Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
  1. #21
    Points: 83,988, Level: 70
    Apr 2014
    17,081
    83,988
    70
    Re: Ferrite bead usage in ADC's
    Go to the AD1955 site (not EVAL).
    Or just type "AD1955" into the search of analog.com and you will find "UG-48 ..."
    That's it
  2. #22
    Points: 266,464, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,572
    266,464
    100
    Isolation between AGND and DGND in the 100 MHz or even GHz range isn't but an illusion. It neither works on the PCB level, because the planes are coupled planar structures nor on the chip level, because both are implemented on a common substrate, either directly connected on chip or maximal isolated by a diffusion well.
    Separated grounds serve a purpose for power supplies or for signal circuits in the DC to 100 kHz, possibly low MHz range.
