Results 1 to 5 of 5
    Points: 521, Level: 4
    Mar 2018
    45
    521
    LCD 16*2 Data Sequence Flow chart
    Good evening to all
    I am not speaking about code I want to understand communication between MCU and LCD how does microcontroller send data to LCD so I made one flow chart that explain my understanding
    I have attached PDF file and I am looking advice with my flow chart
    Points: 30,002, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,949
    30,002
    42
    Blog Entries
    9
    Re: LCD 16*2 Data Sequence Flow chart
    Have a look on datasheet pinout waveforms of the LCD you are talking about (presumably based on the HD7780 chipset) and you will have a better understanding of the whole process, it just describes what the above flowchart depitcs for example for the writing command:
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Mar 2018
    45
    521
    Quote Originally Posted by andre_teprom View Post
    RS=0; // Select the Command Register by pulling RS LOW
    RW=0; // Select the Write Operation by pulling RW LOW
    EN=1; // Send a High-to-Low Pusle at Enable Pin
    Wait = 450 ;
    Points: 263,541, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,045
    263,541
    100
    Confusing description. Actually E is pulsed high for Pweh >= 450 ns.
    E is pulsed for each byte read from or written to the LCD controller. In so far I don't understand why it's described only as prepare action in your diagram.
    Mar 2018
    45
    521
    What it should be ?
