T
treez
Hello
I was scoping the Primary , Post rectifier DC Bus in a 100W, 240VAC, offline PFC’d Flyback to see what the voltage ripple was like on this rail.
As you can see, at the mains peak, there is a lot of noise at the peak of the waveform that makes the measurement impossible.
The blue waveforms were done with a x10 scope probe (with a dangling ground clip) with its lead wound in three turns round a ferrite torroid. The yellow waveforms are done with a diff probe.
I obviously need a ten times coaxial probe without the dangling ground clip.
Do you know of one?...or must I do the old trick of wrapping wire round the ground barrel of the probe?
