Results 1 to 9 of 9
    Member level 5
    Points: 1,792, Level: 9
    Mar 2012
    92
    1,792
    9
    Distance between MCU-Phy-Magnetics-RJ45
    I want to designt a fast ethernet line (1 Gigabit)
    My SOC (xilinx Zynq) has to be connected to a PHY then to magnetics and finally to a RJ45 connector
    SOC-------------PHY-----------Magnetics---------RJ45
    |---distance 1---|---distance 2---|---distance 3---|
    I know that thumb rule talks about 25 mm of distance between each component
    But I need to place the RJ45 connector far 50-100cm from the SOC.
    So what is the recommendation for all the distances between the components (PHY, Magnetics, RJ45) ?
    max distance 1 = ?
    max distance 2 = ?
    max distance 3 = ?
    Points: 263,329, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    Re: Distance between MCU-Phy-Magnetics-RJ45
    You have to check impedance matching and termination for each connection. Ethernet is usually terminated at the PHY, in this case, there are no restrictions for PHY to magnetics or magnetics to JJ45 connections, except for common mode EMI considerations. SOC to PHY depends on the interface standard and trace impedance. If correctly terminated, it can be extended to a few 10 cm without problems.
    Member level 5
    Mar 2012
    92
    1,792
    9
    Thanks FvM,
    So assumingly that all traces are terminated correctly and controlled impedances,
    The,
    max distance 1 < 10cm
    max distance 2 = no restriction
    max distance 3 = no restriction
    Correct?
    Can you point me to a good article / application note ?
    Member level 5
    Mar 2012
    92
    1,792
    9
    And one more question :
    Why the DISTANCES between the PHY and the magnetics needs to be AT LEAST 1 inch ?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    Where do you see this specification?
    Member level 5
    Mar 2012
    92
    1,792
    9
    In PULSE - Layout Considerations for Pulse Ethernet Magnetics and Ethernet Connector Modules note it says:
    "For EMI consideration, this distance must be
    25mm (approx. 1 inch) or greater for both
    discrete and integrated magnetics."
    https://www.networking.pulseelectron...f?hsLang=en-us
  7. #7
    Points: 80,159, Level: 69
    Apr 2014
    16,271
    80,159
    69
    so the paper already gives the answer to the question: It´s to reduce EMI.
    Now I don´t have the HF knowledge to verify this statement. So what can I do?
    * accept it and design the circuit according the paper
    * or avoid it, by using magnetically shielded RJ45 connectors with built in tranformer.
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,329
    100
    The Pulse application text is an undeclared quote from an SMSC/Microchip application note. http://ww1.microchip.com/downloads/e...s/en562748.pdf
    If distance actually creates common mode isolation depends on the common mode trace impedance. It may help in some cases. SMSC PHY chips are known to have common mode interference issues, I'm not sure if we can generalize it.
  9. #9
    Points: 12,785, Level: 27
    Feb 2010
    UNITED KINGDOM
    1,996
    12,785
    27
    Its is 25mm OR LESS between the magnetic's and the RJ45 connector...
    It is 25mm OR GREATER between the Magnetic's and the PHY
    This is mentioned in numerous data sheets and application notes...
    The distance is to avoid the magnetic fields of the transformers influencing the Phy.
