Page 4 of 4 FirstFirst ... 2 3 4
Results 61 to 70 of 70
  1. #61
    Points: 12,951, Level: 27
    Aug 2015
    Melbourne
    2,124
    12,951
    27
    Re: 1.5kw DC to DC Boost Converter Circuit
    yes, a snubber is an R in series with a cap.
  2. #62
    Aug 2015
    Melbourne
    2,124
    12,951
    27
    Yes
    output diodes, on my secondary side of transformer of the bridge rectifier?
    output diodes are typically those diode on the output side of the transformer ...
  3. #63
    Points: 205, Level: 2
    Dec 2019
    36
    205
    Mosfets got burnt again after connecting snubber circuit.
  4. #64
    Aug 2015
    Melbourne
    2,124
    12,951
    27
    how are you heatsinking the fets?
  5. #65
    Dec 2019
    36
    205
    I have all the mosfets on a large heat sink and all of them insolated with mica from the heat sink, but after putting the snubbers on they did Not even run to get hot. It's almost like they just shorted or got shoot through. I think the ringing I'm worried about is not to bad without the snubbers.
    I've had it running like that for a while on 800 to 1000 watt and everything was looking normal. Heat sink got up to 45 degrees Celsius.
    I'll post another scope reading once I have it running to see if I should be worried.
  6. #66
    Aug 2015
    Melbourne
    2,124
    12,951
    27
    Mica and thermal paste is not rated for more than 100V, so check the insulation to the heat-sink in case you knocked it and things got shorted out ...
    Also check the snubber ckt is connected from Drain to Source ( not gate ) --/\/\/\/\-----|| ---- in series ...
    and that the snubber caps are rated high enough in volts - and the resistors are big enough not to go short ...
  7. #67
    Dec 2019
    36
    205
    This is what I meant with the ringing, and should I add snubbers to this.
  8. #68
    Aug 2015
    Melbourne
    2,124
    12,951
    27
    I wouldn't worry about that too much - - is that the gate drive ... ?
  9. #69
    Dec 2019
    36
    205
    Yes, it's the gate drive.
  10. #70
    Aug 2015
    Melbourne
    2,124
    12,951
    27
    OK - it's pretty ugly gate drive - but cannot say more without a schematic ...
