Results 1 to 19 of 19
    Newbie level 6
    Points: 53, Level: 1
    Dec 2019
    12
    53
    Capacitor as a MOSFET in RC Circuit
    hi every body
    I have a resistor-capacitor circuit that I fitted with MOSFET and want the MOSFET capacitor to phase shift.
    Unfortunately, as much as I could increase the amount of this capacitor by increasing the transistor w and l and parallelizing several transistors, I saw no phase difference.
    I don't know where my problem is!
    Maybe the wrong way to build the capacitor with MOSFETM is wrong
    Can anyone help me?
    Points: 81,102, Level: 69
    Apr 2014
    16,449
    81,102
    69
    Re: Capacitor as a MOSFET in RC Circuit
    Before you design .... you should do some considerations and calculations.
    What are your expected R and C values?
    What's the input waveform?
    And what phaseshift (in time) do you expect?
    Newbie level 6
    Dec 2019
    12
    53
    650/5000
    I want to implement a capacitor with MOSFET, which creates a phase difference between the input sinusoidal signal and the output of the circuit. But unfortunately whatever I do, there is no fuzzy difference.
    I increased the capacitance as much as possible by increasing and transistor and parallelizing several transistors but no fuzzy difference.
    What solution would you offer if I wanted to make a phase shift with MOSFET?
    My goal is to change the amplitude and phase of the output sine signal relative to the input. I want the output phase of the circuit to be controllable.
    For example, I have both a 2 degree phase and a 2 and .....
    In general, I want to change the amplitude of the variable resistance signal I make with MOSFET and the circuit phase with MOSFET capacitor.
    Newbie level 6
    Dec 2019
    12
    53
    sine wave and input frequency 20hz-20khz
    capacitor value is about 10ps
    Is it possible for the MOSFET capacitor to be several microns or more?
    Points: 18,454, Level: 32
    Nov 2012
    3,269
    18,454
    32
    Maybe the wrong way to build the capacitor with MOSFETM is wrong...
    You are right here.
    Mosfet cannot do anything by itself; it does what it is supposed to do. Usually you tell it what to do by giving a voltage to the gate.
    Please provide a diagram with input and output clearly specified. It will be helpful if you also tell what you wanted it to do and what it is actually doing.
    Points: 53,754, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,105
    53,754
    56
    There is such a thing as a capacitance multiplier. Is that what you made?
    Test your RC network by applying a wide variety of frequencies.
    Somewhere in the middle is a frequency range which brings out capacitor behavior. You get attenuation and corresponding phase change.
    Outside that frequency range, signal is either unchanged or unobservable, and likewise is phase change.
    There are chaser and oscillator circuits, built from 3 stages of RC networks. Each stage contributes a certain amount of phase shift. It might help if you compare your project to them.
  7. #7
    Newbie level 6
    Dec 2019
    12
    53
    Thanks for your guide
    My goal is to use RC series circuits to change the different phases. But the problem is that when I replace the capacitor and the resistance of the MOSFET the circuit is not working properly ......
    Last edited by BradtheRad; 8th December 2019 at 04:18. Reason: Deleted duplicated text -kept correct spelling of RC series circuits
  8. #8
    Apr 2014
    16,449
    81,102
    69
    secret circuits
    secret values
    secret informations ...
    We want to help, but how do you think we can help this way?
  9. #9
    Points: 12,924, Level: 27
    Aug 2015
    Melbourne
    2,118
    12,924
    27
    Only the gate to source gives you a usable capacitance ( unless you have a J-fet ) if you use D-S the cap will be dominated by the channel resistance, depending on what you let the gate do ...
    Using mosfets as variable caps is a bad idea - look up "vari-cap" this is much closer to what you are seeking I think ...
  10. #10
    Newbie level 6
    Dec 2019
    12
    53
    no no no
    im so sorry
    I mean RC series circuits, not secret!
    it was a mistake type....
    Last edited by BradtheRad; 8th December 2019 at 06:25. Reason: two posts in quick succession
  11. #11
    Apr 2011
    13,105
    53,754
    56
    Quote Originally Posted by forouzanb View Post
    2 degree phase
    The mosfet has an insulated gate with very high resistance. Try calculating the R*C time constant and it tells you what fast frequency you need to apply, in order to reveal capacitor action.
    In the audio frequency range it is typical to use capacitor values in uF units (micro-Farads), or tens of uF, or hundreds of uF.
    Anyway, 2 degree phase difference is very hard to observe. When applying sinewave to a capacitor, in all circumstances there is a 90 degree phase difference between current through it and voltage across it. Do you have a dual-trace scope? Try to devise a setup so you can observe it. Then there may be a way to adapt it to work with a mosfet model in simulation, perhaps after setting an exaggerated capacitance value in the gate fabrication.
  12. #12
    Newbie level 6
    Dec 2019
    12
    53
    Thanks for your kind explanations
    What formula and values of the phase difference did you calculate when it was 2 degrees?
    Because I'm with a pico capacitor and a 1k resistor, the frequency of 1 Hz that I calculate is about 90 degrees.
  13. #13
    Newbie level 6
    Dec 2019
    12
    53
    The common-DRAIN transistor has a no phase difference between input and input. Is there a way to make a phase difference between the input and output signal?
    For example, by increasing the capacity of the gate-source capacitor?
    I parallel to 20 common-drain transistors and increased the w and l in 90 nano technology and was able to increase the capacitance of the gate-source from femto to pico. If I have a series RC backbone with the same values, I see a 90 degree phase difference between the input and output.
    So why not let this happen when I replace MOSFET with capacitor in rc with same value?
    What do you think is the reason?
  14. #14
    Apr 2011
    13,105
    53,754
    56
    Simulation showing action of RC in series with source. Various amounts of phase shift are portrayed.
    Green waveform is voltage. Yellow is current. Current is always in phase with output voltage as measured across resistor.
Name:	demo capacitor phase shift (RC high pass) sine sweep 100-1000 Hz.png
    Source voltage is not in phase with current through the system. At higher frequencies the output is affected less. It's just about in phase with the source, and nearly the same amplitude (97 percent). The phase difference is visible on the scope traces.
    With 3 percent amplitude difference it calculates to 14 degrees of phase advance. (This suggests how difficult it is to detect a phase advance of 2 degrees.)
    Notice at low frequencies the phase difference approaches 90 degrees.
    If we reverse the positions of R & C then we get phase delay. This may or may not be the same principle at work in your setup.
  15. #15
    Newbie level 6
    Dec 2019
    12
    53
    Well I want to use a MOSFET in a RC circuit instead of a capacitor, the MOSFET itself being the capacitor itself should give an input signal, the model I used for the Gate Source Capacitor is in common-DRAIN and you can look at its shape.Click image for larger version.
  16. #16
    Points: 264,236, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,168
    264,236
    100
    You originally asked about MOSFET acting as capacitor, now you switched to common drain amplifier. It's time to clarify the topic and show a schematic of what you are trying to achieve.
    Your RC circuit on the right is a high pass, the common drain amplifier isn't due to the MOSFET transconductance which generates a low output impedance.
    Please review the equivalent circuit of common drain amplifier in circuit design text books. See e.g. example from Grey, Hurst, Lewis, Meyer, Analysis and Design of Analog Integrated Circuits.
Name:	source follower schematic.PNG
Name:	source follower.PNG
  17. #17
    Newbie level 6
    Dec 2019
    12
    53
    So how can I make a capacitor with the MOS transistor? What should I connect to the transistor mounts to act as a capacitor for phase difference?What should it be bias and where should region it work?
    So far I think if we connect MOSFET anyway, it will become a capacitor
    How does a Mosset become a capacitor in general?
  18. #18
    Nov 2012
    3,269
    18,454
    32
    Do you want a circuit using a MOSFET that does simulate a capacitor? What is the frequency range and the voltage specification?
    I presume there are plenty of active capacitor circuits on the internet. But you may miss some of the features.
  19. #19
    Newbie level 6
    Dec 2019
    12
    53
    Yes, exactly, the sine input signal with the frequency range of 20 Hz to 20 KHz
    plz help me
