Results 1 to 5 of 5
    Member level 5
    Points: 975, Level: 7
    Mar 2017
    93
    975
    7
    Power amplifier design (grounding)
    Regarding the power amplifier design in ADS. How to do the with DC power supply & transistor grounding in layout window? and also during PCB fabrication process. Is it just replacing with Viaground which will be as hole in the layout?Click image for larger version.
    Points: 30,910, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,539
    30,910
    42
    Re: Power amplifier design (grounding)
    Before all, have you ever considered Decoupling Capacitors placed juts after Lambda/4 Transmission Lines ?? You will have to place and be sure that they will change amplifier's response very much.
    Use realistic models and take the parasitics into account..
    You can consider GND connections being as multiple VIAs in parallel.There are VIA models in ADS Component Palette..
    Member level 5
    Mar 2017
    93
    975
    7
    Quote Originally Posted by BigBoss View Post
    Thank you for your response. For decoupling capacitors, do you mean those ones?Click image for larger version.
Name:	Sample proposal design.png
    For grounding, Do you think that just replacing each ground with 1 Via ground, then during the fabrication drill a hole for each one will be sufficient?
    Member level 5
    Mar 2017
    93
    975
    7
    How to calculate the parasitics of the decoupling capacitors?
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,539
    30,910
    42
    Quote Originally Posted by Mabrok View Post
    You don't have to calculate the parasitics.Install the DK of -for instance Murata-supplier for ADS then place appropriate capacitor onto your circuit.The model will include all parasitic elements of the capacitor.
