Results 1 to 3 of 3
    Newbie level 1
    Points: 926, Level: 6
    Dec 2014
    926
    Leakge current in low Vt cells
    Why leakage current in low Vt cells is high as compare to high Vt cells ?
    Points: 40,215, Level: 49
    Mar 2008
    USA
    6,493
    40,215
    49
    Re: Leakge current in low Vt cells
    Because the subthreshold slope has not intersected the
    junction leakage floor by the time you hit Vgs=0.
    This not only makes the leakage higher, it makes it highly
    variable - a nominal 80mV/decade means that if your VT
    of 200mV (low-VT) has a +/-100mV tolerance the real
    leakage current could vary upward by over a decade at
    Vgs=0 (or downward, but nobody cries about that).
    And even at nominal, 2.5 decades (for 200mV/80mV)
    means you'd leak about 3nA per transistor (where a
    good long channel high VT FET should be femtoamp
    range). Now figure your LVT transistor count.
    Points: 8,831, Level: 22
    Apr 2016
    1,856
    8,831
    22
    Quote Originally Posted by riti View Post
    Simply put, because low Vt cells are designed for performance. The trade-off is that the threshold is so low/narrow, that it leaks more.
    Really, I am not Sam.
