Results 1 to 3 of 3
    Newbie level 1
    Points: 14, Level: 1
    Dec 2019
    14
    HSS Port refinement Error
    Port refinement, process hf3d error: Waveport s is internal to solution domain comes up when I try to analyze this design. Any suggested adjustments be made?
    Points: 6,959, Level: 19
    Jun 2012
    Edmonton, Canada
    1,064
    6,959
    19
    Re: HSS Port refinement Error
    Welcome uknwn123,
    Modify your bounding box such that the waveports are on its sides. As is, they are inside the domain, which is not a good idea.
    Good Luck!
    Points: 10,347, Level: 24
    Feb 2007
    All over the Map.
    1,108
    10,347
    24
    You might also try a metallic cap on the back of the port. If you are still having trouble examine the field in the plane of the port and make sure it is not detached. That is an occasional problem.
