Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
  1. #21
    Points: 6,007, Level: 18
    Jan 2012
    Italy
    1,058
    6,007
    18
    Re: Simulating the slew rate with capacitive feedback fully differential amplifier
    Why reverse?
    The bigger the C the lower the impedance.
    Usually: A = R_fb/ R_in....in your case it is: A= X_fb / X_in.....nothing reversed.
    Thanks klaus, you are right, I was confused cause in my simulation with out a resistor it was C1_fb/C1_in, but now as you explained it becomes impedance relationship
  2. #22
    Advanced Member level 3
    Points: 10,293, Level: 24
    Nov 2001
    US
    894
    10,293
    24
    It is missing the symmetry probably because you didn't simulate long enough like in your post #14. Can you run longer simulation?
    If the intended application is to build a sample and hold circuit, than you are going on a wrong path. Sample and hold circuits using OTAs are a switched capacitor circuits and then just by switching the caps in 2 phases usually, you define also the OTA input common mode. I think you should build a test bench that is closer to the application you have in mind. This cap-cap OTA you have right now is good for running .ac analysis for the S/H but not for transient simulations.
  3. #23
    Jan 2012
    Italy
    1,058
    6,007
    18
    Quote Originally Posted by sutapanaki View Post
    Dear Suta,
    I have simulated with longer time, as you expected the signals are becoming true after a while and looking fine as shown belowClick image for larger version.
    Now this issue is being cleared,
    Now I am interested in your suggestion to tun the simulation with two phases, I never tried before this kind of simulation used usually for SC circuit, could you please help to setup this test and how it looks
    Thank you
  4. #24
    Nov 2001
    US
    894
    10,293
    24
    Your amplifier right now is not suited for that. If you want to do it, you have to use the OTA in a SC configuration. As it is now with that resistor in the feedback is not quite good for S/H because you've probably noticed in your simulations that the pulses at the output droop with time because they lose charge through the capacitor.
    You could look into a flip-around S/H which is one of the not so complicated configurations. SC S/H circuits are also suitable for use with SC CMFB.
  5. #25
    Jan 2012
    Italy
    1,058
    6,007
    18
    Dear Suta,
    Thank you for your help
    I have two questions,
    1. I have designed my OTA with continuous time CMFB circuit, will it be a problem or it is only optional to design SC CMFB ?
    2. Are switches available by Cadence ?
    Thank you
  6. #26
    Nov 2001
    US
    894
    10,293
    24
    It can probably work with CT CMFB. Check it in simulation.
    What do you mean by "switches" in Cadence? Switches are transistors and transistors are available in the design kit.
  7. #27
    Jan 2012
    Italy
    1,058
    6,007
    18
    Thsnk you Suta,
    I mean ideal switches
  8. #28
    Nov 2001
    US
    894
    10,293
    24
    Yes, it is called "switch" I think in analogLib.
