Results 1 to 5 of 5
    Points: 33,823, Level: 44
    Sep 2008
    cambridge
    7,025
    33,823
    44
    Half Bridge SMPS in Current Mode but with slope compensation is OK?
    Page 122 of “power supply cookbook” (2nd Ed) by Marty Brown details the design of a 280W offline Half Bridge Converter in Current mode with slope compensation.
    Current Mode is in theory not advised for Half Bridge converters due to potential imbalance of the rail splitting input capacitors.
    However, can we actually say that as long as significant slope compensation is used, then Current mode is actually fine for Half Bridge SMPS’s?
    The attached two LTspice simulations show two otherwise identical current mode Half Bridge converters. One is unstable, but the one with slope compensation is fine.
    Points: 12,331, Level: 26
    Aug 2015
    Melbourne
    2,013
    12,331
    26
    Re: Half Bridge SMPS in Current Mode but with slope compensation is OK?
    if you add a lot of slope comp, technically the ckt is no longer just current mode - but tends to be closer to voltage mode - in its control characteristics - however the amount of slope comp to allow an half bridge to operate without cap imbalance has never been computed - to my knowledge ...
    in any event the control loop will need to be a lot slower than for optimised peak current mode ...
    Points: 263,619, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,995
    263,619
    100
    I see a misunderstanding involved with the 280W Half Bridge Converter design example. MC34025 is no current mode controller. It's a voltage mode controller with additional current limit and shutdown function. The difference is obvious by the fact, that the current sense input is compared against a fixed threshold rather than the error amplifier output, see diagram below. Slope compensation may be nevertheless necessary for stable current limit operation.
    Sep 2008
    cambridge
    7,025
    33,823
    44
    Thanks, yes, on pg 127, Brown states that the controller MC34025P can be configured as either voltage mode or current mode, but Brown specifically states he is putting it into current mode.
    On page 132, Brown gives the schematic…..he has a current sense transformer….the resistor at the output of this is fed to pin9, and also to pin 7 ……he also feeds in a slope comp ramp into pin 7, which he drives from the oscillator (and he buffers it with a PNP).
    As such, Brown is indeed using it as a current mode controller with added slope
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,995
    263,619
    100
    Yes, you are right. Current mode is established by also connecting pin 7 to the current sense signal.
    The reservations about usefulness of this mode haven't been dispelled though.
