Results 1 to 8 of 8
    Newbie level 1
    Points: 16, Level: 1
    Dec 2019
    16
    750 MHz Band Attenuation Filter
    Approximate band attenuation 20 dB from 735 MHz to 765 MHz. Is microstrip pcb and lumped components a possible method to create this filter? In simplest form, a series paralleled inductor and capacitor.
    Points: 30,920, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,541
    30,920
    42
    Re: 750 MHz Band Attenuation Filter
    Lumped Components serve well here..No need Microstrip structures..
    The Simplest Form is a Parallel LC in series or a Series LC in Parallel or combination of those.But better solution is to use N-stage LC filter approximations ( Butterworth or Chebychev etc. ) then apply Bandstop Transformation.The best method is to use a Filter Design Program..
    Points: 263,617, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,057
    263,617
    100
    You need the complete pass- and stop band specification to determine the filter effort, e.g. minimal order.
    Newbie level 3
    Points: 34, Level: 1
    Cornell_Bill's Avatar
    Nov 2019
    34
    Lumped Components is a good method. No need Microstrip structures.
    Points: 34,288, Level: 45
    Oct 2001
    4,898
    34,288
    45
    Any lumped component Band Pass Filter with central frequency greater than about 500MHz would be very sensitive to component tolerances, to PCB layout, and especially to temperature variations.
    May need more space for a 750 MHz microstrip filter, but for sure you will have much less headache designing and manufacturing it.
    Points: 14,752, Level: 29
    Apr 2014
    2,300
    14,752
    29
    Actually, I like to combine both discrete and line elements at these frequencies. But as FvM mentioned, without full specs it's not possible to estimate anything.
  7. #7
    Points: 53,567, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,068
    53,567
    56
    Series LC usually has some amount of neighboring resistance also in series. It reduces Q.
    LC tank has maximum Q due to slight R. It's easier to achieve narrow bandwidth.
    Bandwidth is affected by the L:C ratio. These 3 layouts are identical except for having different LC ratios.
Name:	band-stop LC tank reson f 750 MHz ident 3 layouts exc diff LC ratios sine sweep.png
    To choose a value, 50 ohms is assumed for input and output resistance.
  8. #8
    Apr 2014
    2,300
    14,752
    29
    Quote Originally Posted by BradtheRad View Post
    Your inductors have different Q factor.
