Results 1 to 18 of 18
    Points: 11,899, Level: 26
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    Multiple pulse width ( 5 pulses ) inverter and lowest low order harmonics
    Hello All, we are looking at 5 pulse MPW for small inverters, 24VDC to 230Vac 50/60 Hz. ( unipolar for those tech savy in this area )
    Is there a paper or person out there who has looked at the low order harmonics resulting from the 5 pulse approach and the spacing of the pulses and relative width at full power for lowest harmonic magnitude for the lower order harmonics? - particularly the 3rd, 5th, 7th, 11th, maybe the 15th
    I guess I will be doing this from scratch from 1st principles to calc the harmonics resulting from the various arrangements possible - if someone has covered the ground before and zeroed in on the best relative spacing and relative widths I would be appreciative of some pointers in the right direction.
    Most important is that the lowest harmonics have the lowest magnitude as, as you go up in freq the higher order are easier to filter.
    Please no " guesses or 'helpful' suggestions " from those not au fait with fourier analysis or harmonic series mathematics or unipolar 5 pulse MPWM ( multiple pulse width modulation )
    If some one has the ability to do this work - I would be happy to recompense for sound results
    kind regards
    additional info: the middle of the 5 pulses ( per half cycle ) is to be fixed, they are to vary in width to control Vout from no load ( skinny ) to full load ( maximum ideal width for min low order harmonics ) - ta.
    Points: 261,889, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    Re: Multiple pulse width ( 5 pulses ) inverter and lowest low order harmonics
    Just for clarification, with 5 pulse unipolar, you are referring to a waveform like below?
    It has 5 degrees of freedom, should allow to set fundamental magnitude + eliminate 4 harmonics (3, 5, 7, 9).
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    A similar modulation scheme with harmonic cancellation is referred to as Magic Sinewaves, for some reason using an even number of pulses per half cycle. https://tinaja.com/glib/msinprop.pdf
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    Hello FvM, yes your sketch is correct, the magic sine waves page does not quite cover what I am seeking ( 5 pulse unipolar ) I note that LT Spice will give me an FFT of a waveform - so I will begin there before I jump into the heavy maths for an analytic solution, kind regards,
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    You can determine the optimal pulse timing for harmonic cancellation using fourier series and Excel solver. I'll send you an example tomorrow.
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    Fourier analysis of 5 pulse MPWM ( multiple pulse width modulation ) for inverter
    Hello All, thought I would re-post this here - as it essentially a mathematics problem.
    Determine the placement and width of a 5 pulse multiple pulse width modulated (mpwm) system - unipolar on each half cycle
    to get the least ( ideally zero ) lowest order harmonics for the 3rd, 5th, 7th, (9th) 11th, 15th
    the lower the better for the lower orders as these are the hardest to filter ...
Name:	5 pulse uni.jpg
    We are looking at 5 pulse MPW for small inverters, 24VDC to 230Vac 50/60 Hz. ( unipolar for those tech savy in this area )
    additional info: the middle of each of the 5 pulses ( per half cycle ) is to be fixed, they are to vary in width to control Vout from no load ( skinny ) to full load ( maximum ideal width for min low order harmonics ) - ta.
  7. #7
    Points: 78,975, Level: 68
    Apr 2014
    16,025
    78,975
    68
    Re: Fourier analysis of 5 pulse MPWM ( multiple pulse width modulation ) for inverter
    I see your idea:
    There are positive signals causung some overtones...and there is the same signal negative ...and you want it to cancel all the frequencies.
    For sure they include the same frequencies and for sure the same amplitudes....but there is more than this: Phase. Phase or each frequency.
    You can only calculate FFT if you have a signal with fully specified timing.
  8. #8
    Points: 53,205, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,006
    53,205
    56
    I assume the filter is an inductor or transformer? The tendency is that voltage falls immediately after a pulse ends. I think the aim is to add a few brief pulses, to slow the drop.
    My simulation makes each pulse adjustable as to length and when it occurs in the cycle. Diodes steer them to a joint output. The load gets the positive portion of a sine-like waveform. The inductor value was selected so as to slow the upward transition of the long pulse so it resembles the rise of a sine wave.
Name:	5-pulse sine-like positive portion (each pulse adjustable widest is 3rd).png
    It may work just as well to make pulse #2 the long pulse. It leaves more remaining pulses which can be more finely spaced.
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    As mentioned before, the fundamental and harmonic magnitudes can be best calculated and optimized using Fourier series.
    You can superimpose 5 instances of the elementary double pulse with alternating sign to model the unipolar 5-pulse pattern.
    See the below appended Excel table. Excel solver must be installed to perform the optimization.
  10. #10
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    as it is symmetric about pi/2 ( 90 deg ) this helps in the maths
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    I get the below shown edge timing for cancellation of 3/5/7/9th harmonic. Time scale is rad. Magnitudes without the 4a/pi factor.
    I have set an arbitrary minimal pulse width of 0.05 rad, the yellow background marks limited pulse/gap width, respectively incomplete cancellation.
Name:	5-pulse table.jpg
ID:	156555 Click image for larger version.
  12. #12
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    great work FvM, unfortunately it is a bit hard to see what you have presented, the middle pulse should be the major one - as per your sketch, the next outer pulses should be about half the width of the middle one and the outer pulses should be about half again in width - this will get near to low order cancellation ( <30dB ).
    I have been reconstructing a "filtered" "sine wave" output by putting the 1st, 3rd, 5th, 7th, 9th, 11th, 13, 15, 17, 19, 21 back together after seeing what they are from the MPWM, this gives me good optics on the progress, and the effect of each harmonic. LT spice seems to be good for this - generating the harmonic amplitudes from the MPWM, and for adding the harmonic sine waves in various harmonics and phases ....
  13. #13
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    The emphasis of the presented results is on the feasibility of harmonic cancellation over a certain magnitude range. I'm assuming that this solution, if achievable, is also unique.
    Because the magnitude of higher harmonics isn't represented in the error function, the solution isn't necessarily optimal according to more general criteria, e.g. meeting power quality standards with or without low-pass filter.
    Alternatively you can include higher harmonics in the error function and optionally apply weighting. Lowest four harmonics won't be exactly cancelled, but total T.H.D. or some weighted error function can be minimized.
  14. #14
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    Hello FvM, thank you for your kind remarks, can you please explain what r1, f1 is in the above? and the ratio or exact width of the 3 pulses in the above also ( middle, outer, next outer ) - from inspection and from common sense 5 pulses ( in total ) will be able to greatly reduce the 3rd, 5th, 7th, and one other ( 9th or 11th - whichever gives the lowest overall THD ) - however none of that is easily viewable in your presentation.
    kind regards,
  15. #15
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    Sorry for lack of clarity. r1,f1 etc. are the edge times (rising 1, falling 1,...) in rad. To get the full picture, you should review the original Excel table from post #9. You can also try alternative optimizations.
    I add the achieved harmonic magnitudes in the below table.
  16. #16
    Aug 2015
    Melbourne
    1,946
    11,899
    26
    that is impressive - are the rise & fall times in radians?
  17. #17
    Apr 2011
    13,006
    53,205
    56
    By definition the output which closely resembles a sinewave has the least harmonic content. Or from another viewpoint, the less filtering needed, the better.
    Here is my simulation which puts the first pulse as the widest. The first upward-going transistion is slowed by the inline inductor. The remaining pulses are timed to allow a gradual drop in amplitude. (And not the typical sharp drop). The result is sine-like. A sinewave serves as reference.
Name:	5 pulse 1st widest 5 opamps 5 caps 5 diodes 3mH unfold to AC n reference sine 50 Hz.png
    A switching arrangement unfolds the output polarity, so that the load receives bipolar AC.
  18. #18
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    Yes, exactly.
