Results 1 to 6 of 6
    Points: 5,915, Level: 18
    Jan 2012
    Italy
    1,042
    5,915
    18
    Stability issue of the closed loop feedback in fully differential ampliifer
    Hello all
    I am trying to simulate the slew rate of my fully differential amplifier, I am using feedback resistors of 100 M Ohm to avoid loading the amplifier, the problem I am getting an oscillated output, while indeed I have good phase margin in my amplifier by simulating it from small signal analyses.
    How can I use more precise way to simulate the slew rate of the OTA without having feedback effect on the circuit
    Points: 24,721, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,735
    24,721
    38
    Re: Stability issue of the closed loop feedback in fully differential ampliifer
    Maybe those feedback resistors are too high. Combined with the parasitic capacitance you might have built an oscillator. Or perhaps a problem with input bias current. Just try smaller resistors and see what happens.
    Points: 263,599, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,053
    263,599
    100
    Whats's the purpose of feedback resistor in your simulation circuit? If it's DC bias, the feedback path should be filtered in a way that it doesn't ruin phase margin.
    Jan 2012
    Italy
    1,042
    5,915
    18
    Dear FvM, Dear barry
    The purpose of the feedback resistors, because I want to set the gain to unity for testing the slew rate of the fully differential amplifier, if for single, ended there will no need and the setup is easily done by using a buffer with output shorted to vin-, this connection we can not use it for fully differential counterpart.
    Now as Barry and also Behzad explained, a big resistor feedback combined with the input capacitance of the differential amplifier creat poles that disturb the differential path. In the same time I cant use small resistor values for high output impedance OTA,
    Then how can I test the slew rate for this case ?
    barry's Avatar
    Mar 2005
    California, USA
    4,735
    24,721
    38
    No one suggested using a small resistor, but 100M is almost no resistor at all. I suggested trying a smaller resistor (1M, 100K). Did you do that?
    Jan 2012
    Italy
    1,042
    5,915
    18
    Dear Barry,
    Also the same bad oscillation I have
    I would like to learn from you how to simulate the SR from only capacitive feedback loop ? will it possible?
