Results 1 to 12 of 12
    Points: 13, Level: 1
    Dec 2019
    7
    13
    White residue after solder mask develope!!!
    Hello, my name is Hieu. I'm a process engineer of PCB manufacturing company.
    We have an issue about white residue on pad. When we doing solder mask and run developer. We check again see the white residue.
    Anybody have an opinions about this issue ?
    Picture below
ID:	156883 Click image for larger version.
    Points: 80,070, Level: 69
    Apr 2014
    16,253
    80,070
    69
    Re: White residue after solder mask develope!!!
    What exactly do you mean?
    Add some marks on the pictures.
    Points: 82,536, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,547
    82,536
    70
    I think they mean the uneven surface after plating, you can just see it against the gold. I suspect this is the underlying copper being uneven and the gold plating just makes it more obvious. Nothing to worry about.
    Points: 263,619, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,995
    263,619
    100
    Photo resolution is too low to see details. Would prefer a microscope photo with diffuse lighting.
    To me, the pad surface looks partly like silver metallic rather than white. What's the gold process? If it's nickel-gold, could it be that the final gold layer is damaged?
    Dec 2019
    7
    13
    Hi Klaus
    as you can see, on the Annula Ring, we have some white residue, I mark on picture below. It's happen when we do solder mask -> exposure -> cure (enough time) -> develop soldermask -> test (we find the residue at this step.
    this residue some time can be cleaned by gently wiping, some time it's can not clean and we have to remove all the solder mask and do it again. Because this white residue, when we do next step (do reflow, it's cannot be welded).
    This is the terrible issue that we have met.
    Hieu
    Dec 2019
    7
    13
    Hi Brian
    it's not the problem with the plating. As i noted above. I send you picture with a mark, picture below. You can see it's has a white residue on annular ring. The process is : Clean acid -> do Solder mask -> exposure -> cure (enough heat and times) -> develop -> test (we find the white residue at this step).
    It's very serious. because if we have this white residue, when we do next step we can not do reflow, can not be welded.
    Hieu
  7. #7
    Dec 2019
    7
    13
    Hi FvM
    Thank you for your reply. Sorry with the picture, I think it's clear enough to see the white residue. I send a picture with a mark, picture below. It's not from plating, we have no damaged with the gold plating.
    the process is : Clean with acid -> do solder mask -> exposure -> cure (with enough heat and times) -> develop -> test (we found the white residue at this step)
    this is the serious issue. Because if we have the white residue we can not do the next step ( reflow.. it's cannot be welded).
    Hieu
  8. #8
    Dec 2019
    7
    13
    picture with the mark. thank your reply
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,995
    263,619
    100
    Not at all, I fear.
  10. #10
    Apr 2014
    16,253
    80,070
    69
    Not at all, I fear.
    I have to agree.
    I see a bright - almost white part at the hole --- I think this just is the reflection of the light.
  11. #11
    Dec 2019
    7
    13
    I have to agree.
    We have many many prolem with this white residue
    it's not a bright
    You can see, that white color on the annular ring. That the white residue.
  12. #12
    Dec 2019
    7
    13
    Not at all, I fear.
    Sorry again about the picture
    But we have many many problem with this white residue . You can see, that white color on the annular ring. That the white residue.
