Results 1 to 2 of 2
    Newbie level 1
    Points: 14, Level: 1
    Dec 2019
    14
    Getting connectivity information from fsdb file
    I have a fsdb file. I am converting it to vcd with the fsdb2vcd command.
    I am opening the vcd file with the simvision tool and the tool converts it to .trn and .dsn
    However when I open the database I can only see the wave values. I cant access the source code or the schematics of the simvision tool
    (these options are usually available when running originally with ncelab -access rwc)
    (When I open the original fsdb with verdi - I do have acces to sorce code)
    Is there any way I can make the conversion with access to the source and connectivity?
    Points: 8,965, Level: 22
    Apr 2016
    1,879
    8,965
    22
    Re: Getting connectivity information from fsdb file
    Quote Originally Posted by tomer View Post
    VCD file is not meant to store netlist/connectivity. You can simulate a VCD along with a netlist, if that is what you are asking...
    Really, I am not Sam.
