Results 1 to 11 of 11
    Junior Member level 3
    Points: 178, Level: 2
    Oct 2019
    30
    178
    Transformers on a PCB
    Hey guys!
    I've just started with electronics and I made this PCB for an amplifier which contains 2 transformers. Here's the layout (with some SMD components):
    The transformers are on the opposite side.
    This is my 2nd PCB and since this is an amplifier I wonder how the transformers affect the circuit (if it does at all). For example, look at the U1 IC which resides exactly under the transformer. Can this cause any problems? Reading the books, I think it's not going to affect anything as this is not an RF or UHF circuit. What do you think?
    (the size of the PCB is 45x45 mm).
    Thank you.
    Last edited by ads-ee; 13th December 2019 at 16:46. Reason: made image edaboard attachment
    Points: 80,070, Level: 69
    Apr 2014
    16,253
    80,070
    69
    Re: Transformers on a PCB
    It does not depend on whether your circuit produces HF or not, it depends whether your circuit reacts on HF. And this depends on what exactly U1 is.
    In either case: In times of many HF sources around (cellular phone, WiFi, bluetooth ...) Iīm more concerned that you don't use a solid GND plane.
    I expect EMC problems - independent of transformers.
    Read the U1 datasheet and look for design notes and application notes at the manufactrerīs internat pages.
    Oct 2019
    30
    178
    Thank you. I read couple of articles about this. So, here it is with the ground plane:
    Since I have a single layer board, can I make it better?
    Last edited by ads-ee; 13th December 2019 at 16:47. Reason: converted image to edaboard attachment
    Apr 2014
    16,253
    80,070
    69
    We are talking about HF. Thus this still is far away from being a GND plane.
    All the traces have the same length as before ... and for HF the width doesnīt play much a role.
    Simple method: Use double layer. Make the whole layer GND without any other traces/signals.
    Use short traces to connect each single GND line with a via to GND plane.
    Are you sure your "secret U1" has no GND connection?
    I assume the U1 connection is wrong/inclomplete. I see only one resistive connection to the other circuit, any other signals are either floating or have a capacitor in series.
    But as long as you hide most informations like part names, values, schematic, description ... itīs useless to go on guessing.
    Oct 2019
    30
    178
    Thanks for the advice!
    Well, I've never done double layer yet... I thought I'd go with the single. I have to read something about via's, maybe I'd go that route.
    U1 is just LM386. It's connected to ground via R6 and bypassing C6 (100n). Not sure why R6 is here which is just 10R.
    But I created a prototype on a prototype board and it works. But yes, it's noisy. Hopefully, because of a long long wires and ... well, prototype board.
    Apr 2014
    16,253
    80,070
    69
    No!
    Repeated:
  7. #7
    Oct 2019
    30
    178
    Yikes!!! You're right!!! Grrr... I have to change everything!
    Damn, I had everything correct on the prototype... and then screwed up the circuit in the software :/
    Fixed. That's the best I can do for now:
  8. #8
    Points: 15,212, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,528
    15,212
    29
    An LM386 is an audio amplifier, with significant gain.
    Your transformer appears to be a powerline 50/60 Hz device with an EI core. Such transformers are notorious to produce significant stray fields.
    Your audio amplifier will very likely suffer from lots of hum.
    My batteries are recharged by "Helpful Post" ratings.
  9. #9
    Oct 2019
    30
    178
    No, both transformers are audio and they're for impedance matching.
    But I was thinking to isolate them as they're on the other side of the board. I hope this will remove the hum.
  10. #10
    Points: 263,619, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,995
    263,619
    100
    The magnetic stray field of audio transformers isn't expected to cause problems in your circuit, unless it involves very high gain (e.g. G>100). If magnetic coupling occurs, it will be to trace loops, not ICs or other lumped components.
    A ground plane may be suggested or even necessary for your circuit, but the problem isn't particularly related to using transformers.
  11. #11
    Oct 2019
    30
    178
    Thank you guys for your valuable info! I had to go and read about ground plane and PCB design overall. It's not that I understand everything now but it's a good start.
    Since I can't make a double sided PCB for now, I'll go with the single side and see what I get in reality. So, this is going to be the first prototype!
