Temperature mobility degradation factor (c) - MOSFET SOI
lufer17
Member level 5
There is an equation that I can't find in any book or scientific article referring to the letter '' c '', what is the origin of it if there is a calculation behind or something? I would very much like that source that explains itself broadly on the subject. Or at least the equation of (c).
It is related to zero temperature coefficient [ZTC]
Eq:
μn2 = μn1*(((T1)/(T2)))^(c)
This is an empirical equation or model, describing a temperature dependence of carrier mobility.
Mobility decreases with temperature, that's it.
"C" is a fitting parameter, that hsould be found from fitting the model to the measured characteristics.
Thank you very much for your help.
If you can indicate a reference book or article say about point that it is impiric.
Really did not find.
