Results 1 to 4 of 4
    Member level 3
    Points: 659, Level: 5
    Jan 2018
    64
    659
    Resistors in Wilson current mirror
    I have some questions concerning analog audio amplifiers: what is the purpose of resistors R1 and R2 in the Wilson current mirror? With what formula are they calculated? Can they be omitted? If they are omitted, what happens to the VAS (Voltage Amplifier Stage)?
    Points: 40,223, Level: 49
    Mar 2008
    USA
    6,493
    40,223
    49
    Re: Resistors in Wilson current mirror
    They improve Vbe-match and current-match fidelity (if
    the resistors have better matching tolerance than the
    transistors' Vbe). You need to establish a current across
    the resistors which dwarfs the mismatch voltage (like,
    if transistor population has a +/-10mV Vbe scatter,
    setting a 100mV (Iset*R) value ought to improve the
    mismatch 90%.
    You lose a little headroom but in older +/-15V analog
    (or discrete) this is tolerable.
    An audio circuit doesn't care about DC as long as
    it's centered and linear, right? If there's feedback
    then small mismatch error in current mirrors may not
    amount to anything. You'd need mismatch modeled
    to say.
    Points: 261,889, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,767
    261,889
    100
    Current mirror need monolithic transistor pairs to achieve reasonable matching. The emitter degeneration resistors are a possible means to get a kind of current mirror behavior with discrete transistors.
    Points: 30,745, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,509
    30,745
    42
    They can also be used to achieve PTAT Current by well adjusting Resistor and Transistor Multiplication number..
