Results 1 to 3 of 3
    Newbie level 3
    Points: 27, Level: 1
    Dec 2019
    Bengaluru
    27
    is there any relation between IR drop and Noise Margin ?
    In ASIC design, is there any relation between IR drop and Noise Margin ? and If yes, then how?
    Last edited by andre_teprom; 2nd December 2019 at 18:35. Reason: title descriptive
    Points: 40,216, Level: 49
    Mar 2008
    USA
    6,493
    40,216
    49
    Re: ASIC Physical Design
    Yes.
    Your noise margin (for a fully settled output) is the
    distance from rail voltage to threshold voltage. At rails
    come together (I*R applies to both vdd and vss) the
    distance must shrink. And that's just for the simple
    static case.
    Now consider a case where a gate at the worst "sagged"
    point of the core, tries to drive another gate that's well
    supplied (say, right up near the periphery bussing). The
    core gate will have a vss potential higher and a vdd
    potential lower than the peripheral gate, so the offset
    subtracts from static noise margin and also gives sub-par gate
    drive levels to the receiving gate. This can cause timing
    to push out, possibly making logic fail for causes that
    are not comprehended by static timing analysis.
    Then there's that the I*R drop is not at all static, and things
    like simultaneous switching can bounce the rails and signals
    driven from them, big time - not just I*R, but L*dI/dt on
    top of that. With about 1nH/mm, and chip sizes well above
    10mm, and tens of pS risetimes, that's some ugly arithmetic.
    Then think about hundreds or thousands of registers flipping
    on "special occasions", cranking their output through high
    drive (hence high shoot-through) buffers and millimeters
    of wireload apiece....
    Points: 8,845, Level: 22
    Apr 2016
    1,858
    8,845
    22
    Quote Originally Posted by akhil_psm View Post
    Yes, there is. The explanation above is pretty thorough.
    I would only add that in digital design we often don't think in terms of noise margin, we think in terms of library margins. If your library was characterized to work at nominal VDD-10%, that is where you draw the line.
    Really, I am not Sam.
