y_data(8 downto 0)));                    -- first 9 bits of the c_data, is equal to the no. of UDW_C in the packet
                checksum_Y         <= std_logic_vector(unsigned(y_data(8 downto 0))+unsigned(checksum_Y)); -- load check sum with previous checksum_C and current data value
                mem_arr_Y(count_Y) <= y_data;                                                    -- store data in memory
                count_Y            <= count_Y +1;                                                -- increase the memeory adress counter
                curr_state_Y    <= UDW_Y;                                                        --jump to next state, UDW_C
              -----------------------------------------------------------------------------------------------------------------UDW_C/ USER DATA WORDS
              when UDW_Y =>
                  if data_count_Y <= dc_count_Y then                                            -- loops the process checking if data_count_C is less than/equal to dc_count(no of UDW_C)
                    checksum_Y    <= std_logic_vector(unsigned(y_data(8 downto 0))+unsigned(checksum_Y)); -- load check sum with previous checksum_C and current data value when true
                    data_count_Y  <= data_count_Y+1;               -- data count value determines the amount of packet loaded in the memory
                    count_Y            <= count_Y+1;               -- incraese the memory adress counter
                      if data_count_Y = dc_count_Y-1 then          -- when count is equal to the no. of UDW_C. dc_count-1, because we start counting from 0
                        data_count_Y <= 0;                         -- reset count to 0, will count next from next data UDW_C
                        curr_state_Y <= CS_Y;                      -- jump to next state, CS_C when all the UDW_C is loaded
                      end if;
                  end if;
              -- -----------------------------------------------------------------------------------------------------------------CS_C/CHECKSUM
              when CS_Y =>
                if checksum_Y = y_data(8 downto 0) then             -- checks the data with the checksum_C value
                  curr_state_Y       <= IDLE_Y;                     -- jump to next state, IDLE_C when true
                  count_Y            <= count_Y +1;                 -- incraese the memory adress counter
                else
                  curr_state_Y     <= IDLE_Y;    					          -- jump to default IDLE_C, when false
                  count_Y          <= count_Y - dc_count_Y-3;       -- wrap around the adres of the register back to where it stored the 1st data of the pckt
                end if;                                             -- will overwrite the new data over the present adres
              when others => curr_state_Y <= IDLE_Y;                -- default case
              end case;
              end if; -- dvalid
            end if; -- reset
          end if; -- VIDEO_CLK
        end process;
      end process;
    You can surely ignore some unecceary comments. I've tried several designs / code, but canīt get it work.
    Can you help me in this, please.
    The code here is the original one, using the for loop for DID comparison.
  7. #7
    Jun 2010
    6,922
    38,244
    47
    dont use a for loop. Use a counter, and wait in the state until the counter is complete.
  8. #8
    Jul 2019
    15
    168
    I just can't use a counter for it.
    Reason: The input is a serial data of 10 bits each. So, I can't pause the data. And we do not want to use a buffer type system. But something more of using shifter or small array based system.
  9. #9
    Jun 2010
    6,922
    38,244
    47
    Then you could make some kind of search unit. Or increase the clock.
    Probably best to go back to your architecture/design drawing you made before you wrote the code and having a re-think on system design.
  10. #10
    Points: 32,130, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,430
    32,130
    43
    Quote Originally Posted by yashjain View Post
    These statements seem to contradict each other.
