Results 1 to 5 of 5
    Newbie level 2
    Points: 27, Level: 1
    Dec 2019
    27
    Confusion with relating the sensor output voltages from its datasheet
    From the datasheet of this acccelerometer (ADXL335) I cant figure out the x y z outputs' voltage ranges. Is it mentioned in the datasheet what output voltages corresponds to -3g and +3g?
    And how can I calculate the voltage output corresponding to 500µg?
    Advanced Member level 1
    Points: 2,677, Level: 12
    Jan 2019
    489
    2,677
    12
    Re: Confusion with relating the sensor output voltages from its datasheet
    data sheet page 3:
    Sensor Input Measurement range (typical) +/- 3.6g
    Sensitivity (typical) 300 mV/g
    Zero g Bias Level (typical) 1.5 V
    These tell me that an output of 1.5 V means no acceleration
    and that the acceleration is measured at 0.3 V/g, so 1.8 V is 1 g in + direction, probably up from the chip's point of view,
    and 1.2 V is 1 g in - direction, probably down from the ships point of view.
    Page 5 pin functions and function descriptions has a drawing of the chip, with x, y, and z axis shown in the center of the drawing,
    thereby defining the + and - directions in 3 space.
    500 ug * 0.3 V/g = 150 uV
    Points: 263,617, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,056
    263,617
    100
    I agree that the datasheet is very clear about expectable output voltage.
    But if you plan to measure 500 ug acceleration, you should carefully read the datasheet info about noise density and temperature drift.
    Points: 18,428, Level: 32
    Nov 2012
    3,267
    18,428
    32
    500 ug = 500 x1e-6x980 cm.sec^(-2) = 0.49 cm.sec^(-2) ---> bit small but can be measured.
    As others have pointed out earlier, the output will be around 150 uV. Bit small but can be measured accurately with a decent amplifier.
    As others have mentioned before, you also need to pay attention to the noise. That essentially means that you cannot make two measurements in quick succession.
    Advanced Member level 2
    Points: 3,123, Level: 13
    Aug 2016
    548
    3,123
    13
    A lot of the relationships are ratiometric which means that you have to set out your specifications first.
    What is your supply voltage?
    --Akanimo.
