Results 1 to 7 of 7
    Points: 16,954, Level: 31
    neazoi's Avatar
    Jan 2008
    Greece
    3,423
    16,954
    31
    Converting AF oscillator to use discrete components
    Hi I would like to convert the last circuit on this page http://www.learnabout-electronics.or...tors/osc34.php to use only discrete components and remove the opamp somehow.
    Is that possible and how?
    I have made an ALC amplifier for RF http://qrp.gr/minivfo which I think it can be used for audio as well, but this will be a total of 4 transistors including the oscillator one. I need to do it as simple as possible.
    Any ideas?
    Professional engineering is the top, but amateur engineering is more fun.
    It is when you cross the barrier between these two, that things become really fascinating!
    Points: 263,518, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,040
    263,518
    100
    Re: Converting AF oscillator to use discrete components
    Wien bridge need a non-inverting amplifier with gain around +3, variation range can be relative small. For clear sine wave output, a linear control element like JFET is preferable, I would even refer to an additional linearization circuit that superimposes half of the drain-source AC voltage to gate-source voltage, can be found in many Wien bridge designs.
    A two or three transistor complementary amplifier should serve the purpose.
    Points: 53,534, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,063
    53,534
    56
    Wien-bridge oscillator made from 2 transistors. A schematic is at website:
    http://www.circuitstoday.com/wien-bridge-oscillator
Name:	wien bridge sine oscillator 2 transistors 152 Hz 3V supply.png
    Component values aren't labelled so I tried playing with values until it started oscillating by itself. The potentiometers need to be adjusted within a narrow range, so that transistors receive just the right amount of bias.
    Points: 12,466, Level: 26
    Aug 2015
    Melbourne
    2,035
    12,466
    26
    you could replace the op-amp with the bjt equiv - long tailed pair etc ... about 7 xtors
    Points: 82,644, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,571
    82,644
    70
    I'm not sure Brad's schematic is a true Wien-Bridge design as it uses different RC values in the series and shunt arms of the feedback loop and it also has additional phase shifting between the amplifier stages. This probably accounts for the critical bias problem as the bias settings also change the RC time constants. It would be very difficult to tune when the R and C feedback components do not track in value.
    It would be better to concentrate on a wideband amplifier with minimal phase shift then apply the frequency selection only in the feedback loop.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,040
    263,518
    100
    The original circuitstoday design is a Wien bridge, the modified one strictly isn't, just some kind of RC oscillator, apparently working.
    To achieve good sine quality, you need ALC. Or an oscillator topology with effective harmonic suppression like Bubba.
    If you want variable frequency with tandem potentiometer as in the post #1 design, true Wien bridge is preferable.
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,040
    263,518
    100
    To show the feasibility of discrete implementation, see the below circuit and simulation files.
    It can be probably optimized in different ways, I believe that the original OP implementation is more straightforward and essentially simpler i any case.
