Results 1 to 6 of 6
    Newbie level 2
    Points: 22, Level: 1
    Nov 2019
    22
    How to generate sine wave using Verilog?
    I have to generate a two different sine wave(1st sine wave normal sine wave which is generate from 0 degree and 2nd one phase shifted sine wave ) using Verilog, and on google, I found something related to it but somehow I didn't understand. So, could anyone explain to me the logic behind this code?
    module sine_cos(clk, reset, en, sine, cos);
       input clk, reset, en;
       output [7:0] sine,cos;
       reg [7:0] sine_r, cos_r;
       assign      sine = sine_r + {cos_r[7], cos_r[7], cos_r[7], cos_r[7:3]};
       assign      cos  = cos_r - {sine[7], sine[7], sine[7], sine[7:3]};
       always@(posedge clk or negedge reset)
         begin
             if (!reset) begin
                 sine_r <= 0;
                 cos_r <= 120;
             end else begin
                 if (en) begin
                     sine_r <= sine;
                     cos_r <= cos;
                 end
             end
         end
    endmodule
    but here what is the logic for ?
    Points: 78,399, Level: 68
    Apr 2014
    15,899
    78,399
    68
    Re: How to generate sine wave using Verilog?
    I expect there is some description where you found the code.
    --> please post the link to the internet page.
    Points: 261,125, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,608
    261,125
    100
    The oscillator operation has been discussed in previous threads, e.g. https://www.edaboard.com/thread39599.html
    The Verilog implementation is somehow clumsy, the function can be made much clearer by using signed data type.
    Code Verilog - [expand]
    output signed [7:0] sine,cos;
    reg signed [7:0] sine_r, cos_r;
    assign      sine = sine_r + (cos_r >>> 3);
    assign      cos  = cos_r - (sine >>> 3);
    Advanced Member level 3
    Points: 6,155, Level: 18
    Feb 2014
    888
    6,155
    18
    Consider that the derivative (slope) of sin is cos and the derivative of cos is sin. Thus you can increment one by a value proportional to the other and you get a self-oscillating output that's a very good (not perfect) sin wave.
    The specific code you're questioning is just a power of 2 divide. FvM posted a better way to do this. The more you divide the longer the period is.
    The biggest problem is rounding errors. You need to get lucky and find a set of parameters that returns exactly to where it started or you need to reset every cycle introducing a small amount of distortion. If you don't the amplitude will 'walk away' towards zero or infinity.
    Bottom line this is a very 'cheap' way to generate a sin wave in an FPGA. For high precision work you're best off using the IP blocks that all FPGA manufacturers provide.
    Newbie level 2
    Nov 2019
    22
    Hi, FvM
    Heartily thanks for the replay ,
    so by using this shift operators we rotate back Or right shift signal by 3 ?
    by using sine and cos equations ?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,608
    261,125
    100
    >>> is arithmetic shift, >>> 3 means multiply with 0.125.
    For a deeper insight how it works please review the linked old thread.
