Results 1 to 2 of 2
    Points: 521, Level: 4
    Mar 2018
    45
    521
    MCP3004 features 200 ksps sample rate at 5V
    Hi
    I need help to understand speed of SPI Ic MCP3004
    Features:
    10-bit resolution
    Four single-ended channels
    SPI interface
    ±1 LSB DNL
    ±1 LSB INL
    I do not understand meaning of 200 ksps sample rate at 5V. does it means mcp3004 can send one bit to slave at speed of 200 ksps ? Each bit take minimum 200 ksbs for transmission ?
    Newbie level 6
    Points: 691, Level: 5
    Aug 2016
    13
    691
    Re: MCP3004 features 200 ksps sample rate at 5V
    Look at the data sheet
    SPI runs at 3.6 MHz max (at 5V supply) and ten bits are transferred per sample.
    This gives a conservative 200,000, ten-bit samples per second
