Results 1 to 11 of 11
    Points: 518, Level: 4
    Jun 2018
    53
    518
    How many devices can we have on SPI?
    Hi
    Could any one help me please
    How many slave devices can be connected to spi bus?
    Points: 80,159, Level: 69
    Apr 2014
    16,271
    80,159
    69
    Re: How many devices can we have on SPI?
    Theretically infinite.
    * each one needs a unique /CS signal
    * you need to consider bus capacitance and dtive strength of each device....or use buffers, MUX, selectors....
    Advanced Member level 2
    Points: 3,123, Level: 13
    Aug 2016
    548
    3,123
    13
    Also, you will be limited by the complexity in connection and routing that comes with increased number of slave devices. The traces too are going to.get longer as slave devices increase.
    --Akanimo.
    Advanced Member level 3
    Points: 6,478, Level: 19
    Feb 2014
    931
    6,478
    19
    As others have said as many as you want but SPI doesn't scale that well since you (typically) need individual CS lines for each device. Though SPI GPIO expanders could be used to help address this.
    I2C with its addressing scheme scales better. Two lines gets up to 128 devices (though also bus C limited).
    Points: 18,428, Level: 32
    Nov 2012
    3,267
    18,428
    32
    I was under the impression that the number is 255 (256 with zero excluded).
    Full Member level 4
    Points: 3,754, Level: 14
    Feb 2007
    INDIA
    238
    3,754
    14
    I2C is again a separate topic. 127 is theoretical limit. Practically it depends on each device capacitance, speed of the Interface.
    Is it a general question.
    If it is question related to your design, you can post some design parameters like Max speed, devices etc
    For SPI there is no defined standard like I2C, Protocol, number of lines, sampling points everything can be varied.
  7. #7
    Feb 2014
    931
    6,478
    19
    Quote Originally Posted by c_mitra View Post
    The read/write bit reduces the address to 7 bits.
  8. #8
    Nov 2012
    3,267
    18,428
    32
    I should have checked before posting. Thanks anyway
  9. #9
    Junior Member level 1
    Points: 95, Level: 1
    Nov 2019
    London
    15
    95
    It depends on a number of slave select lines on the hardware. Example: If my SPI master has 4 slave select lines then we can connect 4 slaves normally.
  10. #10
    Apr 2014
    16,271
    80,159
    69
    I agree.
    Or 16 (with additional master /SS line) --> and two HC138
    or 15 without additional master /SS line --> and two HC138
    or 8 with included ( in the 4) master /SS line --> one HC138
  11. #11
    Newbie level 1
    Points: 20, Level: 1
    Dec 2019
    20
    I agree. You should have checked.
