Results 1 to 4 of 4
    Newbie level 1
    Points: 23, Level: 1
    Nov 2019
    23
    digital integrated circuits
    I am puzzled about the equivalent circuit of digital IC's input and output ports.
    I consider the input port to be an equivalent resistor and equivalent capacitor parallel to the ground , and the output port is a voltage source series resistor
    to the output .The voltage source voltage and resistor value depend on the level of the output.
    Do I understand what I'm asking?Click image for larger version.
    Advanced Member level 1
    Points: 2,388, Level: 11
    Jan 2019
    442
    2,388
    11
    Re: digital integrated circuits
    i do not see a question
    Points: 11,947, Level: 26
    Aug 2015
    Melbourne
    1,955
    11,947
    26
    often the inputs have diodes to Vcc & Vee for protection ...
    ditto for the o/p pins ...
    Points: 8,871, Level: 22
    Apr 2016
    1,861
    8,871
    22
    Yep. In a modern ASIC there is still a lot more. You can expect a lot of level shifting going around, a lot of clamps for ESD protection, buffers, etc.
    Really, I am not Sam.
