Results 1 to 7 of 7
    Points: 462, Level: 4
    May 2018
    34
    462
    Wrong simulation for VP0808 mosfet?
    In this simulation (I am using multisim 14.0), the output voltage value (measured from XMM1) multimeter is:
    ~0V when S1 is on VDD
    ~0V when S1 is on GND
    3.3V when S1 is on VSS
Name:	Annotazione 2019-12-08 215310.png
    But, if I make this circuit on Breadboard whit a real VP0808, it do not faithful to simulation (I have 3.3V when S1 is on GND).
    Is it a simulator error?
    Points: 263,329, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    Re: Wrong simulation for VP0808 mosfet?
    Do you understand the meaning of Vgs(th) specification in datasheet, particularly the wide threshold voltage range?
    May 2018
    34
    462
    If I understand well, for P-MOSFET, the Vgs should be less than Vth:
    Vgs < Vth
    When I connect my gate to Vdd I have Vgs = 0V
    When I connect the gate to GND, Vgs = -3.3V
    When I connect the gate to Vss, Vgs = -6.6V
    It is correct?
    In this case, my Spice model have than VTO = -3.55V. If I connect gate to GND, the Vgs < Vth is false and I have 0V to drain pin.
    May 2018
    34
    462
    Can anyone help me, please?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    I thought you already answered the question yourself. You have explained the simulation result, the real MOSFET has apparently much lower threshold voltage, well possible according to the datasheet.
    May 2018
    34
    462
    Yes, OK.
    I would like to get a behavior like the one described by the simulator, in particular that the mosfet does NOT lead when Vgs is equal to GND.
    So I should choose a MOSFET with a fairly high Vth. Could you suggest such a component?
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    Max. Vgs,th of 4.5V of VP0808 is relative high, you probably won't find any devices with Vgs,th,min > 3.3V.
