Assigning a null array in VHDL
shaiko
In a package I have the following definition of a unconstrained unsigned array:
type array_1d_unsigned is array ( integer range <> ) of unsigned ;
In another file I have an input port named 'x' that is of that type:
entity some_entity is
x : array_1d_unsigned
While instantiating the entity, I want x to be assigned with a null array.
inst_some_entity : some_entity
x => -- I want to assign a null array here.
What's the correct syntax for that ?
You'll need to create a null constant (or signal):
Code VHDL - [expand]
constant NULL_ARRAY : array_1d_unsigned(1 to 0)(1 to 0) := (others => "");
x => NULL_ARRAY,
Because its unconstrained, you cannot do it inline, because OTHERS is not allowed in an unconstrained context
Reactions: shaiko
    shaiko
This is what I tried to do.
But how will the definition of that constant look?
Please show an example.
I dont understand what you mean, I showed you how to define the constant.
Sorry.
I viewed this on my cellphone first.
And what you wrote in the line of code didn't show.
Forum admins - please note of this problem.
Sorry.
A snapshot of how this looks on my phone is attached.View attachment 156581
You can't use the mobile site if you want to see any attachments. The forum on the mobile site is text based only.
Use the full site.
Reactions: shaiko
    shaiko
TrickyDicky,
The solution with the constant worked.
But what if x was an array of integers ?
type array_1d_integer is array ( integer range <> ) of integer ;
Can you post an example of a null array instantiation of this type ?
A NULL array is defined as array with 0 length. ie. one with a range where 'left is higher than 'right in the case of to, and 'left is less that 'right when using downto.
