Results 1 to 4 of 4
    Junior Member level 1
    Points: 240, Level: 2
    Feb 2019
    17
    240
    Iran Core Transformator No Load Current (Core material)
    Hello friends
    I have two types of iron to make the iron core Transformator
    In the same number of rounds
    220v to 12V
    Type A No Load current = 130ma
    Type B No Load Current = 100ma
    What can we conclude empirically?
    Is Type B Better?
    Points: 261,871, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,764
    261,871
    100
    Re: Iran Core Transformator No Load Current (Core material)
    May be better. For completeness, we would measure current phase angle. Current can be lower due to higher permeability or lower losses.
    Points: 11,899, Level: 26
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    type B may be thinner lams or toroidal...? = lower losses
    or more turns on pri wdg ...
    Points: 15,100, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,507
    15,100
    29
    You need to measure real core loss, with a wattmeter that measures true power= V*I*cos(alpha).
    The core material with the lowest losses, all other things kept identical, is the best.
    When I say all other things should be identical, I mean IDENTICAL. Including the applied voltage.
    My batteries are recharged by "Helpful Post" ratings.
