Results 1 to 5 of 5
    Newbie level 1
    Points: 427, Level: 4
    Sep 2017
    427
    How to access Micron MT25Q nor flash
    Greeting,
    I have a project that create QUAD SPI controller for MT25QU device. I am able to access to all register of the flash, but not able to read back data from the memory. here is my procedure (assume that i am already in quad mode)
    1. Write Enable x06h
    2. Write Extended address xC5h + 00 (flash region 0)
    3. Read Memory (quad input/output fast read) xEBh + 000_0000 (24bit address)
    I am not getting right result back. I know at the begining of the flash my data is 0303, but I got back is 0xFF.
    I looked at wave form, and my wave form is closely follow Micron datasheet.
    2 clk cycle cmd
    6 clk cycle address (only use 24 bits address and 2 bits for select flash region)
    10 clk dummy cycles
    4 clk read back ( i have 2 flashes, and read 16bits from each flashes).
    Points: 80,263, Level: 69
    Apr 2014
    16,286
    80,263
    69
    Re: How to access Micron MT25Q nor flash
    A lot of text, no clear question, not much we can verify...
    Please give
    * (a link to) the datasheet
    * your code
    * the scope picture
    * schematic
    * register contents (maybe the memory device needs some setup, or there are some write/read protections active)
    Newbie level 1
    Sep 2017
    427
    Thanks for replying to the thread.
    My question: how do I access to Micron spi flash memory? Is there any procedure that I need to follow?
    datasheet: https://www.micron.com/products/nor-...12abb8e12-0sit
    the device is already set up in quad mode and verified with manID, and other flash registers.
    status register: 0x00
    flag status register: 0x80
    volatile configuration: 0xFF
    Enhanced volatile configuration register: 0x7F
    Waveform:
    -- Read manID waveform
    -- try to read data but could not get right return
    Ken
    Points: 263,501, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,039
    263,501
    100
    It's more likely that the preceding write didn't succeed.
    It's not clear how the waveforms (apparently from a simulator) are related to your microprocessor hardware.
    Newbie level 1
    Sep 2017
    427
    Hi FvM,
    I program flash with working FPGA image. the first data at 0x0000_0000 address is 303A. I tried to read data at that address and getting 0xFF.
    the wave form is the actual pin out at the FPGA. So i would assume that the FPGA did actually sending out these signal to the flash.
    Ken
