Results 1 to 3 of 3
    Full Member level 2
    Points: 1,984, Level: 10
    Nov 2011
    123
    1,984
    10
    PCB and schematic simulation for CE with CST
    Hi guy,
    i'm currently doing pcb simulation with CST. i have some basic question to ask here.
    let say i assign a discrete port in my PCB for a series component as shown in figure below
    In schematic tab i assign this discrete port as lump component. the connection is shown in below. am i doing it right, by terminating the other end with a ground.
    one more question if i replace it with a series resistor, i wanna probe the signal after the series resistor, which side i should place the probe in schematic tab, the ground site or the other side?
    hope someone here can answer my question.
    thanks
    Points: 14,451, Level: 29
    Apr 2014
    2,255
    14,451
    29
    Re: PCB and schematic simulation for CE with CST
    Quote Originally Posted by arr_baobao View Post
    Yes, that creates a connection from the ports plus terminal to the ports local reference.
    If your port represents a series element, then both is wrong. You need to probe voltage against the "global" ground where the input ports refer to. Which means you need another port that has ground reference connected to that global ground.
    Full Member level 2
    Nov 2011
    123
    1,984
    10
    Quote Originally Posted by volker@muehlhaus View Post
    sorry u mean if it reprensent a series element then i cant place ground on the other side on the schematic tab?
