Results 1 to 2 of 2
    Newbie level 6
    Points: 902, Level: 6
    May 2015
    14
    902
    Heating a cuvette which is placed in a box.
    Hello everyone.
    I need some ideas/Inputs on heating a cuvette(upto 60° C). And the temperature should not exceeding 80° C,Since the trasistion temperature is 80° C). This cuvette is inserted into a rectangular box(L:8cm;W:3cm;H:2cm). So space is an important constraint here.
    What I am thinking is to have a copper plate under the cuvette and use the resistor heating(If you have any other ideas of heating please share it). But I do not have any idea on how to control the temperature.
    Please let me know if you have any ideas on controlling the tempeartures.
    Thank you.
    Advanced Member level 1
    Points: 2,366, Level: 11
    Jan 2019
    436
    2,366
    11
    Re: Heating a cuvette which is placed in a box.
    You might want to use aluminum instead of copper.
    Aluminum is less expensive, easier to machine and the thermal conductivity is not significantly different from copper.
    try a simple mechanical switch to open when it gets too hot, and close when it gets cold, like this
    https://www.digikey.com/products/en/...1&pageSize=500
