Results 1 to 5 of 5
    Junior Member level 1
    Points: 130, Level: 1
    Aug 2019
    15
    130
    Two Qs re: resistance
    Not sure if the answer depends on the circuit, or if this is a rule that will apply across the board?
    So, I get that a resistor will limit the flow of current in the circuit.
    I have a circuit with a 10k resistor, and let's say I add to that a 4.7k resistor. I believe this to be called 'piggybacking'?
    1. Is that considered series, or parallel?
    2. Why is the amount of current now decreased? To my complete newbie brain, there should be more resistance; to me, there is now 14.7k of resistance (+ or - a bit, due to tolerance). But apparently, there is now 5.3k of resistance. Why is that?
    Thanks in advance.
    Advanced Member level 3
    Points: 10,077, Level: 24
    Nov 2001
    US
    873
    10,077
    24
    Re: Two Qs re: resistance
    If the two resistors have one terminal in common, then it is series connection and current will reduce if the voltage across the series connection stays the same as it was when only one resistor was connected.
    If the two resistors have two terminals in common, then it is parallel connection and under the same circumstances as above, the current will increase.
    Points: 263,329, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    Where did you get 5.3k? Resistance of parallel circuit is 10*4.7/(10+4.7) = 3.2k.
    Aug 2019
    15
    130
    Quote Originally Posted by sutapanaki View Post
    Ok, that helps.
    Well, where I get 5.3 is this: 10k - 4.7k = 5.3k
    But I see that's not the way it works. :)
    Thanks guys!
    Points: 18,428, Level: 32
    Nov 2012
    3,267
    18,428
    32
    Each resistor has two ends. It is a symmetrical device in the sense that you can exchange the two ends without ANY effect.
    Let us label the two ends of resistor R1 as E1 and E2. Same way label the two ends of resistor R2 as E3 and E4.
    If you connect E2 to E3 and keep the two free ends E1 and E4, you get s series connection. In a series connection, both resistors takes the same current (consider current like a fluid).
    If you connect E1 to E3 and also connect (independently) E2 to E4, and use the two ends (E1E3 junction and E2E4 junction) you get a combination that is called parallel (the two resistors are now lying side by side).
    In a parallel connection, both the resistors see the same voltage (but take different currents).
    In a series connection, the equivalent resistance is greater than the individual values. In a parallel connection, the equivalent resistance is smaller than the individual values.
